DIY powerfeed
Started by Skidoojustin, November 27, 2024, 09:42:52 PM
Skidoojustin
Hey all, I need some help. Im building a power feed on my lt15 using a wheelchair motor and a drum and cable, much the same as the rope feed and crank it originally came with. The motor is off a jazzy 1120 power chair and is a fairly large motor. Running on 12v.
The problem I'm having is the saw head only starts to move a 90-95% and is wide open at 100% which is making the saw head hard to control. 100% is much to fast. I'm using a 10-55v 60amp PWM. Is it because I'm running 12v instead of 24v or is something wrong with the PWM. Most videos of power feed builds, the saw head will start moving at 30% or so on the PWM. Any help much appreciated.
2005 Woodmizer lt15. International harvester 384
barbender
Was the Jazzy motor designed for 12v or 24v?
Skidoojustin
The power chair was 24v. The motor itself doesn't say. Model number on the motor is E675
ladylake
  If its going way to fast try gearing it down.  Steve
Before trying to otherwise control the motor speed, I would match the motor to the correct voltage.
fluidpowerpro
Change is hard....
Local wind direction is determined by how I park my mill.
jpassardi
I made the same setup for my LT15 and it works well. Jazzy motor (not sure if same model)  running on 12V and the 60 amp PWM. The drive pulley is about 4". I can slow it down more than enough. What size pulley or sprocket are you using?
BTW: I had to replace the cheap rocker switches that the PWM comes with.
I use a dump truck tarp gear motor and a PWM to run my up/down.
Skidoojustin
I'm very interested in seeing your setup. Im hoping to spend some time this weekend trying to figure this out. The motor is running plenty fast on 12v at 100% the return is about right. Just having trouble controlling it with the pwm. The motor is a drvmotr1116 hi-speed. Model # E675. When I turn the pot the motor only starts turning at about 90-95%. I'd love to see pictures of your setup.
never finished
I set mine up to saw in reverse and gig back in forward. They tend to reverse slower.
ktm250rider
I have a similar issue running my motor at 12v.  Im wondering if its the motor age as it was purchased used through Ebay.  Im also running a reclaimed from the dump battery which doesnt hold a charge for too long.  If i hook my jump box the motor seems to have more control.
I did just learn about 12-24v up converters that i need to wire in and see if that helps.
fluidpowerpro
I was watching a u tube video this morning of a guy that used the wheel chair motor for his power feed. In it he comments that "it worked a lot better" after he went to 24V. He didnt elaborate any on the "better" part. He pointed to a 12-24v step up boost unit he had installed. I did a search on ebay and saw what looked like the unit he used. Its a unit intended for use on golf carts. Its only rated for 10 amps which in my mind would be suitable for charging, but it seems small for a drive. Its only $18.00.
Sorry.. going off board a little here, the reason is that my mill will come into the shop shortly for winter upgrades.
This year one of the items on my list is to add power feed.
Reading this thread has given me concern that although some people have had success running on 12v, I think 24v would be better. I suspect thats why some arent getting much range of speed adjustment that is desired. For that reason I think Ill use a 12-24 v boost unit.
These are the 2 voltage booster units noted above.
The cheaper one that the U tube guy used.
https://www.ebay.com/itm/146042169822
The one I plan to use.
https://www.ebay.com/itm/176063233068
After some time using my mill I have found that although I can get something to work, it becomes a matter of how long.
Although I do saw for hire, I'm not hardcore like others. I put about 100hrs a season (May thru October) on my mill. Even at that, I have found reliability of components can be an issue so I will spend a little more on a heavier duty unit, even if I have found the lighter duty will work.
One example is the PWM units. For my raise / lower winch, I started by using a unit rated for 30 amp continuous / 60 amp intermittent, and it works fine, but not very long. I found I would have to replace them after about 30 hrs of use. I have since switched to one rated for 60/100 and so far it has lasted a year with no issues.
Thats my plan for the power feed.
I would welcome any comments from others that have experience in this area.
Change is hard....
jpassardi
Here is how I did mine:
Not sure which used Jazzy motor it is but I have a couple hundred hours on it run by the 60 Amp PWM & 12 Volts. No issues other than replaced the cheap rocker switches it comes with.
I kept the original rope/pulley setup the LT15 crank used. At some point I plan to upgrade to chain/sprocket drive because it can slip if rope is wet.
