Author Topic: Venison Sausage  (Read 297 times)
Offline WV Sawmiller
    • Green's Sawmill Services
Venison Sausage
« on: October 25, 2021, 11:43:27 AM »
   I had a few pounds of trimmings off a young doe and decided to make it up into bulk sausage. I have never tried stuffing any and may one of these days but these work good for us. I took 3.5 lbs of deer trimmings and added 1.5 lbs of pork pieces. I sometimes use a boston butt if I am doing a good bit and I have used cheap pork sausage or ground pork to add the fat needed to the mix. I used a seasoning mix from a local sporting good store. A box costs about $5 and does 24 lbs of meat. If I add pork sausage I use the mix for amount of the deer meat and if I add unseasoned pork I add seasoning for the whole mix. I ground the pork and deer together then added the seasoning. I made meatballs with an ice cream scoop. They figure out just a little over 5 to the pound. If I am making hamburger patties I do the same only I make bigger meatballs. We put the meatballs inside a vacuum freezer bag then flatten them out into patties in the bag then seal the bag. We put 4 patties to a pack because that works well for us. Once frozen you can break the patties apart if we only want 1-2 and not the whole pack.
Venison sausage meatballs ready to go in the bag
This is a sealed pack. Not as pretty as most but the patties will break apart when frozen.
  Now we just need some grits and hot biscuits and muscadine hull preserves. digin_2
Offline petefrom bearswamp
Re: Venison Sausage
« Reply #1 on: October 25, 2021, 12:14:37 PM »
Oh my that looks good.
Archery has been open for some time now but I am only a gun hunter.
Rifle opened Saturday in the Adirondacks and Im heading up to camp tomorrow.
Trouble is deer are almost like hens teeth up there.
Lots action on my trail cams here tho so should do good come season here which starts Nov 21st.
Still working on the remnants of last years venison, taking loin to camp to enjoy with fried onions and mushrooms on wednesday evening.
Kubota 900 RTV
Polaris 570 Sportsman ATV
241 acres of woodland
Re: Venison Sausage
« Reply #2 on: October 25, 2021, 12:18:34 PM »
   We had youth/senior hunts a week ago and 4 days of antlerless gun season last week. I have driven past does with fawns in the pasture every time I went to my stands.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Venison Sausage
« Reply #3 on: October 26, 2021, 08:10:01 AM »
Howard, I've made a little sausage using the same seasoning as shown in your pic!
My question is how much to add per pound of ground meat!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Re: Venison Sausage
« Reply #4 on: October 26, 2021, 08:51:28 AM »
Chuck,
   The recipe was on a sheet inside the box. I think it was one package for 12 lbs of meat, 2 Tablespoons for 3 lbs, etc. I just followed the instructions. I have used this for years and always had good results with it.
Offline Chuck White
Re: Venison Sausage
« Reply #5 on: October 27, 2021, 09:33:51 AM »
Thanks, now I'll have to check the box, I didn't notice a recipe or anything, just 2 packets of seasoning!
Checked, the recipe sheet was laying on the bottom.
Looks good, thanks!
~Chuck~
Venison sausage
Started by isawlogs on General Board
Last post March 01, 2004, 03:22:55 PM
by shopteacher
sausage
Started by LeeB on FOOD! FOOD! FOOD!
Last post January 30, 2011, 05:27:00 AM
by Tom
Making sausage
Started by Raider Bill on FOOD! FOOD! FOOD!
Last post December 06, 2018, 01:14:39 PM
by millwright
homemade sausage
Started by sandsawmill14 on FOOD! FOOD! FOOD!
Last post February 20, 2017, 02:51:21 PM
by sawguy21
