New Lumber Storage Shed
Started by Planman1954, February 21, 2016, 09:23:03 PM
Planman1954
A while back, I mentioned that I planned on building a lumber storage shed. Since buying a sawmill about six years ago, it seemed I always had leftover boards and no place to store the, except in my garage areas:
Trust me, if you own a mill for your own use and not as a commercial enterprise, you WILL have leftovers!
Anyway, so I chose an area near the mill to place the 16'x16' structure. It is right beside an area that will be convenient to load and unload pieces. Here is a photo of my brother helping cut a few small trees in the way:
I began by grading the small area with my old Ford 9n with my box blade. I then set some 16"x16"x4" thick concrete blocks every 8' on all corners and centers. After leveling them up, I set a concrete block on each one. Then I placed a termite shield over each block. I made them from some metal roll stock. It worked fine. Then I placed a 2x6 treated sole plate onto the block system and lined them up to square:
The next step was to place the joist system onto the toe plates. I used 2x8s at 16" on center, with a double 2x8 beam around the perimeter with a beam across the center. I let the joist system float on the sole plates while I nailed the joists together. After squaring up the joists, I nailed them down to the sole plate:
The next step was to lay down the 1x12 floor over the joists. But before doing this, I laid felt over the joists so that there would be a vapor barrier under the floor. The whole idea of the structure is to have a complete surrounding of felt to create a moisture free environment. Here's a picture of my buddy Tim who helped me today of the floor boards being put down:
And here's a photo of the finished floor:
We finished the day by standing up the first of five walls. I plan on updating the project as I go along. It may be a few weeks, as I'm only able to work on the weekends usually on it.
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Ljohnsaw
That's great progress.  Curious as to how you are securing your floor to your "footings".  I would worry about it being blown off your foundation in a stiff wind!
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
WV Sawmiller
P'54,
   Congrats and looking good. Keep us updated. Want to take any bets as to how long it will be before you say "Its not big enough" (They never are).
    Be careful and keep on punchin.
Planman1954
Ljohnsaw....it's not going to blow away...I promise! The shear weight of the joist system bearing on the piers is massive already. Once the thing is loaded with lumber, well...I'm not worried.
Bark Beetle
How are you going to stack the lumber in there, are you going to put up some racks or just stack it on the floor? It will definitely be nice to have a dedicated building for lumber( around here it is always in the way :D)
You don't work wood, you work with wood.
You can come build me one too.  :D
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Planman1954
I made the building 16'-8" deep so that 16' long stock will fit. I'm going to put two 36" wide doors on the front with four feet between them. There will be a wall in the center of the building front to back, which will give me support, along with the right and left end wall, for 2' wide racks. There will be three on each wall at 2',4',and 6' above the floor. I can then carry boards through each of the two doors and place them on either side of the aisle in each half of the finished building. You'll get the idea as I go along.
Looking great.  A man needs a place to keep lumber.
WV Sawmiller
P'54,
   A suggestion - can you include a small hinged door as a loading chute on one end, preferably the high or most accessible end, that you could raise and slide your lumber in maybe off the forks of your tractor (if you have one) or the end of your truck or trailer? You can then lift inside and on the long heavy stuff just lift one end at a time. Even a 2' square opening or 16" wide if that is your stud spacing, should be big enough to slide most lumber into the shed. Might even build in a simple roller system if not too complicated.
   Lots of us are old enough now we avoid lifting a board any time we can and sliding/rolling off forks or a trailer could be a lot easier than carrying them through your doors.
   Just a thought - remember free advice is worth what you paid for it.
pineywoods
Planman is a neighbor and good friend. He tends to do things kinda backwards. He built an absolutely beautiful home, then filled it with some of the nicest handmade furniture you ever saw..THEN he bought a sawmill to saw lumber to build a shed to keep his lumber in. Pore mill still sits out in the rain.. ;D
Deese
Very nice Planman! Keep us updated smiley_bounce
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Planman1954
Piney must have just driven by! I forgot to put the cover on the mill after I finished sawing the other day...I let it cool down so it would not melt the plastic cover. :D
WVSawmiller: That sounds smart! I did put a lot of thought into the arrangement of the lumber by reading a lot and watching videos of other lumber storage ideas. I think I need to stick the plan! Guess I'll just have to keep myself in shape a few more years as I tote a board at the time into the shed. >:(
WmFritz
That's going to make one fine lumber house, Planman.
Piney, nobody's more backwards then me. I built my mill and then I found the Forestry Forum to figure out what to do with it.  ;)
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
21incher
That looks like it will be a great storage area. The biggest problem with stacking lumber in a shed that I am running across quite often is I always need the peice on the bottom of the stack.  :)
Planman1954
I've made some more progress on the shed. I hope to post pictures soon. Stay tuned!
