Author Topic: Threading Wood , Beall Threading Kit  (Read 3341 times)
Offline 21incher
« on: January 13, 2018, 09:43:07 PM »
I need some threaded wood nuts and bolts for a future project so I just picked up one of the Beall threading kits to play with. The beginning shows the setup and how it works, the rest is just making the little accessories for it. Have to make some good properly sized dowels to get the best results.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline jayhdjr
Re: Threading Wood , Beall Threading Kit
« Reply #1 on: January 14, 2018, 07:55:06 AM »
I've always wondered how that was done. Thanks for posting, Jay
Logosol M7, Stihl 041, Stihl MS 310, Kubota B26
Offline 21incher
« Reply #2 on: January 14, 2018, 09:43:02 AM »
This seems to be the best way to get good results making threads from what I have read. They also make big threading dies like metal threading dies that seem to get mixed results. I have to make some good properly sized maple dowels to try next. :)
Offline Larry
« Reply #3 on: January 14, 2018, 01:48:15 PM »
Another interesting and well made video. 8) 8) 8) 8)
I like those Beall taps because they self align in the hole.  Small detail but I think worth while.
I make hard maple vacuum chucks for the wood lathe.  Tap 1-1/4" - 8 than I soak the threads in CA to harden the wood.  Re-thread to cut through the CA.  My chucks go off and on a lot and never had a thread failure....yet.  I sometimes do the CA trick on smaller threads if I think they will see much use.
Bigger taps (expensive) can be found on ebay cheap.  Re-sharpened works fine.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: January 14, 2018, 04:01:46 PM »
? What is CA ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #5 on: January 14, 2018, 04:49:56 PM »
Cyanoacrylate. Super Glue.
Offline 21incher
« Reply #6 on: January 14, 2018, 05:08:13 PM »
Thanks for the tip Larry I will try that. I just used junk dowels and they seem like fairly strong. Maple with ca would  probably be almost as strong as brass. I am going to have to check the thread on my lathe chuck that sounds like  a great idea. Or I  could make a stub for the 3 jaw chuck just using the 1 inch thread. Is there an online service that can resharpen the taps? :)
    • My homepage
« Reply #7 on: January 14, 2018, 07:36:57 PM »
You can sharpen most taps with an angle grinder. You just need to take enough metal off to reveal a sharp face.
Offline 21incher
« Reply #8 on: January 16, 2018, 07:16:26 PM »
I never thought it was that simple. I will have to try that on a box of dull ones I have. Thanks Dave. :)
Offline 21incher
« Reply #9 on: January 25, 2018, 03:47:04 PM »
 Ordered some good maple dowels from Beall and made 18- 12 inch threaded rods that all came out perfect with no chipping. Made 70 walnut hex nuts and the tap is still sharp. This thing works great. Just have to get a flap sander now to sand the nuts. 8) 8)
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #10 on: January 25, 2018, 04:05:35 PM »
Those look really nice.
Offline samandothers
« Reply #11 on: January 28, 2018, 02:47:07 PM »
Look forward to seeing them in a project!
Offline 21incher
« Reply #12 on: February 07, 2018, 02:24:48 PM »
Here is a pic of the project start. I am making a new bedroom set for my guest room and trying to make it have an industrial / gearhead look. This is the start of the headboard. The tables, shelves and everything else will have a similar look when it is all done. Have to learn how to spray poly next so I can get a decent finish. :)
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #13 on: February 07, 2018, 02:45:54 PM »
That is super sweet. I really like that. Keeping it natural not paint?
you can make some pretty killer adjustable shelving with that :)
Drill and tap the ceiling then run your shelves ceiling to floor.
« Reply #14 on: February 07, 2018, 03:04:50 PM »
Wow!  Ask and he shall receive!  Very neat design.  The contrasting wood is really sharp looking.
Offline SlowJoeCrow
« Reply #15 on: February 08, 2018, 12:21:19 PM »
Nice, I really like the design as well!
Offline 21incher
« Reply #16 on: February 09, 2018, 02:34:01 PM »
Thanks .
I have simple adjustable shelves sketched up for the nicknacs. The top shelf will be anchored to the studs using the kreg jig and the threaded dowels will hang down from them. Have to order another batch of dowels and make a power feeder for the jig to make it easy to cut the threads on a 4 ft dowel. Also have to figure out the clearance needed for polyurethane and cut the threads deeper so the nuts will still move freely.  A fun project using backyard wood. :)
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #17 on: February 09, 2018, 03:58:55 PM »
I bet you can make a jig that will go into the chuck of your cordless drill. Put it on low and feed er through.
Offline 21incher
« Reply #18 on: February 11, 2018, 11:22:01 AM »
It would be easy if there was a way to lock a drill at about 20 rpm that seems to make the cleanest threads. I am thinking a old gear motor may work best. :)
Offline 21incher
« Reply #19 on: February 16, 2018, 07:05:54 PM »
A couple videos of the build.
Making the nuts and bolts.
Making The Headboard.  This one didn't end to well.
I hate finishing. smiley_dwarf_finished_chair
A thread on wood threading
Started by purple otter on General Woodworking
Last post April 04, 2013, 09:00:27 AM
by SwampDonkey
Large wood threading kits.
Started by Dave Shepard on General Woodworking
Last post May 16, 2019, 10:49:14 PM
by Dave Shepard
question
Problems threading a rod...
Started by Paschale on General Board
Last post September 08, 2008, 12:13:38 AM
by Paschale
Belsaw arbor threading die
Started by b dukes on Sawmills and Milling
Last post October 22, 2012, 01:11:36 AM
by bigred1951
