Author Topic: Maple Syrup 2018  (Read 23018 times)
Offline millwright
Re: Maple Syrup 2018
« Reply #140 on: March 21, 2018, 06:52:23 PM »
Itís been too cold here in northern WI , had a couple good runs but then it shut down again. Hoping for some in the next few days
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #141 on: March 21, 2018, 07:14:23 PM »
  Zach's good at finding leaks 8)  When we first turned on the pump we only had 15".  There were some entrances leaking, missed taps(spiles hanging open), some squirrel chews etc.  We'll listen for air coming into the  collection tube and work up the wet/dry from there checking the valves for the mains listening for air while closing them and working out from there.  Sunday around noon we noticed a drop in vacuum and found a couple loose spiles and entrances that needed adjusting.  It's never ending ;D :)  27" is max for this pump.  That's what it'll do dead headed :)
  I thought it might loosen up a bit here this afternoon and planned to turn the pump on but when I checked at 1PM and again at 4 there wasn't even a drip coming in.  Should be some tomorrow.  I think we might have enough to run Friday evening.  Saturday for sure.  But the forecast may very well change in the next couple hours ::) ;D :D
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #142 on: March 22, 2018, 07:22:44 AM »
We are forecast to get up to 38į by 2:30 or 3:00 today, so we should at least get a small run today!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Mapleman
« Reply #143 on: March 22, 2018, 07:41:41 AM »
Things are still frozen up here, we haven't had a run for almost two weeks.  Some of the warmer trees have seeped a little, just enough to fill the mainlines in the cold spots and freeze, so no sap is going to get through them until it warms up into the 40's.  And the ice has been pushing fittings apart here and there, once it runs we'll have to spend some time and a lot of energy in the deep snow (we got almost 5 feet here in the three recent storms) getting the leaks fixed.  Oh well, such is sugaring - we had a great start and we're paying for it now!  The weather next week looks ideal....
"The older I get, the better I used to be."
Offline Chuck White
« Reply #144 on: March 22, 2018, 03:10:37 PM »
Sap has been running "a little" here today, but not enough to gather!
We'll be gathering sometime shortly after noon tomorrow!
We do have a few barrels that are 1/3 to 1/2 full right now, but they'll wait until tomorrow!
Yes, definitely, next week looks good!
~Chuck~
Online Corley5
    • Whittaker Farms
« Reply #145 on: March 22, 2018, 04:17:10 PM »
  I clicked the vacuum on today about 1.  It was running a bit.  Releaser had cycled twice.  I don't expect much.  It's not very warm and is supposed to be colder tomorrow.  They've backed our highs off for the weekend too.  Look like a couple nights next week won't freeze.
Online Corley5
    • Whittaker Farms
« Reply #146 on: March 22, 2018, 07:26:47 PM »
We've pumped about a 150 gallons so far.  Pretty surprising for as cold as it is.  I'll go over and shut the vacuum off around 9.
Offline Chuck White
« Reply #147 on: March 22, 2018, 09:41:01 PM »
We are projected to reach 45į or so tomorrow, so, we'll be gathering sap!
~Chuck~
Online Corley5
    • Whittaker Farms
« Reply #148 on: March 23, 2018, 09:07:03 AM »
  We ended up with close to two hundred gallons yesterday.  34 today, 32 tomorrow and 38 Sunday with sun all three days.  I think by Sunday afternoon we'll be able to run the evaporator.  Monday 47 and sunny 8) 8)  After Monday it doesn't freeze up for a couple nights.  Thursday will be the next day.  The forecasts change hourly ::) :)
  Anyone have any experience with the wireless tubing system monitors?
Offline Chuck White
« Reply #149 on: March 23, 2018, 04:17:53 PM »
Well, today we gathered 450 gallons of sap, ran it through the RO, then boiled!
Keep in mind that our evaporator was dry!
In the end, we made 3 gallons of syrup, and now our pans are flooded!
The sap is still running, so we'll have more tomorrow!
