Author Topic: Inlay Coffee Table in the Works.  (Read 8477 times)
Offline SwampDonkey
  • Large Tooth
« on: January 21, 2008, 09:08:48 AM »
Taking a pattern put together and displayed from the Making Patterns From Triangles thread, I am piecing together a coffee table using one of the patterns inlayed into the top.
Here I have biscuit jointed a few pieces, which are being held with clamps recommended by a forum member.  ;) Once all the sections are glued up, I will scribe an oval off each end. Looking to have about a 30 inch wide table, by 45 inch long at the mid points.  ;D
Move'n on.
Offline Robert Long
  • winner of WM Personal Best "GRAND CHAMPION" Cat. 6
    • www.portablesawmill.ca
Re: Inlay Coffee Table in the Works.
« Reply #1 on: January 21, 2008, 09:39:41 AM »
Hey Swamp Donkey 8)
That's looking nice!   I am sure you are planning a boarder around that glue up.
Looking forward to seeing the table complete ;)
Robert
Offline SwampDonkey
  • Large Tooth
« Reply #2 on: January 21, 2008, 10:01:48 AM »
I have two more 5" sections to glue up on the end where the handles are and one more on the far end of the clamps.
I have some legs to turn and some 3" wide edging for the table underside to cut.
Move'n on.
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #3 on: January 21, 2008, 11:50:10 AM »
I use aluminum bar clamps and seem to struggle with getting a flat piece in the end.  The bars bow slightly and do not sit flat on the piece.   Looks like you have home cut bars out of wood sitting flat on the piece?   Do the clamps compress the top and bottom bars onto the piece?
Let us know how the clamps work and where to get them.  Great clamping job not to mention the good looking inlay joints!
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline metalspinner
« Reply #4 on: January 21, 2008, 12:57:35 PM »
 8) 8)
Love those clamps!
No way are you going to sand through those inlays either. :D  What is that form of construction called, anyway?  Marquetry?  Any ideas on the base design yet?
LCC,
Those clamps compress in from all four directions.  Woodcraft carries them.  I'm sure others do, as well.
Offline SwampDonkey
  • Large Tooth
« Reply #5 on: January 21, 2008, 01:56:02 PM »
Oh yeah?  :D It took about 1 hr and 1/2 on the table sander, but I did it. I was a dust magnet by the time I finished.  :D :D Just gotta touch up on the hand held belt sander after she's all glued up.  ;D
Quote
I just call it inlay.  :D What do I know? My first attempt, so don't ask too many hard questions.   ;) It wasn't super perfect fit, but she's snug and just the odd hairline. A little colored fill will do magic along with some rotten stone between 2nd and third finish coats.  ;D
Quote
Yes, I just didn't draw anything up. Going to use halving joints to make a lower shelf using rails spaced about 2" apart. Just a place to stuff a book or photo album or puzzle book or whatever.  ;D
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #6 on: January 21, 2008, 04:43:26 PM »
Well I got an education today. Metalspinner mentioned this inlay work was called marquetry, so I went searching. ;D
http://www.marquetrysociety.ca
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #7 on: January 22, 2008, 06:25:29 AM »
So, how do I scribe an ellipse on my table top  ???
Refer here
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #8 on: January 22, 2008, 08:09:31 AM »
Here is a splined joint used to make the table shelf with rails as cross members. Not sure how to join to the legs on the corners yet.
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #9 on: January 22, 2008, 07:17:16 PM »
Here I've scribed my ellipse with my home made ovaler. My ovaler is a bit loose, you can tighten things up a bit if you take more time then I did. I would also embed a trimmed off finish nail on each corner of the underside to eliminate slippage. Maybe protrude the nail about 1/32", just barely touching the surface of the table. Your going to sand the surface afterward anyway. But mine did work well. I went around afterward and checked the geometry and made adjustments before applying a heavier line weight. It looks pretty good to me. I upgraded my mechanism from a 5" block to a 10" for a table this size.
Move'n on.
« Reply #10 on: January 22, 2008, 11:18:07 PM »
That's looking great, SD.
That pattern reminds me of quilt patterns.  Will this table be a close neighbor to your previous table?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #11 on: January 23, 2008, 12:06:11 AM »
SD,
That is looking good ;D.
Offline SwampDonkey
  • Large Tooth
« Reply #12 on: January 23, 2008, 06:10:52 AM »
Yeah me to, to the quilt patterns.  ;D It will be just across the room.  ;D
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #13 on: January 23, 2008, 10:01:45 AM »
Well, here is the table top cut out on the band saw. When carving out I left about 1/16 of an inch margin around the pencil line to give space for error. Then I took the top over to the table sander and smoothed out the rough edge to the line. Not too bad if I say so myself.  ;D :)
You know what would go good with this table is if a some lady quilting bee put together a matching throw to toss over the back of the couch.  ;D
Move'n on.
Offline Bro. Noble
« Reply #14 on: January 23, 2008, 12:49:13 PM »
You know what would go good with this table is some lady to toss over the back of the couch.  ;D
Sounds like an interesting next project 8) 8) 8)
Offline SwampDonkey
  • Large Tooth
« Reply #15 on: January 24, 2008, 03:53:41 PM »
Turned the legs today out of Y. birch. Took about an hour each to mark the reference lines and turn them out.
Got my four table legs in a row.  ;D Cough.
Move'n on.
Offline shopteacher
  • Hiking Sedona, AZ.
« Reply #16 on: January 24, 2008, 05:54:38 PM »
Nice, 2 gold stars for you.
Offline SwampDonkey
  • Large Tooth
« Reply #17 on: January 24, 2008, 05:59:13 PM »
A little tip for turners:
If you have a steady hand or even better a template....., did you know that if you scribe the shape you want to turn on each face of your turning, that you can see the shape from the pencil lines as it turns on the lathe? Try it. ;)
Move'n on.
Offline WDH
« Reply #18 on: January 24, 2008, 11:31:10 PM »
I am with Bro. Noble.  Tell me more about the lady that matches the table ;D.
SD,  nice legs :D.
Offline getoverit
  • freeing trees from silence
« Reply #19 on: January 25, 2008, 02:00:43 AM »
Awesome table !!
Coffee table
Started by iffy on General Woodworking
Last post March 09, 2016, 07:52:25 PM
by sandsawmill14
Coffee Table
Started by bags on General Woodworking
Last post November 23, 2017, 01:11:03 PM
by Bruno of NH
coffee table
Started by ely on General Woodworking
Last post March 22, 2015, 08:55:39 AM
by Magicman
Walnut coffee table
Started by Den-Den on General Woodworking
Last post January 30, 2014, 10:39:34 AM
by Jemclimber
