Author Topic: Sequence of sawing  (Read 4654 times)
Offline appleseedtree
  • Howdy
Sequence of sawing
« on: January 17, 2018, 09:04:40 PM »
Hello Forum. Iím a pro arborist but a rookie sawyer. Iíve bought an old LT40 non hydraulic and so far just completed one project sawing 5 small locust logs. My current project is on the mill, an 18í x 36Ē pine log. Iíve been around it once to trim it up and Iíve  taken a few 1Ē boards off of it.   One of the most perplexing things to me is knowing when to saw another board off the top and when to roll the log. Itís currently a 25 x 26Ē cant with rounded corners. Iím looking to get as many 2 x 12s as it will yield. I thought Iíd make a couple of 12Ē wide cants and then make the boards. The top and bottom boards would have lots of wane but I guess I could trim that off. Question is, can I set the two 12Ē wide cants side by side and saw both of them at the same time or is it better to saw them one at a time?  Not sure if the guides would even allow a 24Ē cut.
Advice appreciated
Offline ncsawyer
Re: Sequence of sawing
« Reply #1 on: January 17, 2018, 09:36:02 PM »
In my experience, when sawing your log down to the desired cant size, you want to end up with a cant that has equal amounts of sap wood on either side of the pith.  The sap wood is stronger than the heart wood, and boards tend to warp "toward" the sap wood or away from the pith, if that makes sense.
So on a 12 inch cant, you would want to mill flitches off of the top of the log until you get down to about 6 inches from the pith, then flip over and mill flitches off of the log until you get down to the 12 inch cant, resulting in a 12 inch cant with about 6 inches of sap wood on both sides of the pith.  This gives you the most stable cant, assuming the pith is centered in the log, and your lumber should stay good and straight.
You mentioned sawing two 12 inch cants from your large log.  This will probably result in splitting the pith or at least yield "lop sided" cants with significantly more sap wood on one side of the pith than the other. In this situation you will probably observe the cants "curling away" from each other as you split your 24 inch cant into two 12 inch cants.  If this happens, all of your 2x12's will have a bow in them.
The best approach, in my opinion, is to cut 2 inch fliches off the sides of the log until you have one 12 inch cant with the pith centered.  Resaw flitches into 2x12s and mill 2x12s from the cant. You will will end up with about the same yield as two 12 inch cants, but much higher quality lumber.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: January 17, 2018, 09:45:05 PM »
Absolutely and very well described ncsawyer.   smiley_thumbsup
I always determine my target cant before I make the first face opening.  It's kinda like looking at a road map before you leave home because it's good to know where you are going before you leave.
I will also echo the statement about "never splitting the pith".  It should be centered within the targeted cant.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: January 17, 2018, 10:17:12 PM »
   Well described by NC and MM. Yes you can often cut multiple cants at the same time when cutting the same thickness lumber but that is usually when cutting something like 2X4s or 2X6s or such.
    You will still get plenty of 2X12s off the side lumber before getting your 12" cant. The total yield will not be significantly different but cutting 2-12" cants and splitting the pith would sure give you lower quality results which you don't want.
   Good luck and welcome to the FF.
  • Howdy
« Reply #4 on: January 18, 2018, 07:55:22 AM »
Wow. Thanks for that. I was really unsure until I read your posts and Iíll definitely heed the advice. I figure after sawing a few dozen thousand bf Iíll know more!  At this point trying to avoid the big mistakes and get some usable lumber in the process.  And I have to say, between  calling the dealer for tech advice, speaking to friends, and researching the internet including you tube, I always end up at Forestry Forum for the best advice!
Thanks to all the contributors and sponsors!
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #5 on: January 18, 2018, 08:13:26 AM »
Agree about taking a 12" cant across the center and sawing that into 12" wide boards.
Just a slightly different way of saying things in case it is helpful.
Another way to think about your question of how to saw is to produce boards with the figure balanced in the width.  When you look at the grain pattern it is balanced from the center out to each side, the grain pattern is not cut down the middle.
But you'll have a lot of wide boards above and below it so what to do if you want 12" not 24" out of them.  Best performance for the 12" is to take a 12: out of the center of them and leave 6" on either side.  You'll need to decide how bad you want all 12's or fewer better performing ones.
I usually clean up the log like you say(often then putting on a fresh blade) and then cut deep for example 6" x 24 off of either face to leave the 12" cant.  Then come back to the 6x24's and cut a 12 out of the center and then cut this into 2x12s. This limits the wide sawing to 2 wide cuts in clean wood with a fresh blade in what will be the edges of the main 12" cant.
Cutting wide with no waves is demanding on sharpness of blade. This goes to your question of whether to cut two wide cants side by side. I would never do this with 2 12" cants even if I had two of them on the mill.   Myself I only do this if the two cants are narrow say 6"+ 6", not too tall,  and don't need individual treatment because of having a bit of bow or something else, for example.  Cutting 12's one at a time rather than 24's you can go faster and expect flat cuts with less care.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: January 18, 2018, 08:47:22 AM »
Since I do not sell/market lumber my setup is always geared toward the customer's cut list.  I have learned to not be concerned with whether I could have maybe squeezed another board out of the log.  I am better off setting my cant targets based on the cut list.
Offline moodnacreek
  • Sawin by the notches
« Reply #7 on: January 18, 2018, 09:01:30 AM »
All good advice. Trying to keep the heart centered even when it's not there is the thing. On soft, straight or short ,fat pines you may be able to cheat and go faster as you will see.
