The mills down again
Started by Bruno of NH, April 03, 2024, 06:06:38 PM
fluidpowerpro
Once upon a time a job at the post office was a coveted gig. My dad use to say that you had to know someone to get a job there. Not the case now.
Change is hard....
Bruno, what repair did you end up having to do? Was your drive bearing shot?
Bruno of NH
Yes all new drive bearing assembly
I will get pictures of the original one
Peter Drouin
customsawyer
I'm thinking that was just bad timing. When I was cutting the metal logs in Hazelhurst I've gone through as many as 30 blades in a day. Cotton picker spindles will take every tooth off of a blade, stall the 55hp diesel and smoke a belt. Never had it break anything else though.
www.thecustomsawyer.com
Bruno of NH
3,400 hrs
I'm wondering if I should order the bearing for the other wheel.
It spins great and is tight
The mill is sawing great
Bruno of NH
I used synthetic atf with the new unit
Quote from: Bruno of NH on May 03, 2024, 07:14:27 AMI'm wondering if I should order the bearing for the other wheel.
It spins great and is tight.....
Personally, I would not.  If it ain't broke, don't fix it.
Southside
Alternatively having those bearings sitting on a shelf will greatly reduce downtime, and the temptation to say "run it, she will make the rest of the day" should those bearings fail.  The idle side are pretty cheap.
I've got one on the shelf myself😊
So do I.
I mistook Bruno's statement as he was gonna go ahead and replace the other side, thus my "if it ain't broke" comment.
