Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
This topic
This board
Forest Education
Entire forum
Google
Home
Help
Search
Extras
In Rememberance
Finda-Data-Base
Tool Box
Forestry Forum Dictionary
Lumberjack Lingo
Knowledge Base
Forestry Forum Gallery
Who's On-line
Login
Register
Menu
Home
Help
Search
Extras
|-- In Rememberance
|-- Finda-Data-Base
|-- Tool Box
|-- Forestry Forum Dictionary
|-- Lumberjack Lingo
|-- Knowledge Base
|-- Forestry Forum Gallery
|-- Who's On-line
Login
Register
Forum
General Forestry
Forestry and Logging
(Moderators:
Ron Scott
IMT 533
Forestry ForumSponsored by:
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: IMT 533 (Read 14212 times)
IVANX71
member
Gender:
IMT 533
on:
January 14, 2009, 09:24:22 AM »
I plan to buy woodmizer Lt 15 so I have to buy something to move logs around farm.
This is the IMT 533, this is an old tractor power 33 hp. Resistant ,poorly spoils and all speak only the best of him.
The question is whether the 33 hp enough power for towing logs through the forest or only for towing logs around farms. I'd like to save money so that I drive logs from the forest just do not know whether the 33 hp enough to extract logs over a steep hill's.
Logged
Excuse me on my English, English is not my stronger side
Gary_C
Senior Member x2
Gender:
Sunrise on the Prairie
Re: IMT 533
Reply #1 on:
January 14, 2009, 09:41:07 AM »
That's a nice looking tractor though I can't say I heard of an IMT brand before. Where are you located? I guess I don't recognize that flag on your profile.
As far as pulling logs, you should add one of those log arches behind that tractor and maybe a set of chains on the tractor for winter and it should do most anything you need done. Just watch out for sticks and brush on the underside of that tractor and know those tires are not rated for woods work. That doesn't mean you can't use them in the woods, but watch out for stumps and sticks that could poke a hole in a tire.
Logged
pineywoods
Senior Member x2
Gender:
Engineering analysis-just sittin thinkin about it
Re: IMT 533
Reply #2 on:
January 14, 2009, 09:46:56 AM »
Looks like someone's version of my old massey ferguson 135. Hang a good set of skidding tongs on the 3 point hitch, lift the end of the log 2 or 3 inches off the ground and go. Unless you have one of them monster 50 ft long LT115's this old tractor should handle anything the LT15 will saw. If the hills are too steep, you need a logging winch on the back...A home-built set of forks on the back works pretty good also...
Logged
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln. Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl 028, 029, Ms390
Senior Member x2
Gender:
DanG, The Official ForestryForum Cussword
Re: IMT 533
Reply #3 on:
January 14, 2009, 10:13:03 AM »
Yep, that IMT is a Yugoslavian version of the MF35. IMT stands for Improved Massey Tractor. The company no longer exists. The tractor should perform just like the 35/135. Woodbowl has one just like the one pictured. I have the larger IMT, a 560, which is a 60hp tractor. They're good machines but parts are hard to find.
Logged
"I don't feel like an old man. I feel like a young man who has something wrong with him." Dick Cavett
Gary_C
Senior Member x2
Gender:
Re: IMT 533
Reply #4 on:
January 14, 2009, 10:29:08 AM »
I forgot to add that one thing missing on that tractor is roll over protection, so be very careful on those hills and when pulling anything while lifting with the three point hitch.
Logged
SamB
Full Member x2
Gender:
Re: IMT 533
Reply #5 on:
January 14, 2009, 11:40:16 AM »
That IMT is a nice looking tractor….it does resemble a MF135….I’ve moved logs that I probably should not have moved with my MF135. With the aid of a Farmi skidder/winch I moved a thirty inch-sixteen foot red oak log up a steep embankment by chaining the front of the tractor to a tree. With a couple steel snatch blocks, some short chains and a little rigging experience you can move good sized logs with a tractor equipped with a 3 point hitch mounted skidder/winch. On level or nearly level ground I’ve skidded logs with just a rear blade and chain. For loading logs onto the mill a boom pole works well even if you can just lift one end of the log. For a small scale logging operation the farm tractor properly equipped can be a valuable tool just be careful and realize your limits.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Forum
General Forestry
(Moderators:
Ron Scott
IMT 533
Share Topic
Powered by
EzPortal
