Iron Inventory
Started by Ron Wenrich, January 25, 2006, 08:16:49 PM
pyrocasto
Home made bandmill Mostly electric. Temporarily manual dogs, stops, and guide arm. 40" cut, 48" log max. Havent got the chance to try anything larger than 16" so far.  :'(
junkorgem
Yes pyro, nice work. I've been following your build from the diy site. Very impressive. I've been meaning to ask you, what size blades are you running? And where do you buy them? Gotta be close to 20'. Very nice work. Update?
lumberjake
we run an old as dirt 5 headblock 00 frick hand mill, with a frick 2 saw edger and a home made swing saw and a montgomery hog
It's run off a detroit diesel and we run berry feed. Four strand log deck with mellot 5 log turner. I need to get some pics on here we still run equipment we bought new in the 70's.
357blacksmith
Log Master LM1, Farmtrac 665 fel
Log Master 1, Farmtrac 665, Champion forge, Peter Wright anvil, and 5 Bassett attack-and slobber dogs.
haywire woodlot
1983 mobile dimension model 128, I bought it in pieces back in february, with the engine full of water and fir needles. Got the engine running and throughly flushed out in the beginning of March, ordered a grand worth of parts and assembled in in early april, got it cutting last week and finally cut 2000+ BFT in the last 2 days. I love my mobile dimension saw!
Dave
downunder Trav
2011 model ms660 magnum 36inch and 42 inch bars, Gb lumber mill, rail mill similar to the wombat mill (home made), home made alaskan style mill, 1991 034 stihl with 18 to 25 inch bars, currently rebuilding this saw as it poohed a crankshaft bearing and spun the bearing in the crankcase requiring some fancy building and machining. Last but by no means the least I am designing a dedicated slabber running a vertical shaft four stroke, plans at this stage are for around 50 inch bar but in time will get a bigger motor and bar.
want list consists of a lucas and maybe a woodmizer lt40, but this will probably remain the want list for a long time.
any one with a basket case 034 let me know please.
I am a weekend warrior with a chainsaw, But the collection is starting to grow, Dedicated slabber here I come!!!!!
GAmillworker
Baker bbx resaw and a lot more
Thank the Lord for second chances
lunkan
2010 Norwood MX34 bandmill sold by Logosol in Sweden
With 3-phase twin electric motors
acco1840
Hand circular Breast Bench mill. 42 inch  chrome saw, 120HP BMC Diesel, 80ft flat belt, Dawn sawdust blower.
davey duck
Turner bandsaw 24 hp Honda,now building hydo-electric bandsaw,John Deere 260 skid-steer loader,PJ24' trailer and 3500HD chevy truck.
David G.Fleming
Chuck White
Quote from: Chuck White on October 30, 2008, 09:38:34 AM
I got my Wood-Mizer LT40HDG24 on May 3rd, 08 from "petefrombearswamp", and since then, I've sawed just shy of 70,000  bf, operating mobile.
Almost ready to pull the plug on it for the season and do any required preventive maintenance through the winter.
I'll have it parked in the back bay of my garage, as soon as it gets home.
June '09, I got a Cooks Cat Claw band sharpener and single-tooth setter.  Have it all set up in a corner of the garage!
edit 10/10: Forgot about my trusty STIHL 021 for removing the troublesome knots.
EDIT:  May 8th 2011, I bought the matching Shingle & Lap Sider (SLR) for my LT40.
Now I just have to learn how to use it!
mometal77
Do you happen to have pictures?
Too many Assholes... not enough bullets..."I might have become a millionaire, but I chose to become a tramp!
oklalogdog
Foley Belsaw M-14.  36" fixed tooth blade.  30' frame - PTO drive -everything works great.
Amateurs built the Ark - Professionals built the Titanic
TK 2000, TK 1220, Belsaw M14, John Deere 7610 with loader, Ford 9N.
shelbycharger400
1978 belsaw 40 in insert tooth belt drive with full feed.  , just got it home in pieces.  previous owner used it once for one log :)
Home made dedicated wide chain bar slabber . 29 in wide capacity (soon to be done)  for stumps, shorts , ect
stumps seem to be the hardest to saw and sand, but have the best character.
Log-ic
I am running an Italian build Pezzolato HD8, it has a 28kW lombardini turbo diesel engine, forged steel bandwheels of 800mm diameter and uses 54mm (2") wide bands of 5740mm length.  It can handle logs of 90cm (35") of diametre and 6,10 metres long (20ft).  All functions are hydraulic and computerized.
Pezzolato HD8 40HP diesel (2" bands) and Pezzolato MP-800 40HP Deutz diesel (4" bands)
Avant 635TDL articulated loader with various attachments
Loroch JLM-V sharpener, manual saw setting pliers
Vollmer VWM planing bench and rolling machine
Husqvarna chainsaws...
Welcome to The Forestry Forum, Log-ic.  I also appreciate your efforts to convert the metric measurements to inches and feet.  It doesn't seem to matter how old I get, I just can't get the hang of metrics.  :D
dukndog
Welcome Log-ic!!
I worked for a company in Belgium a few years back, located in Lier. As Tom said, thanks for the conversion!!! We still use metric parts for our equipment, but as Americans, we tend to always convert it back to standard.
DnD
WM LT-15G25 w/PwrFeed, Mahindra 3510, Husky 385xp, Stihl MS261 and a wife who supports my hobby!!
wmcbrian
I'm using a Timberking 200 with a woodmaster 718 planner / molder
bigen
Quote from: Ron Wenrich on January 25, 2006, 08:16:49 PM
Looking to see what folks are running.   Feel free to add your mill to the inventory list.  More than one mill?  No problem.  You have multiple votes.
Im going to get my first real sawmill saturday at the farm show in pittsburg, ks.   its a e z boardwalk 40 im really looking forward to it
paul case
welcome bigen. glad to hear from you on here. pc
pc
Meadows Miller
Gday
And Welcome to The Forum wmcbrian & bigen  ;) ;D ;D 8) 8)
Paul There is afew of You EZ Boys Now Carpenters got one too  ;) I might have to start calling you the EZ mafia ;) :D :D  They look a good little mill I reckon Ill have to swing by and have a catch up with you and have a play on your mill while im there Paul  ;) ;D
Quote from: bigen on July 13, 2011, 10:50:27 PM
Ill have to put 3 more votes in for Hand Circ then  ;)  :) :D  The old 8-20s getting picked up by My Mate tomorrow though  but its good to see him getting it no sawyer should be without a mill  ;) ;D 8)
Regards Chris
4TH Generation Timbergetter
jdsawmill
Duane
paul case
you are welcome to come by an we will saw some. too hot now to saw too much so i bet you can get your fill!  pc
pc
CalebL
2005 Woodmizer LT40HDD34 with a debarker and simple set works.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
downeastmark
2010 Timberking B2000, all hydraulic 34 hp kohler engine and TK's computer set works.
