KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: E2300 digital temp controller  (Read 717 times)
Offline firechief
« on: January 13, 2018, 05:54:36 PM »
Hey all, just went out to check on boiler a bit ago and noticed my digital temperature controller readout was reading three 000ís and beeping every second. Tried setting boiler temperature higher but fan will not even kick on no matter what I do. Tried turning off and back on but no go. Had to shut down and back on natural gas furnace for now. Have had boiler since 2009 no issues such as this yet. Could be my controller is shot. Any thoughts ?
Thank you.
Offline stratford 50
Re: E2300 digital temp controller
« Reply #1 on: January 14, 2018, 06:39:57 AM »
Could it be low water level alarm?
Offline firechief
« Reply #2 on: January 14, 2018, 08:00:32 AM »
Stratford thank you for the reply. I will check that today. That very well be it, earlier this season I drained some water trying to get my water quality to where it should be. Maybe I did not add enough back and itís finally caught up. My manual doesnít state anything about a low water level alarm in my unit. It does mention about the digital readout showing LO on the duel fuel model which I donít have. I will check today.
Offline firechief
« Reply #3 on: January 14, 2018, 08:27:44 AM »
Well the water level looks full to where it should be on the according to the gauge.
« Reply #4 on: January 14, 2018, 12:19:09 PM »
The dipper on the water level sensor can break off and will cause an alarm, happened to my friends e-2300, disconnect the wire from the water level sensor to see if the alarm stops,
Offline firechief
« Reply #5 on: January 14, 2018, 12:36:12 PM »
Thank you. I will see if I can find.
Offline firechief
« Reply #6 on: January 14, 2018, 01:06:00 PM »
Stratford thank you for the suggestion but disconnecting the low water sensor wire didnít seem to fix it. Even tried disconnecting the water temperature wire separately but that didnít work either. Have to pick the brain of my dealer tomorrow. Thank you.
Offline boilerman101
« Reply #7 on: January 14, 2018, 07:16:03 PM »
Yes, sounds like a failed low water sensor. The sensor makes a continuity curcuit so you can't just unplug it. You would need to jump it out on the harnness side.
Offline firechief
« Reply #8 on: January 14, 2018, 07:53:03 PM »
Thanks boilerman. So I unplugged the plastic connector with the wire within plus disconnected the wire from the digital temperature controller and was still getting the alarm. Iím afraid I donít know enough to jump it.
« Reply #9 on: January 14, 2018, 11:52:29 PM »
Turn off power to the furnace. Plug sensor to harness connectors back together cut and strip wires near the sensor and wire nut them together on the harness side. that will complete circuit and furnace should run until you get a replacement low water sensor float.
Offline firechief
« Reply #10 on: January 15, 2018, 07:33:19 AM »
Thank you boilerman. So it looks like the sensor has two white wires going to it. To complete the circuit just cut, strip, and nut together to bypass the sensor ?
Offline firechief
« Reply #11 on: January 15, 2018, 10:56:29 PM »
Stratford and Boilerman:
Thank you for your help and expertise. It was a faulty low water sensor. Bypassed the circuit and she fired up. Was only down to 160 in 3 days. I imagine Iíll keep it bypassed until the season is over before I replace sensor. Much appreciated.
E2300 Controller Failure
Started by MudBud on Firewood and Wood Heating
Last post December 28, 2014, 11:21:27 AM
by MudBud
pwm controller
Started by kelLOGg on Sawmills and Milling
Last post August 06, 2006, 10:47:21 PM
by pineywoods
Kiln Controller
Started by shopteacher on Drying and Processing
Last post May 14, 2004, 08:40:29 AM
by SawDust_Studios
E Classic controller
Started by Dyerbrk on Firewood and Wood Heating
Last post March 28, 2011, 09:13:15 PM
by Dyerbrk
