Author Topic: lucas mill saw doctor needed  (Read 1901 times)
Offline Mountain Sawyer
  • Lucas Mill 1030
« on: April 01, 2014, 08:21:21 PM »
Are there any saw doctors that anyone knows about in eastern us
Always enjoy the outdoors that God has made
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: lucas mill saw doctor needed
« Reply #1 on: April 01, 2014, 08:23:59 PM »
We all are……if you don't believe it, just ask us.  :D
Seriously……what's going on Mountain?
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #2 on: April 01, 2014, 08:49:08 PM »
Whats Up MS??
DGDrls
  • Lucas Mill 1030
« Reply #3 on: April 01, 2014, 08:50:57 PM »
hi poston i have a couple blades that i need retipped, one is missing a tooth and the other has been sharped down to the nub and i need them brought back to life, who would you suggest to fix them its a 10'' blade
  • Lucas Mill 1030
« Reply #4 on: April 01, 2014, 08:53:09 PM »
Hey whats up with you DGDrls have you been sawing much lately.
Offline scsmith42
    • Whispering Pines Farm
« Reply #5 on: April 01, 2014, 08:55:29 PM »
Why don't you send them to Paynes or Menominee Saw (FF sponsor)?  I've worked with both companies and they are great.
Tom's 3638D Baker band mill
  • Lucas Mill 1030
« Reply #6 on: April 01, 2014, 08:57:25 PM »
We have been sawing about 1500 to 2000 bdft a day for the last 3 weeks and im down to two blades and it makes me nervous so i need to get these two fixed up so i want be so worried lol. hey SCsmith ive not heard of them where are they located and how much does it cost to get them fixed
Offline dgdrls
« Reply #7 on: April 01, 2014, 08:58:25 PM »
No sawing, but can't wait to start again ;)
Did you Try Menominee saw??
DGD
« Reply #8 on: April 01, 2014, 08:58:47 PM »
A prayer.  :)
I believe I would invest in a new box of blades. I'm assuming you meant 10 degree not 10 inch.
  • Lucas Mill 1030
« Reply #9 on: April 01, 2014, 09:00:58 PM »
Yes poston its a lucas mill 1030 its a 10'' circle blade
Offline dgdrls
« Reply #10 on: April 01, 2014, 09:10:52 PM »
So what have you been sawing, and how is the Lucas treating you??
D
  • Lucas Mill 1030
« Reply #11 on: April 01, 2014, 09:32:21 PM »
Hey D ive been sawing chestant oak , white oak, and ash, and just 3 or 4 poplars, im only getting about three days a week sawing because either it will snow or rain but we have been doing alot of sawing . After i got over being really sore for a few days ive been enjoying myself
Offline dgdrls
« Reply #12 on: April 01, 2014, 09:55:10 PM »
Good stuff,  you will have to post some pictures,
Best
DGDrls
Offline GeneWengert-WoodDoc
« Reply #13 on: April 01, 2014, 10:20:35 PM »
Most large saws (over 24" diameter) need special attention to tension the saw.  However, a 10" saw does not need such special work, so a good local shop will be fine for this saw, if they know how to handle carbide.  One clue on their ability (in addition to calling some customers) is to see how they protect the carbide teeth after they have worked on them.  Carbide is so brittle that they should be exercising special care so that the teeth are well protected from accidental hits.
Check out FAST-SHARP in Locust Grove, VA, as they know carbide and follow good practices, and there may be others too.  They are in the same state as you are, not to far from Charlottesville.
Offline UN Hooker
« Reply #14 on: April 01, 2014, 10:59:00 PM »
That saw blade on the "10 inch cut" Lucas should be around 26" diameter - like my "10 inch cut" Peterson blade.       UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
Offline JohnM
  • Sometimes its best to punt and play field position
« Reply #15 on: April 02, 2014, 09:33:24 AM »
I think this is what the WoodDoc is talking about.
I sent mine up to Quality Saw and Supply, in West Enfield, Maine (45min drive for me).  I'm guessing Menominee has a similar service and there's likely someone close to you. ???
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #16 on: April 02, 2014, 09:40:03 AM »
Swing mill blades do need a special knowledge set. You can find all kinds of cases where a swingmill blade came back after being reworked and would not saw correctly. The saw doctor needs to know the application and the specs on how and where the carbides attach to the saw for that mill and blade design so when the saw pivots, the cuts align exactly the way they are supposed to.  With a general use saw, the carbide height is not critical. on a swnghblade, it is absolutely essential.
Offline Grandedog
    • Left Coast Supplies
« Reply #17 on: April 02, 2014, 12:48:20 PM »
     Howdy,
   Jeff nailed it. The outside dimension is critical on a swingblade. If the tip seats are not damaged, and the blade hasn't been overheated, it's just a matter of brazing in some new tips. We have re-tipping jigs available for your machine that makes it easier than what people imagine.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
Offline tjhammer
« Reply #18 on: April 02, 2014, 02:26:29 PM »
I use paynes all you have to do is tell them what kind of saw it is and they will send it back sawing like a new one
tj
hammer
Offline Jeff
  • Fearless Leader
« Reply #19 on: April 02, 2014, 03:31:49 PM »
So does our sponsor Menominee saw.  :)
Saw doctor in Oregon for 827 lucas mill blades
Started by boardwalker on Sawmills and Milling
Last post January 29, 2017, 11:00:38 PM
by TKehl
Know any Lucas Mill or other alaskan mill operators in N. GA?
Started by HeartwoodBurl on Sawmills and Milling
Last post February 17, 2014, 06:33:43 AM
by Seaman
Lucas mill
Started by jph on Sawmills and Milling
Last post February 02, 2010, 07:21:17 PM
by sigidi
Lucas Mill
Started by kdf101 on Sawmills and Milling
Last post August 04, 2009, 11:24:48 PM
by ErikC
