Author Topic: Power upgrade to the mill  (Read 2975 times)
Offline Bruno of NH
Re: Power upgrade to the mill
« Reply #20 on: April 18, 2018, 02:53:31 PM »
Was making it's maiden cuts at 12:30 after a trip to the parts store for some gas line.
I don't know if it's the weight difference or it being a v-twin the mill vibrates much less.
It makes some smooth cuts
I can see how the added hp will be much better 8)
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline starmac
« Reply #21 on: April 18, 2018, 03:28:53 PM »
All else being equal, a twin cylinder will vibrate less than a single.
Online Darrel
  • Never throw an unopened log on the burn pile.
« Reply #22 on: April 18, 2018, 09:28:13 PM »
Now you've got yourself a mill you can't keep up with.  8) 8) 8)
1992 LT40HD
Offline Iwawoodwork
« Reply #23 on: April 18, 2018, 10:37:41 PM »
now you have enough power to add a double grove engine pulley to run an alt or small hyd pump for hydraulic add ons.
Offline Bruno of NH
« Reply #24 on: April 23, 2018, 12:08:33 PM »
So far I'm very impressed with the Predator engine.
It's been making some nice lumber :)
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #25 on: April 23, 2018, 12:14:53 PM »
Good,  8)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #26 on: April 23, 2018, 12:51:41 PM »
Mine runs good. but doesn't like to idle. and is a bit cold blooded (doesn't like the cold).
I knew what I thought I meant.
Offline Bruno of NH
« Reply #27 on: April 23, 2018, 05:37:57 PM »
Crusarius
In the cold I was told to cover the fan intake on the front.
Because it brings in to much cold air.
Offline Bruno of NH
« Reply #28 on: April 23, 2018, 05:44:11 PM »
The old 13hp wouldn't run 10 bands very well.
I have some but didn't use them much because of poor cuts in everything.
I grabbed some 10 and headed out to the mill today and put one on.
Nice cuts in some knotty pine
I couldn't believe it  :o
I'm still only going to buy 7 and 4 but I can use up the 10 I have.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #29 on: April 23, 2018, 07:18:51 PM »
It's good to read about your engine upgrade success Bruno.  8)
Offline fishfighter
« Reply #30 on: April 24, 2018, 07:29:04 AM »
Thanks for the up date. Does your mill use a clutch? If so, what make?
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #31 on: April 24, 2018, 07:32:57 AM »
Crusarius
Hmmm thats good to know. thanks. I may try that. Course its now in the 70's.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #32 on: April 24, 2018, 09:16:29 AM »
Crusarius
I now have a 25hp Kohler on my mill and it doesn't like the cold weather, so it doesn't run very well without covering part of the intake!
I use half of a Frisbee, just fasten it onto the grill with fine wire or zip ties!
~Chuck~
I LOVE MY SAWMILL
Offline Bruno of NH
« Reply #33 on: April 24, 2018, 05:02:43 PM »
Mr Fish
I didn't see any marking on the clutch.
It fits on the 1" keyed shaft and has a bolt that is 3/8 fine thread that holds the back plate on.
WoodMizer Power Feed Upgrade
Started by mhasel on Sawmills and Milling
Last post February 10, 2005, 09:06:09 PM
by mhasel
Best mill upgrade
Started by captain_crunch on Sawmills and Milling
Last post May 11, 2011, 10:42:33 PM
by laffs
mill upgrade
Started by jDal on Sawmills and Milling
Last post September 08, 2012, 11:02:06 AM
by Too Big To Fail
Best upgrade I can make to my mill
Started by DanMc on Sawmills and Milling
Last post November 10, 2017, 04:55:09 PM
by Magicman
