Baltic Abrasives Technologies
Author Topic: Grapple  (Read 2875 times)
Offline hopm
Grapple
« on: January 13, 2018, 06:47:51 AM »
Been watching grapples being used and see it as something that could be beneficial to my setup. However, like so many other pieces of equipment, price becomes an obstacle. In looking I saw a bolt on bucket grapple was priced reasonably. Any experience with one of these? I would be using it on an compact tractor. I have seen similar on large equipment, but would like your opinion on what I could expect on a compact. Thanks in advance for any guidance!!
Online YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Re: Grapple
« Reply #1 on: January 13, 2018, 07:33:42 AM »
I've never used one, but have a full grapple for my tractor. They are very useful, in the correct setting. The sides of the bucket or grapple play a large roll in what it can handle.  If I was getting a bolt on grapple, I would either install bucket teeth or cut an angled "V" in the sides of my bucket, much like a backhoe bucket, so stabilize and hold material better.
If I had to get only one attachment for a tractor, it would be a quick attach set of forks.  Even these days, 90% of the time, forks are on the tractor.
HobbyHardwoodAlabama.com
Offline ladylake
Re: Grapple
« Reply #2 on: January 13, 2018, 08:29:59 AM »
 Keep in mind a grapple weighs quite a bit, reducing the lifting capacity on a compact tractor. They are great for handling logs if you can lift them.  Steve
Offline york
Re: Grapple
« Reply #3 on: January 13, 2018, 08:51:52 AM »
I did not know that you could put a grapple on a compact tractor-How about a link for this grapple?
Albert
Offline 47sawdust
Re: Grapple
« Reply #4 on: January 13, 2018, 09:03:00 AM »
What is the loader capacity on your tractor?The other factor to consider is the wear and tear on the tractors front end.Light duty axles and gears will not hold up.
Mick
Offline hopm
Re: Grapple
« Reply #5 on: January 13, 2018, 10:24:07 AM »
This video caught my attention after I saw a larger grapple on a 70 hp tractor on a job I was on. The tractor in this video appears to be way small.
This is the one I want....
https://www.everythingattachments.com/Compact-Tractor-Wicked-Root-Grapple-50-Single-lid-p/eta-cut-sl-rg-50.htm
This is probably the best I could hope for....
https://www.palletforks.com/48-60-bolt-on-grapple-attachment.html
Online Darrel
  • Never throw an unopened log on the burn pile.
Re: Grapple
« Reply #6 on: January 13, 2018, 11:23:43 AM »
My FIL had a 24 horse Kabota with a bucket and backhoe.  I was amazed at how much it would do. Then when I had it at my mill, I was even more amazed at how much it wouldn't do.
1992 LT40HD
Offline DDW_OR
Re: Grapple
« Reply #7 on: January 13, 2018, 02:21:50 PM »
Here is what i recommend.
get the quick attachment like a skidsteer has.
then get pallet forks, and this
i may also get them
FYI, my pallet forks have 4 forks. makes my Mahindra 5520 into a pitchfork  8)
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Bruno of NH
Re: Grapple
« Reply #8 on: January 13, 2018, 02:31:19 PM »
Google the thumb grapple it will bolt or weld on many things buckets or forks
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline submarinesailor
  • LT15 and a wife of 45 yrs
Re: Grapple
« Reply #9 on: January 13, 2018, 03:04:24 PM »
I recently installed a thumb grapple http://greens-machine.com/ and like the way it works.  Need to get you guys some pictures.
Bruce
Offline Novascotiamill
  • I walked the “Thin Blue Line “ for 20 years
Re: Grapple
« Reply #10 on: January 13, 2018, 05:11:34 PM »
I just ordered a 55 inch wicked grapple for my ck2610,the grapple only weighs about 200lbs so ill have about 1000lbs of lift to use to move logs around ,pick up brush piles etc,it has a quik attach system as on a skidsteer. Ive got forks Ive been using to load logs but I think the grapple will be easier and safer. Go for it ,order one up!
