What to charge for milling tropical hardwood?
Started by teakwood, August 08, 2019, 06:32:24 PM
teakwood
the wood mizer blade is the same thickness than my normal blades. 0.045" and the agent also told me that my sawmill is probably too small for that blade.
what i don't get is, if the kerf i need to cut is the same thickness why would the sawmill need more hp with different blades??
Southside
Which profile is it and what do you have for HP on your mill?  The carbide 7° from WM is not the deep gullet like the turbo 7 is so I agree with you there.
teakwood
If the logs are smaller then the HP requirements should be less too? Having 24" of band in the wood must need more power than only 12".
steeper cut angles take a more aggressive bite and would take more hp.  softer wood usually uses a lesser angle so it does not take more than the gullet can handle.  I use 7 degree on everything but I have a 38 hp motor.
teakwood
i'm pretty sure my mill will be sufficient, it won't be fast but a manual mill never is. The logs are small diam and very short so i just go slower if the hp's aren't sufficient
teakwood
ok, today i met with my client in her plantations, after arriving i ask, where are the trees??  here she told me,....  every 3m where a cocobolo tree with 2-4" diam.
every here and there the are some with 8-12" and then there are some old grown ones with a nice 20+" diam.
so from the initial 3000trees she told me she has, 2800 are useless, maybe 200 are small/mid sized and 15 are nice trees.
You have to understand that cocobolo is a very unregular tree, if you're lucky the main log will give you 7' and after that it's all branches with more curves than a mountain road.
I tried to explain here the basics of wood, timber and sawing. had to bring her down back to earth, she thought that 50 of the small trees will give a container load . I explained that she maybe gets one load of all the trees she has.
after that she left and let me there with her right hand which is actually an old friend of mine. half in the conversation i knew that she was getting annoyed with me.
after she left we dropped a 10" tree and i took it home, the first log (3'long) had 4" of heart
I did the test run with the bimetal blade and it works like a charm.
the employee told me that she does that some times but afterwards she calms down and is back to listening, the heck i have a strong character too, so we will see if something good comes out of all that.
But i learned that my sawmill is perfectly capable of milling the hardest wood and that i like the new bands.
In Life everything has to be seen as a gained experience.
Banjo picker
Teak, you sure seem to have a good attitude.   Some of the experiences I gain I could do with out and wish I had never had to come to grips with them.  Banjo
teakwood
well yeah, you have to learn disappointment here, normally it's just bla bla if anybody comes to you with a brilliant business idea.
also if you sell something like a car or truck, half of the possible buyers don't even have the money but they still negotiating.
Didn't heard back from the client yet, so probably won't.
