Author Topic: Pettibone master 5  (Read 3783 times)
Offline miketclew
Re: Pettibone master 5
« Reply #20 on: March 13, 2018, 05:28:02 PM »
Yah, there is a cradle pin on the front axle, and then standard centerpins for steering articulation. Back axles are fixed. I'm thoroughly impressed with this little machine. At roughly 7' 2" wide, and 14 feet long, it really gets around for thinning nicely. Working it right now in easily 16-20 inches of snow. We're in the process of getting another foot or two now.
Offline miketclew
« Reply #21 on: March 13, 2018, 05:40:38 PM »
Yes, Transmission R 1 2 3 on dash. Reverser on right hand side of seat. H/L on left hand side of seat.
Left foot clutch - Right foot brake and throttle. I'm trying to get an operators manual from Pettibone now. I have a parts repair/service for the machine, wisconsin v461/462/465 and gearmatic model 9. Would be nice to have them all :)
Offline starmac
« Reply #22 on: March 13, 2018, 07:43:57 PM »
That skidder actually has a V4 wisconsin in it?
Offline miketclew
« Reply #23 on: March 14, 2018, 07:00:43 AM »
Sure does. There were two engine options for this model/serial number. I'll attach the flyer that pettibone sent me for this machine.
Offline mike_belben
  • Pulp Friction
« Reply #24 on: March 14, 2018, 11:52:54 AM »
Is there room for a chevy 4.3?
Revelation 3:20
Offline miketclew
« Reply #25 on: March 14, 2018, 12:16:32 PM »
Not in my fuel budget there isn't :'(!!  It's fairly spacious in there, the biggest concern I have would be room for radiator. The wisconsin is air cooled.
I'm going to do my best to keep the wisconsin going, but have been thinking about re-powering with a diesel since prior to bringing it home.
A friend of mine has one that is diesel powered, I need to take a closer look at it. My uncle also owns one - I believe it's the same model. It's still parked in the woods where it was left 15 years ago :(
Offline buzzegray
« Reply #26 on: March 14, 2018, 03:30:15 PM »
Check CL , California, goldcountry. Pettibone 5. Five pictures.
Offline starmac
« Reply #27 on: March 14, 2018, 05:40:05 PM »
Couldn't find it on craigslist.
Offline 47sawdust
« Reply #28 on: March 14, 2018, 05:45:38 PM »
Mike, that Pettibone bulletin is really kool.I hope you enjoy the skidder as much as the goats do.
Mick
Offline starmac
« Reply #29 on: March 14, 2018, 06:11:42 PM »
Wow, it shows the 4 cy jimmy for the diesel option. I assume a 453, and they have it turning 2600 rpms, they wind that puppy up.
I have to wonder if a guy needed to swap out one of those wisconsins  for a diesel, how much trouble it would be to put an air cooled duetze in one.
Offline miketclew
« Reply #30 on: March 14, 2018, 06:14:19 PM »
Starmac, reading my mind (The duetz air cooled that is)! Not sure what the horse power options are. I figure 50-60 hp would be plenty from a diesel.
Offline starmac
« Reply #31 on: March 14, 2018, 06:50:16 PM »
I doubt the wisconsin puts out any more than that. I don't even know what the duetze is rated at, but guys that have them in skidders sure seem to like them.
Offline JesseA
« Reply #32 on: March 15, 2018, 01:08:59 AM »
The f3l912 deutz I have is 37 or 47 kw which is 49 or 63 hp.  Quiet, and easy on fuel.
The 4.3 in my rock junk is pretty reasonable on gas probably 5 or 6 gallons a day.  But Im usually chugging it around below 2000 rpm. If it was injected itd probably be better.
Offline starmac
« Reply #33 on: March 15, 2018, 03:39:55 AM »
I am thinking a 4.3 would have to be kept wound up to have the needed torque in a skidder, but I don't know what their torque is, so just guessing.
Offline JesseA
« Reply #34 on: March 15, 2018, 04:21:10 AM »
E
 Most of these came along in second gear, low range. 3.34 in the 4 speed, 2.62 in the transfer, 5.38s in the diffs chugging along at 12 or 1500 rpm.  Granted I was taking one at a time but still, most of those skidder axles are 20:1 between the diffs and the hubs
Offline mike_belben
  • Pulp Friction
« Reply #35 on: March 15, 2018, 09:57:43 AM »
4.3 is a fairly torquey engine.  Another cheap reliable piece would be a ford straight six but room might not be available.
For cheap diesels, if you cant find or cant justify the premium expense of detroit/duetz/cummins stuff..  id consider a mercedes om617 from the 240D and 300D cars.  Theyre 3.0 inline 5 turbos with a bosch MW pump.  Very good engine.
Revelation 3:20
Offline miketclew
« Reply #36 on: March 15, 2018, 10:02:11 AM »
The f3l912 deutz sounds perfect!!!
Can you post some pics of the deutz ?
Offline JesseA
« Reply #37 on: March 15, 2018, 03:09:46 PM »
I grabbed these pictures off the internet, my Deutz is buried in a friends shop.
Offline JesseA
« Reply #38 on: March 15, 2018, 03:25:58 PM »
Quick search says 44kw which converts to 59 hp and 201 kg which converts to 639 lbs.  that seems high because I can shuffle mine around on the shop floor ok.
Chapman services over in Troy might have one if you want to put a tape measure to one.
Offline mike_belben
  • Pulp Friction
« Reply #39 on: March 15, 2018, 07:21:38 PM »
I got $2500 for a 4cyl version.  Theyre right up there with 4BT pricing.
Revelation 3:20
pettibone master 15?
Started by coxy on Forestry and Logging
Last post March 12, 2013, 05:29:33 PM
by jocco
Pettibone master 6 info
Started by Pettimaster6 on Forestry and Logging
Last post November 23, 2016, 09:12:03 PM
by Pettimaster6
Pettibone Master 12D Skidder
Started by VTPettibone on Forestry and Logging
Last post February 02, 2014, 11:21:03 PM
by coxy
moved
MOVED: Pettibone master 6 info
Started by chet on Chainsaws
Last post November 24, 2016, 08:41:02 PM
by chet
