Wireless remote control
Started by peterduncan, September 10, 2008, 04:02:43 AM
peterduncan
I have a 2007 Timberking B-20 mill that I would like to replace the reel that handles the up and down of the head with a wireless remote control unit. I have heard of this being done, but I do not know what product they are using. Help! Help! I have learned that I might be able to use a remote for a winch.
Radar67
Pineywoods was working on a remote unit for his saw. He can tell you where to get the relay kit.
pineywoods
Yeah, I have a wireless remote control system still under development on my WM LT40. What's holding me up right now is getting a homebuilt auto-clutch working. Head up, head down, arm in and arm out are fully functional. I have all the stuff needed, just too many other things going on. It uses an infared control. The remote control head looks like a tv remote, fits in my shirt pocket. It's 12 channels, the outputs are all relays, so it's fairly easy to interface to the mill. Cost about $70 in kit form. Available fully assembled and tested for a few bucks more, which I recommend. The kit is a real booger, even for experienced electronics types.
www.electronics.com
I have no connection with this firm, other than being a satisfied customer.
BTW, they have bunches of other goodies too, dc motor speed controllers, stepper motor controllers etc.
StorminN
pineywoods,
Do you have a more specific link?
Thanks,
-Norm.
Happiness... is a sharp saw.
Radar67
Here are a couple of pictures of what it looks like...
cheyenne
That is a great idea. My only question is which channel gets NASCAR. Cheyenne
Home of the white buffalo
pineywoods
Quote from: cheyenne on September 10, 2008, 07:55:52 PM
The one that goes fast forward while the backstops are still up  ;D
schmism
ramsey (of like the winches) makes a wireless remote control add on for your winch
OFFSITE IMAGES NOT ALLOWED PLEASE READ FORUM RULES
all it does is take the in/out remote signal and activate a relay that closes the right contact as if you were holding a wired remote in your hand.
should be a simple addition to run a larger relay for a 12v motor.
039 Stihl 010AV  NH TC33D FEL, with toys
StorminN
schmism,
Surplus Center has had some like that for sale lately...
3 Channel wireless remote, $49
-Norm.
ladylake
I had a wireless remote to operate my throttle for a while on my B20, it worked good but those small buttons were hard to run with gloves on. I found a 6 wire industrial cordreel which I use to run the setworks (which always work now) a remote trottle run with a toggle switch and a power up and down log dog. After having a remote throttle it's one thing I wouldn't be without anymore.  Steve
pineywoods
I posted a bad link for the source for remote controllers
Here's 2 places that have them.  www.electronics123.com
www.electronickits.com
pineywoods
OK, finally here is the full skinny on my wireless remote control on my manual WM LT40.
I used a 12 channel infra-red controller from www.electronickits.com. cost about $80 fully assembled. Available in kit form a little cheaper, but don't... Mounted on a sheet metal bracket screwed to the top of the control box.
closeup of the control board
The actual sensor is inside that round piece of cardboard tubing. Did that to cut down on the field of view.
Here's the back side
Looks complex but really isn't. 5 heavy relays to handle the current requirements of the mill electric motors. The output relays on the remote control board are only good for 10 amps, so  use them to actuate a bigger relay that controls the motors.
Here's the remote, fits in a shirt pocket
Button 3 raises the saw head
Button 4 moves blade guide in
Button 6 moves blade guide out
Button 9 is carriage forward
Button 10 is for autoclutch (more on this later)
button 12 is carriage back
button 14 resets everything (panic button ;D)
Everything else is available for whatever goodies I might think up.
Changes to the mill?? almost none..
One jumper wire on the up-down drum switch removed
Micro switch mounted on the side of the control box and a notch filed in the fwd/rev handle
This is just a safety interlock to prevent control box in fwd and remote in reverse mit sparkenflashin und fusenpopen.
Hole drilled in the bottom of the control box to feed wiring thru.
Look closely, I didn't have to drill a hole, there was one already there, rusted thru  ;D
That's all there is to it. All the original controls work just like they always did, manual over rides remote in case of conflict.
Cost....I had a well stocked junk box, but with all new parts this project wouldn't run much over $200
WH_Conley
Which button lowers sawhead?
Wouldn't do me any good anyway, my fingers are so big I would be doing three things at once anyway. :(
Bill
pineywoods
Quote from: WH_Conley on November 10, 2008, 10:39:14 PM
I had button 1 wired for head down, never used it, so I took it off. One less thing to go wrong ;D
milling man
Quote from: ladylake on September 11, 2008, 06:01:20 AM
How did you hook the remote up? and where did you find the industrial cord? mine has been messing up ever since the warrenty ran out
pineywoods
I been informed if no pics, it didn't happen. So belatedly, here is a video of the wireless remote on my manual LT40 in operation. If it looks a little slow, that's because it was. Cuttin a big ole ERC that's been in my log pile for over a year. It's kinda hard. Now the dry cedar sawdust don't bother me much. But Oooohhh  for a setworks.
http://www.youtube.com/watch?v=aFbKpEpFvck
You got a lounge chair and a glass of lemonade ???
