Porch Decking & Overloaded Trailer
Started by Magicman, March 13, 2024, 05:15:59 PM
Resonator
When I grow up I want to be like Magic Man! ffsmiley
When you build something yourself, you know how it was built, no cuttin' corners. :thumbsup:
(Except on all that diagonal part). :wink_2:
The second tier is floored so I'll count it as a success.  ffsmiley   So now I am removing the flooring from the final tier.  Although it is the smallest, it will be more difficult because I will be reducing the size which will take additional time.
doc henderson
Looks great!...   I mean bout time!  :usa:
The odd shaped 9X12 lower tier as it is now.
The right hand portion with the decking removed will be removed.  The finished lower tier will be a 9X9 kinda trapezoid with the near corner removed for the steps as seen above.
Gotta be careful with that rotten deck to keep PatD from stepping through.....again.
gspren
Could just tack some old license plates over the holes to keep a "rustic" look.
Yup, that might work except there is nothing to tack to.
Looks like I did not do much today but there is so much left to do.  I did get the right side where the green paint was yesterday cut off and squared up.  I also used the HiLift jack to remove two piers and I will have to add two in the correct places to replace them.  Tomorrow I will tie the near right corner in and hopefully lay some if not all of the 2X6 decking to the lower tier.  Gotta build new steps.
The tree service guy came by this afternoon and gave me a price on removing the Red and Post Oak trees.  I am needing the Post Oak logs to supply the material for my new railing.
The forecast is for some rain tonight and clear tomorrow, so maybe I can keep on keeping on with this project.
It does not look like I did much but I put in a hard day.  Nothing that strenuous, just continuous.  Thankfully again there is negligible structural damage nor rot but I did have an instance of termite infiltration on the steps and the rim joist above the steps.  IMG_5444.JPG I will rebuild the steps and replace that joist next.
The three boards on the left are not attached and are serving as my walk boards.
The weather forecast shows rain Monday afternoon and gone by Tuesday morning so maybe I can soon finish this project.
JD Guy
MM You're making me feel guilty  ffcheesy Guess I need to get off my *** and get mine done
before full blown summer gets here!
For now I have put the sawmill and sawing jobs on idle until I finish this.  I am telling folks that I am on a job, and I am.  I will have the deck done before Easter but it will not have railing nor a roof yet.
I made nice progress on da steps today between other interruptions.
I should finish flooring the deck tomorrow.   :thumbsup:
Bill Gaiche
I bought decking materials last week and found the quality was poor compared to years ago. I went with the premium stuff in order to having fewer knots. bg
doc henderson
magic I wish I lived closer.  I bet you are a lot of fun to build a deck with.  I might even learn a thing or two!
I initially wanted to use White Oak but I did/do not have a source so hence the option to use the normal 5/4 X6 or 2X6's.  The 5/4 was mostly pith wood with wide growth rings so poor quality.  The 2X6's are all #2 side lumber with much tighter grain.  Since I got the "contractor's" price, the 2X6's were the same price as the 5/4 would have been.
When unloading I was concerned about maybe it was from bug killed trees with open knots but this concern has proven to be a non issue.  Only one tier used full 12' boards while the other two tiers have shorter sections plus the steps so I have been able to work around and still utilize the two boards that would have otherwise been unacceptable.
My railing is still standing in tree form, so no railing for now.  Since I began this rebuild project I have also decided that it will be completely covered with a roof so this deck will become a porch.
DSCN0456
Good Morning Bill, it's good to see your smiling face.  Bill is one of the FF members that has actually seen this deck and we have had the pleasure of feeding him several times. ffsmiley  He is seen above in the center between Paul Case on the left and our late FF member wwsjr (Willie Steele) on the right.
This morning's rain should be gone by 10:00, so I can get back to work.
After the rain moved out and even with the interruptions I still managed to finish the steps and whatever else needed to be done before the decking can go down on this lower tier.
I'll paint the CopperCoat on the joists and nail-um-down in the morning.  I am looking forward to laying this little project in my taillights.
One thing that has not been settled/decided yet is the skirting.  I just know that it will not be wood because I had a few instances of termite intrusion before with the Cherry skirting.  Maybe some kind of mobile home skirting ??
61.
doc henderson
or aluminum soffit.  or foe brick board to match the house.
I have taken pictures of the brick, both in the shade and sunlight, to try to match whatever needs matching.
61.
I done did it or maybe did done it:
The lower tier is complete.
A different view showing the three deck tiers.
The three tiers plus the step up onto the porch.
So railing, skirting, and a roof is next.  I have two metal roof contractors coming tomorrow; one tomorrow morning and the other tomorrow afternoon.
61.
Old Greenhorn
You done did! ffwave Looks great Lynn! I like the design too, even that was established a while back. Now you can enjoy it, between sawing jobs. ffcheesy ffcheesy
Thanks Tom, yup over 20 years and maybe I am finally getting it right.  At least I know that it will outlast me.  ffwave
61 is coming.
Old Greenhorn
Yeah, I noticed that '61' thing, what is that all about? Did I miss something?
doc henderson
I was wondering too.  I think y'all been married longer than "61" years.  as I recall you left home, and you and Miss pat ran off and got married fairly young.
Resonator
Early congrats to the love birds on their anniversary. :wink_2:
Southside
Iffin you put up skirting where will your hound dogs lie?  ffcheesy
White Oak Meadows
doc henderson
If it is short shirting, be sure to put hose under there. ffcheesy
Quote from: Old Greenhorn on March 27, 2024, 08:05:53 PMYeah, I noticed that '61' thing, what is that all about? Did I miss something?
61 ain't here yet but it's coming.  ffsmiley