I used a PVC electric box and made the front label in AutoCAD and laminated it.
As I noted above, the up/down I made uses a dump truck tarp motor also run off a 60 Amp PWM and 12 Volts.
Both work very well and adjustability in speed is key.
Edit: Forgot to mention I placed limit switches on the carriage to stop it at max travel distance going forward and in reverse.
ktm250rider
I got the cheap one, still in the box waiting to install.
fluidpowerpro
I'm anxious to hear how it works.
Change is hard....
jpassardi
Like I said, the only issue for me was the rocker switches failed so I replaced them with HD toggle switches.
One annoying thing with those PWM's is that they use tiny wiring to the switches so a pain to terminate and are fragile.
ktm250rider
Quote from: jpassardi on December 04, 2024, 12:56:32 PMLike I said, the only issue for me was the rocker switches failed so I replaced them with HD toggle switches.
yeah, my master switch just broke this weekend!
fluidpowerpro
Quote from: jpassardi on December 04, 2024, 08:49:55 AM
Have you ever found that the ability to slip is a good thing?
One thing I have concern about is what happens if the mill hits an obstruction. When I'm pushing the mill by hand I feel it and can stop to see what the issue is.
With power feed I wont be able to feel it and worry that bad things could happen.
Im planning on including something in my design to sense an obstruction before any damage is done. One idea is to mount the idler sprockets in some sort of swivel set up that is spring loaded. If the mill hits something the chain tightens and the idler swivels and then trips a switch.
Change is hard....
jpassardi
FPP: You're on the right track - Yes, I have found that useful. That's one of the reasons I haven't yet gone to a sprocket/chain setup. Though, you should be right near the controls when feeding anyway.
Mine will slip if I run into something like a barnacle I need to trim which is good. The downside is it sometimes will tear up the elastic band I super glued to the pulley for rope traction. Not a big deal, happens rarely, scrape it and glue another on quick but it is a short delay.
What you're proposing could be done with one of the same limit switches wired to the feed side of the PWM. The key will be getting the right spring rate.
rusticretreater
Quote from: fluidpowerpro on December 04, 2024, 08:13:41 AMI was watching a u tube video this morning of a guy that used the wheel chair motor for his power feed. In it he comments that "it worked a lot better" after he went to 24V. He didnt elaborate any on the "better" part.
A motor can operate at both 12 and 24 volts by being designed with an internal winding configuration that allows it to adjust its current draw based on the applied voltage, meaning the motor can handle different voltage levels without damage. Running at a higher voltage will generally result in increased speed and power output.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
doc henderson
Mine drives a chain and sprocket with a hydraulic motor.  if it hits an obstruction like a loading arm up to high, it pulls the motor a bit and bypasses at the valve. so, I hear it and stop.  it does not wreck anything on the mill.
mroldstyle
FluidPower,
are you using the sawmill battery for your raise and lower and also planning on using it with your travel motor? Does the alternator keep up the battery or are you using a separate battery, and if so, how are you charging it?
fluidpowerpro
Currently the raise lower winch is run off of the battery and I'm planning on running the power feed off of it also. My 16 hp engine has a 15 amp charging coil. I do have concerns that the charging system won't keep up but Ive asked around and the concensus is that it should be fine. I guess I will find out.
The battery I have now is just a small lawn/garden tractor size so I do plan on changing to one that is larger.
Change is hard....
mroldstyle
Thanks, I think I will follow your lead. I have been running my travel motor off mill battery w/o problems, but now I'm adding a lift (tarp motor) and was concerned it would be too much. I will probably bump up battery size also.
jpassardi
Re: Running both motors off mill battery: My 25 HP Kohler has only the flywheel charging coil and it maintains no problem. The old 15 HP did as well. I do have a battery larger than a lawn mower one but not car size, 500 CCA I think.
The feed motor will draw more the up/down as it runs semi-continuous. Up/down is intermittent.
fluidpowerpro
For those with power feed, I have a question.
I'm on the fence about how I will do the controls.
When using the power feed are you required to remain at an "operators position" or do you walk away?
Is the ability to walk away important to you?
How often to you walk away vs stay at the controls?
Currently I'm leaning toward the ability to walk away but wanted to see what others do.
Change is hard....
