Author Topic: How many Logrite Tools do you have??  (Read 9961 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« on: August 10, 2013, 09:34:17 PM »
Everybody "fess" up.  How many Logrite Tools do you have?
I have 4.  Two 48" and one 60" cant hooks, and the latest addition is the 30" Hookaroon.
The subject came up in another thread and it was on my mind today as I was using my very latest Logrite tool.  I wanted it to reach stubborn flitches that are sometimes on the loading arms and out of reach for the two plane log clamp.
And it worked perfectly for that job.
Waiting for the next time.  It is painted a special Green in keeping with the theme of the 10th Anniversary Pig Roast.
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: How many Logrite Tools do you have??
« Reply #1 on: August 10, 2013, 09:40:58 PM »
Actually, the forest green in not the pig roast theme, but more of the Forestry Forum theme. I have a green 48" cant hook here in the office that I don't use that is signed by a whole bunch of members. If I count that, I have 3 cant hooks, 2 hookaroons, i mark 7 arch, 1 international log scale and also a pruning saw, one bottle opener, and once small scale cant hook. I purchased all of my tools other than the bottle opener, "toy hook" and the signed canthook which was a gift from the members. :)   All of my other tools are blue other than one orange canthook that is actually Tammy's :)
Offline trapper
« Reply #2 on: August 10, 2013, 09:45:48 PM »
2 cant hooks one with the log lift on it and one hookaroon.
I like MM's hookaroon better than mine because of the smaller diameter handle
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline thecfarm
« Reply #3 on: August 10, 2013, 09:51:08 PM »
No tools,yet. But I have the Blue Creeper.
Offline bozzaa69
  • not new anymore
« Reply #4 on: August 10, 2013, 09:52:50 PM »
None. I make my own.
Offline Jeff
  • Fearless Leader
« Reply #5 on: August 10, 2013, 10:19:38 PM »
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #6 on: August 10, 2013, 10:20:18 PM »
one
and I use it all the time ;D
A&P saw Mill LLC.
License NH softwood grader.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #7 on: August 10, 2013, 10:21:06 PM »
I have 1 but I have 2 hands. So I'll probably get another 1.  ;D
Offline Compensation
« Reply #8 on: August 10, 2013, 11:47:13 PM »
That's the same reason I bought 2 stihl bg55's. Then later bought a third one, don't really know why. Now I have one and my dad and friend each has one. Wait a minute, I bought 4 leaf blowers. Wow, I am weird.
Anyhow, I have a blue cant hook. What are those cant hooks called that has a rest on it so you can lift the log off the ground to cut firewood? Got one of them too.
D4D caterpillar, lt10 Woodmizer, 8x12 solar kiln, enough Stihl's to make my garages smell like their factory :) Ohh and built Ford tough baby!
Offline sandhills
« Reply #9 on: August 11, 2013, 12:00:40 AM »
So far two 60" cant hooks, unfortunately never used them with the mill yet but are mighty handy cleaning up trees cut down around the yard to help with loader work on the big logs.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #10 on: August 11, 2013, 01:52:20 AM »
I have 2 cant hooks -- 30" and 60", plus a 60" peavey with a slightly bent handle.
The 30" cant hook is the workhorse. It's a two-tone -- part blue and part silver (aluminum). Most of the time I use it to roll logs along the log deck. It's also great for coaxing a timber that doesn't quite want to turn all the way on the deck.
The 60" cant hook doesn't get as much use but it is an absolute life back saver in the log yard. No need to fire up the loader just to shift a log off the pile.
The peavey is semi-retired but I have plans for making a useful mill too out of it. If that works out I'll give the design to Logrite to see if they can market it.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #11 on: August 11, 2013, 07:34:48 AM »
48 and 60" peavies
78" cant hook
timber carrier
24 and 30" Pickaroons
1/4" scale stick
Fetching arch with 2 man handle and tow tongue
That makes 8.
Plus Porta-winch, Blue creeper, and a replacement hook for megahook which I use to roll logs.
Everything gets used regularly and it's a pleasure to pick up any of these tools.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: August 11, 2013, 08:24:00 AM »
One 48" cant hook, but one day I will add either a hookaroon or a pickaroon!
Which ever one I get, will primarily be used to pull boards back off the loading arms for edging!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #13 on: August 11, 2013, 08:31:41 AM »
Deux,  quite pleased with both ;)
Offline SPD748
  • "Tuam Libera Mentem"
« Reply #14 on: August 11, 2013, 09:02:56 AM »
Besides these three, I have one 48" Peavey. All four work great!
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
Offline bozzaa69
  • not new anymore
« Reply #15 on: August 11, 2013, 09:15:22 AM »
I like that log scaler.
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #16 on: August 11, 2013, 09:17:29 AM »
30" canthook and pickaroon, 48" canthook and pickaroon, Scribner Decimal C log scale
Offline Skoalbandit78
  • talk low, talk slow, and don't talk to much"
« Reply #17 on: August 11, 2013, 10:01:28 AM »
I have only one, which is the 30"and I really like it.
Offline tyb525
  • Always learning.
« Reply #18 on: August 11, 2013, 10:09:04 AM »
One 48" cant hook and I love it. Definitely no buyers regret there.
Also one bottle opener ;)
Offline clww
  • Oh yeah? Watch this!
« Reply #19 on: August 11, 2013, 11:04:12 AM »
One orange 60" cant hook. smiley_thumbsup
Many Stihl Saws-16"-60"
18-Wheeler Driver for CFI
What's new at Logrite Tools
Started by neslrite on Sawmills and Milling
Last post May 08, 2005, 07:54:51 AM
by Captain
*Modified*New Logrite Tools
Started by Ga_Boy on Sawmills and Milling
Last post March 24, 2005, 07:38:26 AM
by Engineer
Cudos for Logrite Tools!
Started by Pedalbiker on General Board
Last post January 11, 2005, 07:32:37 PM
by Frank_Pender
Congratulation to Logrite Tools!
Last post November 02, 2006, 07:59:14 PM
by Corley5
