Author Topic: Beam Boring Machine Make/Model  (Read 1243 times)
Offline bhlaban
  • Learning Everyday!
« on: September 13, 2018, 11:34:23 AM »
Can anyone identify the brand/make of this boring machine?  It's currently disassembled and has a broken gear (shown in pictures).  I'd like to get it fixed up and was hoping to find a replacement for the broken gear, but I assume I'll have better luck searching if I know the brand/make.
Offline D L Bahler
  • Hopp Schwyz!
    • Traditional Swiss Carpentry
Re: Beam Boring Machine Make/Model
« Reply #1 on: September 13, 2018, 11:39:15 AM »
Looks like a Millers Falls
Offline bhlaban
« Reply #2 on: September 13, 2018, 12:13:18 PM »
Thanks for the reply - Any suggestions on finding a replacement gear or repairing the broken gear?
Offline ljohnsaw
« Reply #3 on: September 13, 2018, 12:14:38 PM »
Good luck on finding just that gear!  Is the break clean and complete - that is, is it just the one piece?  There is not a huge amount of stress on those gears as it is human powered.  My first inclination would be to braze the piece back on and use it like that.  Even if there is a tooth you need to reconstruct, it should still work.
John Sawicky
SkyTrak 9038, Ford 545D FEL, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 42" capacity/32" cut Bandmill up to 54' long - using it all to build a timber frame cabin.
Offline D L Bahler
  • Hopp Schwyz!
« Reply #4 on: September 13, 2018, 12:19:02 PM »
I actually think I was mistaken. This might be a snell.
I looked at the pictures again and decided my first guess was wrong. We mostly just have the old Millers Falls machines around here. But you've got the wooden uprights, where a Millers Falls is all metal but the base.
Probably be best to find a machinist to cut you a new gear. If you have any car factories in your area, there's probably someone who'd mill you a precise gear on the side. (that's what we do around here when we need precision parts made)
Offline bhlaban
« Reply #5 on: September 13, 2018, 12:29:51 PM »
It is a pretty clean break.  I can fit the two pieces together nicely.  Someone suggested using JB Weld - Is that not recommended?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #6 on: September 13, 2018, 12:47:57 PM »
It is a Snell machine.
I may have a gear here on hand from our parts bin. Measure the diameter of the hole and the diameter of the gear and let me know.
Jim Rogers
Offline bhlaban
« Reply #7 on: September 13, 2018, 01:16:42 PM »
Jim Rogers
How precise do the measurements have to be?  All I have on hand is a small SS ruler, which I understand isn't the most precise.  Using the ruler and naked eye, the measurements are as follows:
Hole diameter: 22/32 in.
Gear diameter: 3 18/32 in.
Note: Gear diameter was measured from tooth tip to tooth tip
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #8 on: September 13, 2018, 02:46:04 PM »
If you don't have a caliper rule to measure the diameter of the hole, measure the diameter of the shaft. Take an adjustable wrench and tighten it down on the shaft and measure from jaw to jaw. I've done that more than once.
Jim Rogers
Offline ljohnsaw
« Reply #9 on: September 13, 2018, 03:09:10 PM »
JB Weld would probably work.  Like I said, not a lot of stress on that gear.  Hopefully Jim can help you out.
John Sawicky
Offline bhlaban
« Reply #10 on: September 13, 2018, 04:19:49 PM »
Jim Rogers
Thanks Jim, I've been meaning to pick up a caliper rule anyway, so I'll get you some more precise measurements tonight hopefully.
Offline bhlaban
« Reply #11 on: September 13, 2018, 04:25:48 PM »
If Jim can't help me out, I'll likely try to find someone to braze it.  If that falls through, I guess I'll try using JB weld as a last resort.
And thanks to all who've replied - This is a cool forum!
Offline bhlaban
« Reply #12 on: September 13, 2018, 09:29:08 PM »
Jim, I got a digital caliper - Below are the measurements:
Shaft Diameter: 0.685 in.
Gear Diameter: 3.575 in.
Offline bhlaban
« Reply #13 on: September 14, 2018, 09:39:14 AM »
I have a couple more questions pertaining to the restoration (with intent to use):
1) An "acquaintance" who helped press out the pins (and broke the gear) threw away the pins - What are the best replacement pins for re-assembly?
2) He also sandblasted a few of the parts (not requested) and I soaked other parts in vinegar, so now I have a mix of really "clean" looking parts and others that still look "vintage."  Should I just have everything sandblasted?  Also, what type of finish should I put on the metal parts (powder coat, spray paint, etc.)?
NOTE: All wood parts were cleaned with Kramer's Best Antique Improver and they look beautiful.
Offline btulloh
« Reply #14 on: September 14, 2018, 10:57:26 AM »
If you put the sandblasted parts in vinegar they should match up pretty well.  I use vinegar to antique new hardware.  Coat with something like Balistol immediately after the vinegar.  I wouldn't paint them, but that's just me.
HM126
Offline Brad_bb
« Reply #15 on: September 14, 2018, 06:06:40 PM »
Check out this thread:  Boring machine cast welding repair
Offline bhlaban
« Reply #16 on: September 19, 2018, 11:27:36 PM »
Brad, thanks for the link - I might just see what those guys in Hudson, WI can do for me.  Still haven't heard anything from Jim on whether or not he's got a spare gear laying around.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #17 on: September 20, 2018, 08:50:48 AM »
I don't normally do business in an open thread. You need to send me a request by regular email to jrsawmill (at) verizon (dot) net.
I believe I have one on hand. .685 converts to 11/16" I believe and 3.575 to 3 9/16". If that is true then I have one.
Jim Rogers
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #18 on: September 20, 2018, 09:15:25 AM »
Here is a picture of my caliper saying 22/32's or 11/16":
Jim Rogers
Wood Owl bits in Boring Machine(Beam Drill) w/adapter
Started by jacobcbass on Timber Framing/Log construction
Last post July 29, 2021, 10:05:36 AM
by jacobcbass
boring machine not boring
Started by son reech on Timber Framing/Log construction
Last post February 09, 2007, 08:15:33 PM
by son reech
CL boring machine
Started by Mad Professor on Timber Framing/Log construction
Last post December 17, 2010, 06:33:40 PM
by Mad Professor
Another Boring Machine...
Started by Brian_Weekley on Timber Framing/Log construction
Last post February 08, 2015, 09:18:11 AM
by Brad_bb
