Next job for us?
Started by OlJarhead, January 28, 2014, 11:22:55 PM
OlJarhead
Got these pics sent to me for a job locally
Not sure but I think those are cottonwoods -- I'm not that knowledgeable about different species yet
Guy likes my rates (hourly) and will load via tractor which is nice with those logs.  He wants the forks when possible and most of these are 15-22" in diameter.
Looks like a challenge (and a long weekend of work!)
Whatcha gonna try to make outta them?
Jemclimber
I think he's sawing them for someone else so he's probably going to try to make $$$ out of them.   8)   Just teasing BT.  :D
From my little screen they look like walnut, but it's hard to tell, they could be cottonwood. I'm not sure what someone would want cottonwood crotches for, but to each his own. I hope the job goes well for you.  I think cottonwood makes nice looking paneling when it has figure.  Good luck and let us know how it goes.
lt15
arkansas
I would say mostly walnut too.  Could be wrong but sure does look like it.
Working on a hot LT40HD for now
OlJarhead
Hmmmm....Walnut would make me more $$$ that's for sure, but it would take a LOT longer on my LT10! lol
We did one Cherry that was 22"x39" (or so) and charged the guy two hours to do it (first job at $50/hr) and milled him the whole thing in 1x' part live sawn part 1x15"s as the log was just too unruly to stay put without making it into a CANT after a while..that log also required that I whittle it a bit with my chain saw and of course being that small was a bit tough to hold onto.  I think the job was 90 minutes and we replaced two blades.  One that got knocked off because a roller hit the log where it protruded out too far and one that just got dull.
My thinking is that 4-6 cuts on a Walnut log will 6-8 feet long will take me 20-30 minutes per log but that's a sheer guess.  I suspect I'd be going all weekend!
As for the end product, I think he wants to use the 3" slabs for table tops etc but I'll meet him on Saturday to find out.
dboyt
Glad you're working that job by the hour!  Clamping is going to be a real challenge on those pieces, but if you cut live edge lumber, you should get a fair yield.  I've had a few jobs like that, and the customer was thrilled, even though the milling came out to close to $2.00 per bd ft.  Looking forward to photos.
OlJarhead
Turns out it's black walnut and he doesn't want the whole load done, just the longer and straighter pieces.
OlJarhead
Met with customer and it looks like the job will be 2-3 hrs of milling.  Going to mill the biggest stuff and then see how it goes.
Might get some walnut out of the deal.
drobertson
It should saw out pretty easy, I kinda like sawing walnut, just has a peculiar aroma,  david
That plus it is neat to be able to watch the lumber color change, almost immediately.   :)
OlJarhead
Can't wait to get at it!  Just pulled the mill down off the mountain :)
OlJarhead
Hmmmm tried to post a vid from --Photos MUST be in the Forestry Forum gallery!!!!!-- but I guess I have to upload to youtube :(
OlJarhead
OlJarhead
Chuck White
Looks like you're doing a fine job.
justallan1
Great videos, Eric.
Didn't you upgrade to a bigger engine? I sawing some dried logs yesterday, thinking I sure need some more power. :D They came close to being called firewood.
Allan
OlJarhead
I upgraded to the 10hp option.  WM doesn't offer more power than that nut I could probably go bigger if I wanted...but if I am to do that it will be MUCH bigger!  Think LT40HD
OlJarhead
First log on the deck and getting milled.
Most of this stuff was live sawn and with many crooks and knots -- the gentlemen wanted unique stuff to make tables etc out of
I found the walnut not really that tough to mill.  It was tougher trying to get past the odd shapes!
Some logs were a real challenge on the this small mill
But we made it work ;)
The main customer is a local woodworker and shows and sells his stuff in a gallery, he's already looking to have some more trees milled...seems the $11/foot for planed walnut vs paying me to mill some for him has really gotten him into it.
I calculated just over 500 board feet milled in 3 hours so with a 1hr setup and at my rather cheap (still) $55/hr rate he got 533bf of black walnut for $220 or $0.41/bf
Ya, that's better than $11 ;)
Peter Drouin
Good job, But after a while milling you want more mill then more mill . so if you jump on a bigger mill jump high.  :D
A&P saw Mill LLC.
License NH softwood grader.
Exactly Peter.  You do not want to have to upgrade again or retrofit options.
Happycamper
jarhead,
  Last summer I re powered my 10 with a 12 1/2 HP Briggs w/electric start 110V. The difference with this engine is quite noticible compared to the 10HP which I kept as a spare. The footprint is identical to the 10 so did not have to do anything but reinstall the four bolts to hold it in place.
                                Jim
Wether you think you can or you can't you're right
OlJarhead
Thanks happy -- if I decide to just go bigger motor I'll try that.
So far the 10hp works pretty well for this small mill and I've produced good numbers with it but frankly, the next upgrade may well be something MUCH bigger ;)
OlJarhead
OH and I'm a 'real' sawyer now!  :D ;D
I'd left the log dogs up on the mill past the log I was milling......(and you know the rest right?)....
Two feet past the end of the log no less!!   Cut half way through a dog before I could stop the head!  BANG!  I was leaving the blade running, I do that a lot, and pushed the head well past the log to clear it for a roll....was going to shut down the band even (always do when rolling)....
Oopsie, no more band.
Quote from: OlJarhead on February 16, 2014, 06:19:40 PMbut frankly, the next upgrade may well be something MUCH bigger ;)
And then you could saw the log clamp or side support completely off.   :-\    :D
LittleJohn
Quote from: OlJarhead on February 18, 2014, 08:57:31 AM
Did you not read in the owner's manual, you have to have the "SPECIAL" blade if you want to cut metal  :D :D
Being perfect is OVER-Rated
