Tally-I/O
Author Topic: Login difficulties  (Read 1995 times)
Offline lurk
    • TinyPortal
Re: Login difficulties
« Reply #20 on: February 11, 2018, 11:18:42 AM »
@lurk a little googling and I find that the xml parse error could be permissions related. SO, I changed the themes directory permissions from 777 to 775 and wallah!  The map stays loaded! However no pins load....
Actually, talking of themes, I noticed in IE11 this forum page no longer fits the screen and gives a horizontal scroll bar at the bottom.  Sure it wasn't like that before.
Also are you sure there's no js conflicts ajax or other?  Because it's strange how the map page loads and after a few seconds disappears.
Offline lurk
    • TinyPortal
« Reply #21 on: February 11, 2018, 11:26:05 AM »
This second page is ok, fits screen perfectly.
I now think it's a problem when you use the [code][/code] tags It breaks out of the side of the theme giving you the scroll bar at the bottom.
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #22 on: February 11, 2018, 01:33:33 PM »
It is the code links.   They wreak havoc. Long links too. And youtube embedded videos.    The Map. It worked perfectly until we switched servers. I am pretty certain it worked when I was testing after the moved as well. It quit working when I upgraded the forum software to 2.0.15. That is when all the login issues started as well
Offline lurk
    • TinyPortal
« Reply #23 on: February 11, 2018, 02:26:55 PM »
Login issues started with 2.0.14.  The latest SMF updates have caused havoc with many mods and themes to be honest, it's created a bit of a mess.  Not all mods, although they say compatible with SMF2, unfortunately some aren't even if the package parser says they are.  Because there's several code changes in SMF 2.0.14 up.
We only had to update our Tinyportal mod to cure the login fix, so we were quite lucky.
A couple of questions I'm curious about.  Isn't the portal you're using supposed to be responsive? And what mod do you use to embed YT video's ?
Online Jeff
  • Fearless Leader
« Reply #24 on: February 11, 2018, 02:43:25 PM »
Yes, ezportal is what I've used for ever now, and it is supposed to be responsive now. Well, I guess I don't know if it is responsive or not, only that you can choose to hide or view blocks depending for mobile or desktop.
The embed mod is the "simple audio video embedder".  I have been in search of a substitute, but have not found anything.  I know full well you can embed a video that is responsive putting the iframe in <div> tags and use css, as I have done it on other websites I work on, but it is a manual process, not an automated one that we need here. I'm guessing it would have to be done with javascripting, I don't think pure css can so it.
Offline lurk
    • TinyPortal
« Reply #25 on: February 11, 2018, 03:05:36 PM »
Thanks, yes I see your banner adds at the top must be running independently to the portal, that's what's throwing the theme out when I zoom in. They don't resize to given space.  Are you running them in some kind of random images script?
Video's, I think, Ohara YouTube Embed is the one I use, it's responsive providing you're using a responsive theme.
Online Jeff
  • Fearless Leader
« Reply #26 on: February 11, 2018, 03:10:00 PM »
Yes, some of them are running random image scripts.  Send me a PM about your portal. I've never used it and really never knew about it.  I'm wondering if you can sell me on switching :D   I know this system, but if I can change to something better without having a stroke, I'd do it.
Offline lurk
    • TinyPortal
« Reply #27 on: February 11, 2018, 03:36:38 PM »
Jeff, do have a test site, either live or local that you could try it on.  I don't think the portal is causing your layout problem, more the way the banners are added I guess.  Not that I'm good with responsive stuff.  I'll shoot you a pm.
Online Jeff
  • Fearless Leader
« Reply #28 on: February 11, 2018, 03:40:39 PM »
On mine, all the banners resize using max-width style attributes, unless I missed one.    They seem to resize on anything I have here.
Offline lurk
    • TinyPortal
« Reply #29 on: February 11, 2018, 04:08:21 PM »
You're right.  I was testing in IE11, which is why I'm not seeing it..
Online Jeff
  • Fearless Leader
« Reply #30 on: February 11, 2018, 04:13:38 PM »
I've been getting to a point as I get older, that I gotta know when to say when. Trying to please every stinkin browser can really get to a guy that knows not much of anything about coding other than what I pick up by looking at source code. :D  So, I try to do the best I can for most, and for some, OH WELL!! :D :)
Offline lurk
    • TinyPortal
« Reply #31 on: February 11, 2018, 04:21:46 PM »
You do a great job, much better than I could even attempt. It looks great in firefox, chrome, and edge.  IE11 I'm still in the habit of testing with, handy fr spotting broken images etc..
I'm currently about to release our new portal version to the world, glad I have people who can code it for me, otherwise it would be a complete mess. lol..  You should see it announced over at SMF very soon.
Online Jeff
  • Fearless Leader
« Reply #32 on: February 11, 2018, 04:23:34 PM »
You do a great job
Thank you sir. Much appreciated!
difficulties in drying hickory
Started by mikeb1079 on Drying and Processing
Last post December 01, 2013, 08:44:51 PM
by mesquite buckeye
cheesy
Menagerie Robustification With Attendant Difficulties
Started by DanG on General Board
Last post December 19, 2008, 10:52:38 AM
by OneWithWood
blade options for WM LT-10? Cutting difficulties
Started by francismilker on Sawmills and Milling
Last post October 18, 2012, 05:46:46 AM
by dgdrls
Login
Started by bandmiller2 on Sawmills and Milling
Last post April 15, 2013, 06:21:20 AM
by SwampDonkey
