I blew a 23.1-26 tire on my 540A skidder. Where do they sell the cheapest skidder tires? I just work one month per year with the skidder and its in plantation wood, i rarely dirve ower a stump or stone. Can i use ag tires? or is there something between the forestry and Agricola tires?
I really can't spend 5k on two new firestone tires
just the shipping to costa rica will be 1000$ :(
Thanks for the help
I'd say you could. My front tires are ag tires off a combine. The ply rating isn't as high but like you said if you keep it off the stumps and rocks it should be fine. That's just my opinion but I'm new to this. My skidder is a 440b
I had 2x ag 18.4x26 on my 440D on the front for yrs, rock finally did one in. For what your doing I wouldn't sweat it at all.
sure, i am runnig one now. get 12 ply though, the 8 ply won't stand it.
Might have BKT tires in country with Importadora Ad Nat S.A. BKT have 10 types of 23.1 - 26 size listed 10 ply to 16 ply.
https://www.bkt-tires.com/en/pattern/fs-216
Thanks for all the replys
Yes we have bkt, they have 18.4-26 forestry tires in stock but won't import 23s. they have lots of different 23s ag tires from 10-18plys but a 12ply ag tire is 1250$ :o. for that price i just spend a little more and buy a cheap forestry tire in the states.
lol, i thought you meant used. i have got some nearly new 28s off blown up combines. one actually had a new forestry tire on it.
Like Barge kind of hinted at there if you go that route put it on the front. Winching in a big load might be enough to buckle it on the back. On the front though I would speculate it would last indefinitely if your really not running over rocks and such like I'm used to here in New England.
That'd be my 2 cents. On the front I would bet you'd be fine.
On a related issue I'm curious about though. Are there ag tractors that run a 23.1x26 tire? I'm no expert farmer guy.. or expert anything really but off the top of my head I wouldn't picture that size tire being a normal ag-thing. Maybe on a huge spreader?
combines used to run 23 and 28s. most run 30.5 size now days. good used tires will soon be non existent. i did see a set of nearly new 23s on sprayer rims at a sale, but i was to late. think they went around 12-1500 for the 4. still had teats on um, 12 ply.
i agree, i run these on the front only.
How much is a ag tire in the US and where can i buy them?
Quote from: teakwood on June 13, 2017, 08:06:41 AM
I can call tomorrow and find out what my tire guy is getting and what he has. I assume the cost to ship a tire is the same ?
Thanks Eric
The shipping will be the same amount from Miami to Costa Rica for a ag or forestry tire but the shipping from NY to Miami would be high. I will have to search around Florida, Georgia, Carolina so i can minimize internal shipping.
Of course all depends on the tire purchase price.
Did the tires came down in price?? Look what i found. Was a firestone forestry 2500$ a year ago???
http://www.petestirestore.com/231x26-Firestone-Forestry-Special-Tire-With-CRC-LS-2-14-Ply-TT_p_6246.html
Go to "machinerytrader".com, go to the bottom of the page and look on "tires" in the parts section, go to page #21 and there is 6-8 23.1 tires listed, both new and used, nice set of Firestones for decent money in Florida right now. 👍
I'm getting a quote on BKT forestry tires in a few days.
the Tr-135 i can get in 18plys for 1050$ each here from a dealer. it was recommended from the seller ::) ???, but it seams to me they may be to weak.
https://www.bkt-tires.com/en/pattern/tr-135
Would you put 2 new tires in the front (where the skidder is alot heavier) or in the back? i don't haul very big loads. my old tires are Firestone forestry's at 50% but pretty ruff, lots of cuts on the sides and they are 17 years old.
Another question: the ag tires seems to be tubeless? will they hold air? my rims are pretty ruff too, of course i will clean the rims in the inside
ag tires on the front if you have a choice. they will hold air tubeless if you clean the rim well at the beads, but slivers will get into the bead and cause leaks.
Buy a case of ether
Beyond patching?
ether for what?
Can i put tubes in a tubeless tire? just to make sure
As soon as I have trouble with a tubeless tire on my tractor a tube goes in. Tractor tires should not be tubeless. ::) Maybe if you put 100 hours a year on it,tubeless is fine.
ok, thanks
i will definitely put tubes in
Quote from: teakwood on November 03, 2017, 08:08:45 AM
ether for what?
Reseating the tire onto the bead after it leaks down over the weekend.
and if i'm buying forestry's? put them on the back or front?
i always try and run real skidder tires on back if i only have two, combine tires on front.
note about tubes, i have had terrible luck with combine tubes splitting. if you can try to get natural rubber tubes.
what does combine tires mean?
i am certain that such tubes i would have to order from the US.
here i can just get normal ag tubes for around 100$. will they hold? or should i buy really forestry tubes?
After a couple of hard learned lessons, I had to go with forestry tubes. :(
Quote from: teakwood on November 04, 2017, 12:25:19 PM
combine/ag tubes are not natural rubber......i'm not sure what they are made of but they are thin and don't seem to last long in the woods. its better than nothing in a pinch. natural rubber are thick and last a long time. i think it has to do with the amount of flexing our tires go through. natural rubber are twice as much and hard to find.
thanks a lot guys for you help.
Firestone makes natural forestry tubes at 165$
http://www.petestirestore.com/231x26-to-75055R265-Firestone-Natural-Rubber-Forestry-Tire-Tube-TR218A_p_6187.html
Here at least , ag are 8 &10 ply combine 12 and forestry specials 16. The old rims caused ware holes in the tubes from rust etc. tried cleaning rims only temporary help. The natural rubber tubes are about 300. Combine tires run 1000. To save the tube when a flat occurred in the woods I changed it right there. The combine tires were much easier to do by yourself than the forestry specials. Need spoons 2 long and one short . a large jar of vasiline for tire lip and rim . Had to lug an air pig. Biggest issue with the combine tires were punchures in the side. Usually from me not cutting square. Found the ag tires did not work for me. The clearing saw seemed to end the punchure problem. With the net forestry tires seem to be passing through middle men making them more expensive. Tires or lack thereof played a part in selling my skidder. Did not mind the tire change in the summer but in deep snow it was a pita. Good luck with what you decide. Should add forestry tires with natural rubber tubes installed about 2500 each. Skidder was 38 years old and still working.
A lot of money for tires [ the good ones] would have less down time than the cheap ones.
For me, I'd go with the 16 ply forestry and they would last for years, Chained up would last even longer.
It's what the guys I buy logs from are doing.