Online samandothers
« Reply #8 on: January 18, 2018, 10:02:26 AM »
Your questions have been covered.  I just wanted to say welcome!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: January 18, 2018, 10:18:02 AM »
Centering the pith can be quite elusive when sawing off center logs so you have to remember which center is important.  This illustration is what is regularly encountered when sawing SYP.  :)
This is a badly off centered log so I turned it so that it was centered horizontally.  The red chalk is for reference for the pictures.  I was illustrating how I determined my target cant.
Here I have made my opening face cut and taken two slabs to reach my target.  The slabs will be edged to the cut list.
Turned 90į and sawed down to the red line on the right which is my cant target.
Again turned 90į and slabs removed to reach my cant target which is then sawed into three 3 5/8" cants.  Notice that the pith is centered within the center cant.  This was not by accident.
Turned the final 90į and the "saw through" begins.  Notice what happened to that original off centered pith.   ;D
Offline pineywoods
« Reply #10 on: January 18, 2018, 11:20:37 AM »
What's not so obvious but very important in Magic's demonstration is yield. I count 21 cuts through the log, for which he gets 36 dimension boards plus 6 slabs which will yield another 8 or 9 boards in as many cuts. approximately 45 pieces in 30 cuts.
Explains why MM has cut over a million board feet and turns out more lumber in a day's sawing than I can in 3 days.
Offline firefighter ontheside
  • I like trees.
« Reply #11 on: January 18, 2018, 11:33:29 AM »
Welcome Appleseed.  Iíve been a member a few years, but have only had my mill for a few months.  I have not cut a thing on it yet.  Still getting it set up.
I have several great big yellow pine logs ready to be cut and am happy you asked this question.
Thanks Magicman for the great pictures.  Iím planning to mainly take 6x6ís out of my logs, but I will follow your planning and cut process.  Iíve saved the series of pictures.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
  • Howdy
« Reply #12 on: January 18, 2018, 11:45:02 PM »
Magic, so it looks like youíve only rolled the log 3 times  and you leave the slabs in place while you saw the next one until youíre ready to roll again. Thatís great to see, as I thought Iíd get a reward for the most rolls to get the fewest boards out!  It appears that you are focused on most board feet for the least amount of effort.
Is that actually red chalk or a lumber crayon?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #13 on: January 19, 2018, 07:19:29 AM »
Yes three turns but the slabs were left on each time for picture illustrations.  Lumber crayon.
Offline Sixacresand
  • John and Nancy
« Reply #14 on: January 19, 2018, 12:21:28 PM »
I have been bit many times by milling a cant down to a desired width, only to have an ugly waves in the cant or bent boards  My policy is to mill cants down to approx 1 inch oversize, mill my boards, then edge, trim off any defects a few boards at a time.  It takes a lot more time and wastes material, but I like straight, uniform lumber.  Customer do not like to hear "turn the hump side up"..
« Reply #15 on: January 19, 2018, 01:18:09 PM »
 Iím guessing Magicman having sawn so many SYP logs like that, knows that this one is  clean and will give it a flat cut the way he is doing it. For example, in the next of the last photo above. I would do the same with a sharp blade on if I knew that that whole side was clean but thatís not usually the case for me, I will turn it before I make all those wide cuts and take off the top so that when I make the wide cuts I am cutting into clean wood only. And with a sharp blade.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #16 on: January 19, 2018, 01:50:00 PM »
Welcome to the forum appleseedtree!  I've learn a whole lot from the folk who have already responded. I've also learned quite a bit the hard way when I didn't follow their advice.  For example, here is why you don't want to split the pith.
1992 LT40HD
Offline Georgia088
  • New to all things sawmill
« Reply #17 on: January 19, 2018, 02:07:52 PM »
So, MM, you have (3) 3-5/8 cants.  So before you made the two cuts to give you 3-5/8s how large was the cant? 10-7/8s?  I know 3 times 3-5/8ths is 10-7/8ths, but do you allow for the saw blade? for instance an 1/8th per cut? So it would actually need to be 11-1/8?  I'm just curious as to how you figure that.  It never seems to come out exact for me.  It seems wherever I allow for the saw blade it needs to be on the other side lol
Thanks!
  • Howdy
« Reply #18 on: January 19, 2018, 06:36:54 PM »
Hey Darrel, I love those photos of the long boards. Looks like great boat lumber. Now I really get it. Donít split the pith! And regarding kerf, 1/8Ē seems to be a generous plenty to my inexperienced eye, Iíd like to hear what others figure. And by the way, Iíve sawed a fair amount on someone elseís old Mobile Dimension circle mill and I would figure 3/8Ē kerf to be on the safe side. Youíd lose one board to sawdust for every 3 boards sawed!
Offline LeeB
« Reply #19 on: January 20, 2018, 02:02:44 AM »
An 1/8" for kerf is pretty close but really depends on your blade thickness, set and a few other factors. I use an 1/8" and it works fine for me.
Sawing sequence 90 or 180?
Started by Kwill on Sawmills and Milling
Last post February 19, 2019, 07:10:11 PM
by Escavader
Bizarre sequence of events
Started by sawguy21 on General Board
Last post September 02, 2015, 06:38:23 PM
by PC-Urban-Sawyer
Compression test sequence
Started by aldo on Chainsaws
Last post April 27, 2011, 07:16:26 AM
by aldo
grinding sequence thoughts
Started by coastlogger on Sawmills and Milling
Last post February 02, 2015, 11:24:02 AM
by uler3161