2017 HM130
Stihl 261
2010 F150 xtr
Lots of rigid genx5 tools
1 long haired german shepherd
2017 kioti ck2610HST with FEL and forks
Grindlux band sharpener
Wicked 55” root rake grapple
O
Offline bandmiller2
Re: Grapple
« Reply #11 on: January 13, 2018, 07:29:12 PM »
As hammer says its hard to beat simple pallet forks. I have had a grapple and found it very useful for picking logs off a trailer and grabbing brush other than that I prefer forks. Frank C.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Grapple
« Reply #12 on: January 13, 2018, 07:53:29 PM »
My pallet forks came from Titan, off of the PalletForks.com web site, delivered here for $431.00!
About half price of the JD dealerships deal, and heavier made!
I use them on my JD 1023E subcompact and on my brothers JD 990!
~Chuck~
I LOVE MY SAWMILL
Offline farmfromkansas
Re: Grapple
« Reply #13 on: January 15, 2018, 08:20:18 PM »
  The latest Cooks flyer has reasonably priced grapples.
Offline buzywoodliff
  • It could ALWAYS be worse
Re: Grapple
« Reply #14 on: January 15, 2018, 08:58:39 PM »
I have to agree with Yellowhammer..... I have a fork attachment for a 100 hp kubota and use it all the time..  with a little finesse, i can pick logs up and out of my flatbed trailer that has 12" side boards.
Online samandothers
Re: Grapple
« Reply #15 on: January 15, 2018, 09:12:33 PM »
I have a 42 hp Kubota with a 60” grapple.  Most useful tool I have.  I have a backhoe on the tractor as a counter balance.  I use it not only to load logs but to put the waste for the burn pile on when sawing.  I put my boards on a set of forks that are not connected to the tractor.   After dumping waste on burn pile I drop the grapple and hook up the forks to take the boards to stack and sticker.  Quick attach feature makes the change quick and easy.
 I would be concerned with the bucket attached grapple being strong enough.  I have a slight bend to my top grapple because on not balancing my weight well enough. Can not imagine what this would have done to my bucket.
Also the the grapple is great for cleaning brush.
Offline Ohio_Bill
  • Wood is Good
Re: Grapple
« Reply #16 on: January 19, 2018, 08:05:35 PM »
Rather than going with a bucket grapple I decided on a Frostbite grapple . I have been very pleased with it .
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Offline JB Griffin
Re: Grapple
« Reply #17 on: January 19, 2018, 09:10:56 PM »
Google Wicker grapple to see the only type for around a sawmill imo.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline JB Griffin
Re: Grapple
« Reply #18 on: January 19, 2018, 09:15:43 PM »
Offline Randy88
Re: Grapple
« Reply #19 on: January 20, 2018, 05:55:06 AM »
Grapples are great, but first you need to narrow down exactly what your going to use it for, if all your doing is moving logs, a center grapple on forks works slick, if your picking up other things, a dedicated grapple bucket is the way to go, if your moving brush, the style shown on the skid steer is perfect.
What you need to determine is how tight you want to squeeze what your picking up, and then figure out if you want one clamp or two.
The style shown on the skid steer will squeeze what your picking up, most others won't unless the log is larger than the clamp, if that makes sense.
I run a double clamp severe duty grapple on my skid steer, with two clamps, works great for logs, or multiple logs, is about worthless on brush and smaller stuff, it won't clamp that stuff tight enough to carry it very far.
Mine weighs in slightly less than a 1000 lbs and the bucket portion is bullet proof, the hold down clamps we've tweaked over the years.     For the use and abuse we do with ours, the clamp should have been made out of T1 but I didn't know it at the time, the one I bought was the heaviest unit at that time, today there are dozens of manufacturers and hundreds of styles to choose from.  Best of luck.
Who sells a one-handed, small log / firewood grapple? Tongs with a grapple
Started by Jasperfield on Forestry and Logging
Last post August 28, 2008, 09:12:16 PM
by Dave Shepard
Grapple bucket or grapple forks?
Started by alan gage on Sawmills and Milling
Last post June 08, 2018, 11:06:11 PM
by mike_belben
Log Grapple
Started by danno on For Sale
Last post April 03, 2015, 07:42:57 PM
by Grizzly
How to run a grapple
Started by postville on Forestry and Logging
Last post December 20, 2011, 07:34:46 PM
by postville
