Author Topic: "simple" timber frame porch  (Read 3667 times)
Offline dablack
« on: June 15, 2015, 03:40:56 PM »
Ok Guys!  Here pretty soon I'm going to be putting a front porch on my house http://www.forestryforum.com/board/index.php/topic,73722.0.html.
I would like it to be timber frame if it isn't too rough (hard).  The span between posts is 13' and the posts are 8x8s.  I think the beams are 8x10 (I can't remember right now) and 13' long.  The angled braces can be 6x6 or whatever.  What would be the best (easiest) way to put the braces in?  I have handtools and don't mind buying a chisel if need be.
Is there a book I should buy that will detail the joint?  It doesn't have to be perfect but I would like for it to use as little metal as possible.
Also, I know that since the beams are only 13' long and that is the span from the center of each post, that I'm going to have to use SOME metal to hold them together.  Any hints on how to hide that metal?
thanks
Austin
Building my own house in East TX
Offline Andy White
  • I'm not so new anymore!!
Re: "simple" timber frame porch
« Reply #1 on: June 15, 2015, 05:18:34 PM »
Austin,
When you get ready, I'll bring you my timber framing tools, and my book by Jack Sobon. That will tell and show every thing you need. Also, the threads at the top of this page will help you a lot also. All my chisels are sharp and ready to go to work. Just shout, and we will do this thing.   8) 8) 8) :P :P    Andy
PS>  Tips on the metal, Don't use any. Use a scarf joint for the beam.   Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: June 15, 2015, 06:09:44 PM »
Austin,
 8)
Offline dablack
« Reply #3 on: June 16, 2015, 10:32:34 AM »
Thanks Andy.  I really appreciate it.  The problem with the metal is that my beams are only 13' long (I think) and that is also how far they have to span.  So, not enough length for a scarf joint.
Austin
Offline Brian_Weekley
  • I am Batman!
« Reply #4 on: June 16, 2015, 12:40:22 PM »
Perhaps you could employ wooden splines and pegs to connect them...
For a shed roof, they might work fine.  That would sure look nicer than metal brackets!
e aho laula
    • My homepage
« Reply #5 on: June 16, 2015, 01:42:55 PM »
That would be a great solution to the short timber problem. :)
Offline WmFritz
« Reply #6 on: June 16, 2015, 05:32:12 PM »
Brian, that looks great.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline dablack
« Reply #7 on: June 18, 2015, 09:22:33 AM »
I love it.  That is what I'm talking about!
Finding Timber Frame "Blue Prints"
Started by FeltzE on Timber Framing/Log construction
Last post February 13, 2004, 06:24:55 PM
by raycon
"Foundation" for a timber frame shed
Started by ohsoloco on Timber Framing/Log construction
Last post November 30, 2007, 10:56:30 PM
by Don P
Timber "A" Frame questions
Started by Lost in the Outback on Timber Framing/Log construction
Last post December 14, 2014, 02:43:55 AM
by ljohnsaw
"How much will my timber frame cost?"
Started by Jim_Rogers on Timber Framing/Log construction
Last post March 23, 2015, 03:39:34 PM
by Jim_Rogers
