Author Topic: 3 point wood splitters  (Read 4172 times)
Offline Kwill
  • Cedar cutter
Re: 3 point wood splitters
« Reply #40 on: February 11, 2018, 02:24:48 PM »
Kwill,
Great idea,seems I would like to see the hyd.plumbing set-up.I take it the loader and the splitter each have their own reservoirs?
they run off the tractor sump
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Offline Ivan49
« Reply #41 on: February 11, 2018, 03:27:29 PM »
In 1972 I built one and at the time I used it on a JD 50.
Ivan, did you use the tractor hydraulics or a pto pump?
Tractor hydraulics and I used the control valve that is in the power troll. Just plug the lines in and use the handle beside the seat to work the cyl
Offline Randy88
« Reply #42 on: February 15, 2018, 09:35:09 PM »
Used a 3 pt splitter for years ran off hydraulics, can't recall it being slow at all, just hard on the back and lifting the blocks, then went to a unit mounted on the front of a skid loader, got tired of that as well, then cut the mounts off and flipped the splitter over and ran it on the skid steer that way, died and went to heaven, been that way for almost 14 years now, couldn't be happier, haven't lifted a block in 14 years, hardly ever handle anything by hand anymore except for tossing the blocks into the furnace.
I'd recommend a valve on the splitter, use a tie strap the hold the lever on the tractor engaged and should work fine.
Offline Woodcutter_Mo
« Reply #43 on: February 15, 2018, 09:58:51 PM »
 On this tractor, the aux lever detents for constant flow. The lever has 2 positions I believe it just changes the direction of flow between the 2 couplers. So this "should" work well with a separate control lever if I understand correctly. I've only used the aux hydraulics to raise and lower a haybine and it just has a single line.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline btd
« Reply #44 on: February 16, 2018, 06:13:18 AM »
Woodcutter_mo you are right, I put the "in" line in the top coupler and the "out" line in the bottom coupler on my kioti then just push the lever on the tractor forward and you should be good to go with a separate valve on your splitter.
Offline Bay Beagle
  • ~ FLATLANDER ~
« Reply #45 on: February 16, 2018, 08:01:45 AM »
BIG THANKS to Ya'll ....... I had made plans to order a "split-fire" splitter, to mount on my front loader - so it would be easy to place on the piles.  After reading a thread warning about exhaust fumes coming off the back of the tractor for three point splitters, I gave my front mount second thoughts.  (I have exhaust plumbed to the front of the tractor)   ..... so the Split - Fire md#3203 three point has been ordered - thanks again!!!
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #46 on: February 16, 2018, 12:23:36 PM »
A single line or a single pair?  You need a pair or you won't be able to get the cylinder to return.
Would work fine on a haybine or similar.  Pressure up and gravity down.
I would think you have a pair of connections.  Haven't seen a single connection on anything newer than an Allis D-14, but with newer imports... ???
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
« Reply #47 on: February 16, 2018, 01:39:18 PM »
 Sorry, I meant the haybine just used a single line so I haven't used both couplers at the same time. The tractor has 2 couplers
wood splitters
Started by dirtmod454 on Forestry and Logging
Last post September 07, 2010, 07:17:36 AM
by RSteiner
wood splitters
Started by OH logger on Firewood and Wood Heating
Last post March 11, 2016, 08:39:12 PM
by OH logger
Re: Wood Splitters
Started by AtLast on General Board
Last post March 17, 2004, 08:51:01 PM
by lamar
Wood Splitters
Started by mizerman on Firewood and Wood Heating
Last post January 27, 2019, 11:17:33 AM
by hedgerow
