Author Topic: My DIY bandsaw mill  (Read 6251 times)
Offline Hilltop366
Re: My DIY bandsaw mill
« Reply #20 on: February 04, 2018, 11:03:36 AM »
How much do cam wheels cost? might be worth it to buy them?
If you use a profile shaped cbn wheel you would only need a up/down cam but it would require a different wheel for each blade profile and a cooling system.
Offline longframe200
« Reply #21 on: February 04, 2018, 11:28:50 AM »
Thank you, but the machine should be able to be adjusted to different tooth profiles.
“I have never let my schooling interfere with my education.”  “A lie can travel half way around the world while the truth is putting on its shoes.”  “It's easier to fool people than to convince them that they have been fooled.”  - Mark Twain
« Reply #22 on: February 05, 2018, 10:45:30 AM »
After a night of searching on internet, I found this cam wheel shape, after I compared to images on factory produced sharpening machine, I think it should work really well.
Re: DIY bandsaw mill 1.5 inch blade on B profile belt
« Reply #23 on: February 14, 2018, 10:11:58 AM »
I wonder if anyone can tell me if it is possible to run a 1.5 inch band saw blade on B profile belt?
Thanks in advance.
Offline Sawmill Man
« Reply #24 on: February 14, 2018, 05:14:06 PM »
Yes you can run a 1.5 inch blade on a b series belt.
"I could have sworn I went over that one with the metal detector".
« Reply #25 on: February 15, 2018, 02:53:22 AM »
Thank you!
« Reply #26 on: February 19, 2018, 12:08:04 PM »
Well this is it, built on what was on the shelf. the grinding wheel is on its way. Now missing only support for the saw band, some color and to see if it can sharpen a saw band of course. This was fun :) Probably will I build a more "professional" machine later.
Thank you
DIY bandsaw mill
« Reply #27 on: February 28, 2018, 01:55:49 AM »
Now is the machine tested, it works over all expectation, I had to reshape the cam wheel a bit for it to work properly. The disc is not balanced, but the vibration is minimal. The blade I was grinding actually went from sharp to sharper, It was new and unused, bought the cheapest I could find. It also had different measurements between the teeth, probably is the tooth setting not particularly carefully done either. When I tested the sawmill (same type of blade) were there a lot of “scratches” on the boards.
I built it with inspiration from here and youtube.
Thank you!
Next may be a tooth setting device.
slip2 - YouTube
« Reply #28 on: March 19, 2018, 12:07:20 PM »
Easy to manufacture, simple and functional. If it will "set" the teeth accurate remains to be seen.
Built with inspiration from here and youtube.
Thank you!
Offline Otl
  • Member*
« Reply #29 on: March 19, 2018, 12:21:17 PM »
New guy on the block, building my sawmill and need to know the best pulley to use as the driver for blade pulley(zinc,aluminium, cast iron. Thanks
Offline york
« Reply #30 on: March 19, 2018, 01:01:49 PM »
OTL,Welcome,but how about starting your own thread???
Please keep your build all in one thread,so the body can follow you and be of help....
Albert
« Reply #31 on: March 20, 2018, 05:16:58 AM »
I would use cast iron, but try a search, the forum is full with knowledge on the subject.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #32 on: March 20, 2018, 08:48:01 AM »
cast iron X 2
Love machine shop work
and Wood work shop work
And now a saw mill work
« Reply #33 on: April 23, 2018, 05:25:35 PM »
The snow is almost gone and the saw has been tested. I promised to make a movie, it can be viewed here. Video - norasagen800.simplesite.com
Offline ljohnsaw
« Reply #34 on: April 23, 2018, 09:09:17 PM »
Very nice! 8) Isn't it great when all your hard work works out?
The only improvement that I would do is put a angled deflector on your sawdust shoot to get the dust to hit the ground near the mill instead of shooting so far out.
John Sawicky
« Reply #35 on: April 24, 2018, 04:10:15 AM »
Thank you! Yes it certainly is :) And yes an angled deflector is needed :)
« Reply #36 on: March 04, 2019, 03:55:40 AM »
First log in this year's sawmill :)
« Reply #37 on: March 04, 2019, 03:58:56 AM »
And this year's grinding machine.
Offline bwstout
« Reply #38 on: March 04, 2019, 08:02:26 AM »
outstand build I used the same plans to build my mill as you made some changes. Still have not built a sharpener just having hard time getting it all in my head at my age have lots of issue getting thing settled in my head ;D
home built mill
« Reply #39 on: March 05, 2019, 03:28:33 AM »
Thank you very much and yes, Ben's plans are very good and at a reasonable price.
Which basic mill is faster - bandsaw or swing mill?
Started by 54Dutchman on Sawmills and Milling
Last post March 18, 2012, 09:37:14 PM
by Okrafarmer
$5,000-8,000 Best Value Bandsaw Mill
Started by Mcgeezer on Sawmills and Milling
Last post December 03, 2017, 09:41:12 AM
by rasman57
What, how and where is your first cut with a bandsaw mill
Started by rasorbackQ on Sawmills and Milling
Last post August 16, 2013, 10:01:59 AM
by dboyt
Looking to buy a Bandsaw Mill
Started by customcutter01 on Sawmills and Milling
Last post November 19, 2017, 10:42:13 PM
by customcutter01
