Draw for handbuilt acoustic guitar get your name in
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Mig Welder  (Read 2106 times)
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Mig Welder
« on: January 12, 2018, 10:01:28 PM »
Hello,
 Found this. Anyone have one like this?
Need to get a Argon tank for the spool gun.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Chuck White
  • Sawing Mobile since 2005
Re: Mig Welder
« Reply #1 on: January 12, 2018, 10:06:04 PM »
That's a step up from me Marty!
Mine uses flux core wire, yours uses Argon gas, obviously you have the better unit!    ;)
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Offline scsmith42
    • Whispering Pines Farm
Re: Mig Welder
« Reply #2 on: January 12, 2018, 10:16:42 PM »
Nice setup Marty.
I have something similar from Lincoln (210MP) that I like a lot.  Don't have a spool gun with it though.
Enjoy!
Tom's 3638D Baker band mill
Offline hopm
Re: Mig Welder
« Reply #3 on: January 12, 2018, 10:27:39 PM »
No expert by any means, but we have one like that at our shop. I asked the guy who does our welding if he could teach me. He asked me if I could use a chalk gun. Told him yes. He said you wont need much teaching. With his guidance he made it alllllmost idiot proof. Been able to use it on many occasions and be confident in the weld. Does a really good job.
Offline starmac
Re: Mig Welder
« Reply #4 on: January 12, 2018, 11:07:41 PM »
I have a spool gun that is very similar to that one, but the welder I used it with has passed on and is long gone. I had two regulators so I could leave both bottles set up and ready on the cart, just plug and play between the suit case and the spool gun.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Mig Welder
« Reply #5 on: January 12, 2018, 11:11:21 PM »
You plan on welding that hydraulic box back together?  ;D
Where's the Spoon?
Online LeeB
Re: Mig Welder
« Reply #6 on: January 13, 2018, 01:31:42 AM »
Any major downside to using CO2 instead of Argon?
Offline starmac
Re: Mig Welder
« Reply #7 on: January 13, 2018, 05:23:54 AM »
Argon is to use with the spool gun on aluminum. Co2 or a mixture of CO2 and argon is what is commonly used for steel.
Offline goose63
Re: Mig Welder
« Reply #8 on: January 13, 2018, 08:08:06 AM »
Argon will burn a little hotter and with a lot less splatter
goose
thank you to all the vets
Offline millwright
Re: Mig Welder
« Reply #9 on: January 13, 2018, 08:50:40 AM »
You will be able to easily weld aluminum with that. Use argon and preheat a bit and keep the metal shiny clean. I usually wash down aluminum with acid you can get at any truck supply, they use it for cleaning wheels and aluminum boxes
Online John Mc
Re: Mig Welder
« Reply #10 on: January 13, 2018, 09:07:31 AM »
For welding steel, I use a CO2/Argon mix on my MIG unit (75% Argon/ 25% CO2). It costs a bit more than straight CO2, but it works well, and I don;t use enough of it for the cost to be a significant issue.
If you are using a spool gun, I assume you want to weld aluminum. For that, I believe you need straight Argon (but I'll defer to the guys who actually do aluminum welding. I haven;t messed with it).
Offline chevytaHOE5674
  • Forester
Re: Mig Welder
« Reply #11 on: January 13, 2018, 10:26:25 AM »
Welded a lot of aluminum with a spool gun on a miller mig machine. Argon gas and getting the aluminum as clean as possible are crucial. A stainless steel wire brush that only gets used for aluminum and acid are your best friends. While the spool gun will stick aluminum together i much prefer TIG welding alum when possible.
Offline woodworker9
    • Elite Concrete Raising Co.
Re: Mig Welder
« Reply #12 on: January 13, 2018, 11:12:36 AM »
The MM 211 is a good light to medium duty mig machine, rated for up to 3/8" steel.  Nice spool gun, too.  Those can get very pricey.
The 211 has an autoset feature that will allow you to set for ticknessh of material and weld.  The machine will make all the necessary changes.  Controlled by a board....so remember that.
The 211 will also run on 120V or 220V.  Obviously, 120V for thinner steel applications.
As stated, 100% Argon needed for that spool gun and aluminum.  I use C25 for steel.  You'll want tri-mix if you're welding stainless.
I have the Millermatic 200, which is the "old school" transformer power house big brother to yours.
For aluminum, as stated already, clean, clean, clean and more clean.  Also, preheat to 250 - 300 makes a huge difference.  For trailers and such, a spool gun is great.  For pretty welds, you're going to get sucked into the wonderful world of TIG.
Nice unit.  They hold their value very well.
There is a fantastic YouTube channel for anyone who wants to learn....."Welding Tips and Tricks".  Jody is a great teacher, and discusses all aspects of welding all different materials with all processes.  I have learned a lot from Jody over the past few years.  He made me a much better welder.
Online John Mc
Re: Mig Welder
« Reply #13 on: January 13, 2018, 11:40:15 AM »
Woodworker9 - Is this the YouTube Series you are talking about:
I'm FAR from an expert welder. I can stick pieces together, and sometimes it even looks good. My welds are functional, but I don't do anything that might be safety related. I stink at sheet metal (because most of my welding had been on 3/16" to 3/8" steel). I really need to practice on the sheet metal a bit.
I've watched some of ChuckE2009's welding videos. He has some instructional ones, but lately has been more into projects and reviews of equipment. I've watched a few of his instructional videos, but I'm not good enough to know how good an instructor he is. (It would help if I ran right out and tried some of the stuff he talks about after watching, but things just never seem to work out that way for me.)
Offline coxy
Re: Mig Welder
« Reply #14 on: January 13, 2018, 07:17:35 PM »
nice set up  when welding aluminum make shur you have no draft like a fan or an open door with wind blowing it don't work so well the first time I tried it I was out side what a mess  :D never did get the hang of it its nothing like welding steel  I use argon co2  and run it at 25psi seem to do better for me   I also learnt that if your up higher than your tank up your psi
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Mig Welder
« Reply #15 on: January 13, 2018, 08:32:11 PM »
I stick weld aluminum. Rods don't last long...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Mig Welder
« Reply #16 on: January 14, 2018, 10:35:21 PM »
One of my farmer friends has that exact setup spool gun and all and last time I checked he loves it.
Boy, back in my day..
Online Southside logger
Re: Mig Welder
« Reply #17 on: January 15, 2018, 11:10:47 AM »
With that spool and argon acting as a purge gas you would be able to weld stainless also and not get the burn through.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
  • Forester
Re: Mig Welder
« Reply #18 on: January 15, 2018, 11:20:50 AM »
I weld stainless without the spool gun with either normal C25 gas or 98/2 mix. The books all recommend a tri-mix gas. Pure argon and stainless leads to a tall cold beads with not so good penetration.
Re: Mig Welder
« Reply #19 on: January 15, 2018, 04:27:29 PM »
Hello,
   What about Helium? I know it makes you talk funny if inhaled and great to make the kids smile in balloons. What about uses for welding?
MArty
Got a used welder: now what?
Started by brdmkr on General Board
Last post March 25, 2006, 08:36:51 PM
by Tim L
what welder to buy
Started by DDW_OR on Wanted
Last post July 15, 2017, 06:45:56 AM
by Peter Drouin
welder
Started by bedway on General Board
Last post February 04, 2007, 11:02:31 AM
by bedway
225 AC/DC Lincoln welder...
Started by york on For Sale
Last post July 03, 2016, 03:18:48 AM
by york
