Dynamic Green Products Inc.
Author Topic: Are you a bar flipper?  (Read 11026 times)
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« on: September 19, 2008, 08:55:57 PM »
I was told by an older friend that each time I sharpen my chain, or at least every few times, I should rotate my bar by flipping it upside down and then back right side up again after a few more sharpenings.  He said it helped to wear the bar evenly.  Do any of you do this? or does it sound like a good idea?  I don't know any better one way or another but I want to be able to explain to someone why I have my bar on my saw upside down, and not look like an idiot!
-Matt
What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.
Offline Rocky_J
Re: Are you a bar flipper?
« Reply #1 on: September 19, 2008, 09:10:53 PM »
Yes, it is part of normal maintenance and care for your saw. The next time you have the bar off, look at the edges of the bar near the tip. You will see wear on the bottom side and usually a bit of a sharp ridge along the outside edge. When the bar wears and this ridge flares out it can eventually interfere with the saw passing through the cut. Use a flat file to eliminate the sharp ridge and keep the bar rails flat and square.
I don't flip every time I have the bar off but rather I inspect the bar rails and install the bar so the least worn side is on the bottom. You have been given the short rule about flipping the bar, now I've given you the 'how' and 'why'.
Offline beenthere
« Reply #2 on: September 20, 2008, 12:25:04 AM »
Like Rocky_J says, is good info.
I flip mine, each time I put on a different chain.
Normally I run two chains and one sprocket through a cycle. When the chains are used up, I get two new ones and a new sprocket. Also, joint the bar at that time.
Has worked well for me for near 40 years.  :)
I just wait for someone to ask me about the bar upside down... ;D ;D ;D
Offline Ianab
« Reply #3 on: September 20, 2008, 05:44:39 AM »
The way I figure it is that you are paying for a whole bar, with two sides. If you dont flip it occasionally then the bottom side (where most of the wear happens) gets worn out first and you have to replace the bar sooner, with a perfectly good top.
I think Stihl started printing the logo upside down on one side of the bar to remind folks that it didn't matter which way up the bar was.
If I'm ever asked I will just tell people it's beacuse I'm planning to stand on the other side of the tree when I cut it, and let them ponder that.  ;)
Offline stonebroke
« Reply #4 on: September 20, 2008, 08:50:21 AM »
How do you joint a bar?
Stonebroke
Offline Cut4fun
« Reply #5 on: September 20, 2008, 11:43:29 AM »
Yes on flipper, just not on my hognose bars though.
Offline WildDog
« Reply #6 on: September 20, 2008, 05:23:45 PM »
I flip my bar at the start of each day of cutting when I do my regular maintenance, the guy who ran our last cross cut/felling course said to flip it every time you sharpen, thats too much for me, if I am cutting fallen hardwood I might touch up the chain 4 or 5 times a day.
I use the same flat file used on the risers to take any burr off the edge of the bar.  Like  beenthere said, remember to replace your rear spocket.
Quote
I have never been asked about the bar wrong side up. I probably do more idiotic things that give onlookers something else to focus on ;)
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline Piston
« Reply #7 on: September 20, 2008, 08:34:16 PM »
Thanks for all your replies guys, it's nice to know I can ask these "rookie" questions and get some good info, I'm trying to learn as much as I can about this stuff and this website is incredibly helpful.  I guess I'll start flipping my bar from now on and get some more use out of em.  Thanks again.
-Matt
Offline Wallys World
« Reply #8 on: September 20, 2008, 10:33:43 PM »
I have a Pferd Universal Edge Sharpener that I got from Baileys. It has a right angle guide on it so you can true up the bar. I do it when I feel/see burrs on the edge of the rails. My saw is a 1982 Stihl 056 and I am still running the original bar. It has been thru alot of wood, but normal maintenance sure makes a difference. Remember to grease your sprocket nose on the bar also.
Wood-Mizer LT28G25, Wood-Mizer EG10 Edger, Wallenstein Timber Talon log loader trailer, Wallenstein GX640 wood splitter, Wallenstein WP835 Fire Wood Processor, Kubota BX 22 TLB, JD 445, JD Gator, Home made arch, Stihl 024 Super, MS251, MS311, MS440 Magnum & 056
Offline Al_Smith
« Reply #9 on: September 21, 2008, 12:37:20 AM »
I flip them every so often not with any set time to do so .Every so often I also true them up using a 6 by 48 belt  sander . I've got some hard nosed bars that are older than most people on this forum that are still just fine .
