Author Topic: Woodmizer LT35HD Pulley  (Read 632 times)
Offline Rhodemont
  • Logging and milling just a hobby
« on: January 15, 2018, 08:18:21 AM »
The spring loaded tension pulley for drive belt let go.  The pulley inner bearing that fits onto the shaft disintegrated and took out the belt with it.  The mill is two years old with couple hundred hours.  Thought I have had the tension set correctly. While this could have been a sudden failure I am thinking it would take a while for it to wear and let go.  Any thoughts on what might have happen?
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline millwright
Re: Woodmizer LT35HD Pulley
« Reply #1 on: January 15, 2018, 09:01:57 AM »
Mine failed at about 50 hours, after it was replaced no further problems. You should use a belt tension gauge when you install the new belt
Offline John S
« Reply #2 on: January 15, 2018, 10:33:18 AM »
For a few years now, I believe that WM provides the belt tension gauge with all mills.
2018 LT40HDG38 Wide
Offline Mt406
« Reply #3 on: January 15, 2018, 12:11:30 PM »
Mine blew up at around 100 hrs. and took the belt out.  :'(
Had some smoldering saw dust from hot parts flying around.
I now have 350 hrs and alls well.
Belt tension gauge came with mill.
Its a must or over tension will cause bearing failer or possible broken crank.
WM was good with warranty on parts for me.
Scott
Offline Rhodemont
« Reply #4 on: January 15, 2018, 02:59:44 PM »
Parts are on the way under warranty.  Mill did come with tension gauge.  I did check it at 25 hrs as recommended and then couple other times.
Had not run the mill for couple weeks with the cold we have had.  Mt406 & millwright, did yours let go in cold weather.  With the shaft being a shoulder bolt the tolerance is probably not that high so maybe bearing contracted tight onto bolt with the cold.
Offline millwright
« Reply #5 on: January 15, 2018, 03:24:05 PM »
I didn't get a gauge with mine, had to by one  it was early fall when it failed, so not too cold  I've sawed well over 100,000 bd ft with no problems with the pulley.
Woodmizer LT35hd
Started by MReinemann on Sawmills and Milling
Last post September 05, 2012, 05:58:24 PM
by MReinemann
Woodmizer LT35HD Setworks
Started by WoodyMcSander on Sawmills and Milling
Last post July 05, 2019, 10:38:57 AM
by millwright
woodmizer LT40HD vs. LT35HD
Started by mjancius on Sawmills and Milling
Last post April 30, 2015, 12:29:40 PM
by isawlogs
Woodmizer LT35HD inconsistent thickness end to end
Started by bhraymer on Sawmills and Milling
Last post October 23, 2018, 09:28:29 AM
by Stephen1
