3 point hitch splitter question
Started by gspren, March 26, 2013, 09:27:58 PM
gspren
  OK, I got it all figured out now that I got an operators manual. There are 5 drain plugs on the bottom and the Hyd drain and the pto clutch drain both looked like possibilities and when I first tried the hyd drain it looked thick and black while the dipstick showed clean which made me stop after the first few ounces thinking gear oil. Now that I knew which plug I tried again and the first 2 quarts or so were black and then got clear so I was really over due to change this. After changing the oil I hooked up the splitter and was pleased with the operation, I only split for about an hour but it worked. At a bit over half throttle the ram takes about 9-10 seconds whether splitting something or not and that's fast enough for this old man, if I had a helper I'd rev it up some. After splitting I felt very little heat in the lines.