Offline markct
« Reply #10 on: September 21, 2008, 10:43:18 AM »
Quote
is there a way to grease the newer sprocket noses, i know the old bars like my fathers homelite had used a little pointed grease gun and ya pushed grease into the little hole on the side of the bar, but the never bars dont have this hole on any i have, mostly stihl ones, so how is one to get grease to the bearing, i had just assumed it got lube from the bar oil but maybe i have been wrong in assuming that, altho at the same time i have yet to have a sprocket nose fail and have alot of wear on some bars.
Offline Al_Smith
« Reply #11 on: September 21, 2008, 11:16:19 AM »
Quote
Ha ,I've blown 'em  right off the end of the bar .Less expensive Oregons on a Mac pm-610 ,several of them . I think that old saw is on it's fifth bar and at least a five gallon bucket full of chain loops . I lost track of the rim sprockets ,many .
Offline Warbird
« Reply #12 on: September 21, 2008, 12:28:39 PM »
Don't worry, you won't look like an idiot.  When you see a guy with the bar upside down like that, you'll know that's a guy who knows what he's doing (well...  maybe!).
markct, I don't think there is a way to grease the sealed bar tips.  You'd have to practically tear the bar apart, methinks.
Offline sawguy21
« Reply #13 on: September 21, 2008, 12:47:59 PM »
The cheaper consumer bars often do not have provision for greasing, they depend on the chain oil to lube the tip. Most of those saws do not get enough hours to worry about it.
Offline Rocky_J
« Reply #14 on: September 21, 2008, 01:41:40 PM »
Newer technology and metalurgy allows for better bearings in the nose sprocket. And the bar lube provides plenty of lubrication. The problem with greasing them is that dirt sticks to the heavy grease. If you grease, then you have to keep greasing to constantly push out the old, dirty grease. Otherwise your grease becomes a dirt trap and creates bearing problems. If you never grease then you don't have to worry about crud buildup as much. The bar lube is light enough to wash away most of the dirt. This is why the new bars don't have grease holes.
I use the air nozzle on my compressor to blow out the bar rails when I clean my saws. I also use the air to spin the nose sprocket until all the crud is blown out and it spins freely. Doing this once every couple weeks or so has given me excellent bar longevity. I haven't lost a nose sprocket in almost 10 years. And I've never greased a nose sprocket in my life.
Offline NewEnglandTreeSvc
  • Git'R'Done!
    • www.netree.org
« Reply #15 on: September 21, 2008, 02:50:19 PM »
Newer technology and metalurgy allows for better bearings in the nose sprocket. And the bar lube provides plenty of lubrication. The problem with greasing them is that dirt sticks to the heavy grease. If you grease, then you have to keep greasing to constantly push out the old, dirty grease. Otherwise your grease becomes a dirt trap and creates bearing problems. If you never grease then you don't have to worry about crud buildup as much. The bart lube is light enough to wash away most of the dirt. This is why the new bars don't have grease holes.
Ditto, to both nixing the grease and keeping the bar flipped and filed properly.
Erik Lovell, Arborist
Offline Rocky_J
« Reply #16 on: September 21, 2008, 02:56:54 PM »
Hey, good to see you over here, Erik.  8)
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #17 on: September 22, 2008, 08:20:17 AM »
Gday
Im a flipper every new chain usually  or when I take the bar of sometimes half way through a chain  I also chek and give it a dress up if needed clean the rail out and clean and grease the knose sprocket + make sure the oil holes are clean It depends wether the wood Im cutting is durty or clean how much maint I do on the chainsaw usually pulldown clean once a day  ;D
Happy cutting Chris
4TH Generation Timbergetter
Offline Cut4fun
« Reply #18 on: September 22, 2008, 03:05:35 PM »
This statement above in my opinion is totally FALSE. If this was true why do my $70-$80 Stihl ES bars in 21" and 25" for 066 and 084 have no holes for greasing. Consumer grade I dont think so.
I think it just depends on the manufacture of the bars if they have grease holes or not.
Offline markct
« Reply #19 on: September 22, 2008, 05:42:16 PM »
Quote
yea i was gona say the same thing, i dont see too many consumer bars that are 25 inch long! and i know my 25 inch bar was around 80 bucks so i doubt ya could make much selling 120 dollar saws with 80 dollar bars!
Flipper
Started by bandmiller2 on Sawmills and Milling
Last post June 30, 2009, 06:47:58 AM
by bandmiller2
Squaring the flipper clamp
Started by Chuck White on Sawmills and Milling
Last post September 10, 2013, 07:06:03 PM
by Chuck White
2009 Christmas Sale Catalog - NEW Online Digital "Catalog Flipper"
Started by KC on Chainsaws
Last post November 01, 2009, 06:44:13 PM
by stonebroke