Carson-saws
Looks real good.   Do I need to take a number?
Let the Forest be salvation long before it needs to be
Planman1954
Here's a couple of photos I just took. The first is a front view, showing the center wall and the two front doors. This will give me two aisles for lumber to be stacked on each side:
Here's a shot looking up. It shows the felt laid over the stripping which the metal roof is screwed into. This is so that the entire building will be totally surrounded by a vapor barrier (felt):
Planman1954
After a long HOT summer, it's time to get this shed completed! I've made some progress in the last few days. I hope to have it done by about the end of next week. Slow and steady wins the race....it seems so here.
pineywoods
Planman1954
Actually, I've got a LOT happening at once Piney! I'm trying to get the woodwork shop done at the same time I'm working on the lumber storage shed....so that I can get the Hammond organ cabinet(s) built for the keyboard restorations! And then on to the rear deck...and then to the greenhouse...and then to the pool house....and then ;D
ozarkgem
your not to far from having a 2 chamber kiln.
Planman1954
Ozarkgem is paying attention! 8)
wvwoodbutcher
That's a fine looking shed planman. Good work.
Hudson Oscar 36
dean herring
Just finished my shed addition floor yesterday. I can finally get the mill shed organized before my buddy John quits on me. I'm gonna try to post some pictures.
Failure is not an option  3D Lumber
Planman1954
That is the MAIN reason that I like this forum...folks documenting their work with photos to demo how things are made. We need more of this to encourage others to BUILD things that add value to their lives and to others...a good thing!
barbender
I think I need you Grumpy Old Men to come work at my place for a month or so ;)
David Freed
I like reading about and looking at pics of projects like this.
I wish we could get away with foundations like that up here. I'm getting ready to pour a 2' deep concrete foundation.  :snowball:
Planman1954
4" to 6" frontline here! But the price you pay is a long HOT summer! :)
Planman1954
More progress today! All that's left is to paint, put on door knobs, and build the lumber shelf support brackets. Then I can load her up, and get a little more organized around here!
caveman
Planman, that is one fine looking wood shack.  With a window shaker and a fridge that thing would make quite a bachelor pad.  Thank you for showing the build.
Caveman
Planman1954
Almost done! All I lack is a couple of steps and doorknobs! I'm happy! As I said at the beginning of the build, the design was based on an easy to access storage rack system. Since pictures are worth a thousand words, I took a few to show the finished rack system. It seems really sturdy, and I'm not worried about it holding a tremendous amount of lumber without sagging. We used 15 pounds of 2" screws! Whew...almost wore out our drills. Anyway here are the pics:
Roxie
Say when
Ljohnsaw
I like the brackets, especially the mitered bottom corners.  I hate when there is a sharp corner, I always find it with my head ::)  Now that you used up your wood stock to make the shelves, I suppose you have to get cutting again :D
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Planman1954
Ha...the next photos will show LOTS of leftovers from years past! Stay tuned.
Planman1954
Here's the beginning...the first load to go in!!
4x4American
I too need a lumber storage shed, since you did such a nice job, I will reward you with getting to build me one for free!
Boy, back in my day..
Planman1954
Hey! All seriousness aside....It is fantastic seeing the racks of ORGANIZED lumber, by thickness and by species sitting on those racks, just waiting to become something nice. It really isn't too hard a project, and will give a lifetime of convenience to the builder. You really should do it. It didn't cost much...a little metal, a little felt, a little paint and caulk, a few nails, a LOT of screws, and some dedicated labor....and you can have one too.
4x4American
Yea, I have so many projects that I want to get done and not enough time.  I want to build one that can hold at least 4mbf of green lumber to air dry.  I'd like to be able to stack the lumber on pallets and then put it in the shed with a loader.  But we also have this frost up here, the ground moves, and to get the floor to stay level, would have to go below frost with footers.  I read on here about a guy who has to shim his lumber drying shed each spring to keep everything level.
Planman1954
You need something quite a bit larger than I have in order to do that. Mine is geared more towards a hobbiest like myself. Commercial operation is a different animal. But couldn't you use those tubes set into a drilled hole, and fill them with concrete? That's not too difficult to do is it? I'd sure think of something if I lived up there. Good luck!
Ron Scott
~Ron
Much,Much easier. You need something,you will be able to get to it without moving a whack of lumber.
I went to a hobby guy place and he had a rack. Nothing like what you have. His went from the floor to the ceiling. I forgot how wide,maybe a foot,but as soon as you walked in,you was looking at it. He had a rack about a foot square up against the wall and his lumber was put in there.
isawlogs
 That is a nice woodshed,   :)
   I'm thinking that with what I "collect" I'll be needing a large barn soon to store it all.  :D :D
   Marcel
DeerMeadowFarm