~Chuck~
Online Corley5
    • Whittaker Farms
« Reply #150 on: March 23, 2018, 09:40:13 PM »
Pumped about 150 gallons today for a total of 300 or so gallons on hand.  Surprised it ran that much.  Tomorrow's weather is to be about the same.  I'd like about 500 gallons before we fire up.
Offline Chuck White
« Reply #151 on: March 24, 2018, 06:58:30 AM »
We'll likely get around 350 gallons or so today, but most likely it's what ran late yesterday!
We're only projected to get up to 30į today!
~Chuck~
Offline Ed_K
  • Leave it better than you found it. Ed_K
« Reply #152 on: March 24, 2018, 07:42:40 AM »
 Only had enough sap for a quick boil yesterday so I put it off and worked on the skidder winch again  >:( . I'll start boiling today at 9 this morning for a long day of boiling ;) . The way the saps been running around here it'll be an every other day boil 8).
Offline maple flats
  • Life is what you make it!
« Reply #153 on: March 24, 2018, 12:03:48 PM »
Update on my situation. Since I have surgery coming on 4/18 and because of the cancer delaying everything, I only tapped 225 at the sugarhouse (Unlike Glen Goodrich who will eventually have about 200,000 taps all direct to the sugarhouse). That includes some trees that have never been tapped before. Since the tapping was finished the weather has been so cold that I've only gotten a little sap. I hauled one load to a friend to boil because it was not enough to run the RO and start a boil. Today I'll get a little, temps going up to 36-37F, tomorrow everything should run and I will finally have my first boil. Yesterday it got to 37 but I only got 100 gal, most areas never thawed until late in the day. Shortly I'm headed down to check for leaks and maybe my first boil, more likely tomorrow. From here on our forecast looks like maple weather for 10 days at least.
logging small time for years but just learning how,  2012 36 HP Mahindra tractor, 3point log arch, 8000# class excavator, lifts 2500# and sets logs on mill precisely where needed,  Peterson ATS upgraded to WPF mill, maple syrup a hobby that consumes my time. looking to learn blacksmithing.
Offline Chuck White
« Reply #154 on: March 24, 2018, 04:47:33 PM »
Good to hear from you, Dave, glad to hear you're getting into it a little!
We gathered 630 gallons today, RO'ed it and boiled, drew off 22Ĺ gallons of syrup!
After we got done yesterday, before feezeup it really kicked off, many of our barrels were running over!
The barrels and lines were froze up and we just broke a hole through the ice and pumped the sap out!
~Chuck~
Offline cbla
« Reply #155 on: March 26, 2018, 06:07:52 AM »
been too cold here for the last week to get a run, but the next week looks good.
Offline Chuck White
« Reply #156 on: March 26, 2018, 06:53:15 AM »
We should get a little sap today, it got into the low 40's yesterday!
It should reach into the upper 40's today, and Tue, Wed & Thu it's not even supposed to get below freezing!  Could run 24 hours on all three days!  8)
~Chuck~
Offline Chuck White
« Reply #157 on: March 26, 2018, 08:42:20 PM »
We gathered just over 400 gallons of sap this morning and boiled it down!
We got just a hair over 10 gallons of syrup, we are now a little over 200 gallons!  8)
Our last years total was 245 gallons!
Looks like we'll likely go over 300 gallons this year!  fingers crossed!
~Chuck~
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #158 on: March 27, 2018, 06:29:37 AM »
At $60.00 a gal that can be nice for the wallet. 8)
Offline Chuck White
« Reply #159 on: March 27, 2018, 06:46:19 AM »
Not even close to that, Peter!  ;)
But, ya, it would be nice!  ;D
~Chuck~
Maple syrup
Started by Norm on Wanted
Last post April 24, 2013, 09:04:23 AM
by Raider Bill
maple syrup
Started by L. Wakefield on General Board
Last post April 10, 2003, 06:11:20 PM
by L. Wakefield
Maple Syrup....
Started by Mr Mom on FOOD! FOOD! FOOD!
Last post March 24, 2009, 02:26:53 PM
by SwampDonkey
Maple Syrup!
Started by jrose1970 on General Board
Last post March 22, 2019, 06:36:45 PM
by Chuck White
