Author Topic: Small pop up window  (Read 569 times)
Offline vfauto
  • TimberKing 2000
Small pop up window
« on: January 26, 2018, 08:05:46 AM »
At some point in the past a feature started that I do not like. When scrolling through post with I-pad if I touch a post a small window pops open with a abbreviated post and the only way to get rid of it is to hit the back arrow all the way back. Any help would be appreciated.
The definition of insanity is to do the same things over and over and expect a different result!
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Small pop up window
« Reply #1 on: January 27, 2018, 11:14:27 AM »
You touch the link again and it should go away.   Can't help you with apple products, as I know nothing.  To remove the feature, it needs to be removed for everyone. I've got no problem doing that if there is a consensus that it it an unused function that people could care less if it was gone.
Small AC window unit
Started by Chris J on General Board
Last post June 23, 2005, 01:00:58 PM
by Chris J
Through the window
Started by Tom on The Outdoor Board
Last post June 05, 2011, 08:47:43 PM
by Onthesauk
window fan
Started by bedway on General Board
Last post July 24, 2008, 03:12:46 PM
by rebocardo
window 8.1
Started by xlogger on Technical Support Topics
Last post November 04, 2013, 01:43:33 PM
by Ianab
