Author Topic: False Log Corners  (Read 650 times)
Offline Dewey
False Log Corners
« on: January 18, 2018, 08:15:46 PM »
I have the chance to get a job supplying 2x6 Log siding... The customer wants false log corners...  What is the easiest way to make them....  I assume they will be cut out of a 6x6...  But how vertical Band saw ??
Offline Jeff
  • Fearless Leader
  • I intend to live forever ... So far, so good.
    • THEE Forestry Forum
Re: False Log Corners
« Reply #1 on: January 18, 2018, 08:25:35 PM »
First I put the log up on saw horses and decided which part of the log was the best area to remove.  I then used a level to create vehicle lines on each end of the log, then uses a framing square to layout the 90 to be removed.  We then used a chalk line to snap from one end of the log to the other to get the two straight layout lines along the length as straight as we could. Because of the undulations of the log, the line will be hit and miss, but you get enough to be able to follow it straight.
Once we had the lines laid out, we used a skill saw to score the lines as deep and as straight as possible.  I then set the blade at a 45, move in from the line about an inch, and cut again, taking a "V" out the length of the log. Do this for both cuts.  Now comes the chainsaw.  You have that straight line, and with the "V" of wood taken out, you can now get in there with the chainsaw to remove the rest of the wood without muffing up your nice straight lines.  Its actually better if you remove too much wood, because the corner will fit right tight to the corner of the house that way.
(Image hidden from quote, click to view.)(Image hidden from quote, click to view.)
Offline Dewey
« Reply #2 on: January 18, 2018, 08:45:37 PM »
I guess I wasn't clear enough... although your pics and explanation was.... Thanks jeff
I need to make horizontal false logs If I new how to draw on here I would....
There is going to be one false log for each course of siding...
Offline Don P
    • Calculator Index
« Reply #3 on: January 18, 2018, 10:32:53 PM »
Like so?
Offline Dewey
« Reply #4 on: January 19, 2018, 08:06:24 AM »
Yes....
Offline Dewey
« Reply #5 on: January 19, 2018, 08:07:49 AM »
I'm thinking Bandsaw for long cut and Radial Arm saw for the crosscut.... I guess some jigs would need to be made...
Offline Don P
    • Calculator Index
« Reply #6 on: January 19, 2018, 08:13:46 AM »
That would work. The crosscut there was 4" deep, we did it with a 16" skillsaw, not sure if a radial arm would do that. If you index the rip with the flat side down on the bandmill it should work. Maybe a bump stop for both the end of the log to locate it and then one to limit carriage travel. These were done on the job so skillsaws and sawzall.
Offline Dewey
« Reply #7 on: January 19, 2018, 12:49:01 PM »
Hmmm....  Wasn't thinking of using mill  but if I can clamp it well enough that may work....
I have a 20 " Dewalt Radial Arm Saw
Log Corners
Started by iffy on Timber Framing/Log construction
Last post August 13, 2010, 10:23:35 PM
by Jeff
Cuttin' Corners
Started by mikedurland on Sawmills and Milling
Last post July 17, 2012, 02:16:55 PM
by redbeard
Red (false morel) mushrooms
Started by Bibbyman on FOOD! FOOD! FOOD!
Last post May 02, 2013, 08:40:32 PM
by mesquite buckeye
Carbon sequestion -true or false
Started by jim king on Ask The Forester
Last post July 24, 2010, 06:52:46 PM
by BrandonTN
