Bridge-Ramp-Help
Started by etat, December 22, 2003, 07:46:23 PM
etat
Trying again.  Been trying almost two weeks to shrink this Dang Picture.  This is what I need to connect two rooms in my house.  There will be a curved stairway beneath.  This needs to be 9 feet long, crosing a 5 foot open area over the stairs, and needs 10 inches rise for headroom underneath, and appx. 4 feet wide.  I havn't yet figured out a way to get curved beams, other than laminating boards together.
Old Age and Treachery will outperform Youth and Inexperence. The thing is, getting older is starting to be painful.
Jim_Rogers
The problem I've having while thinking about your project is the width being 4'. If this is what you want you'll have to have very thick deck boards in order to span the 4' from arch log to arch log. That's why in another thread I suggested three arch logs one for each edge and one for the middle. This is to support your deck boards, personal weights of people walking over the bridge, and moving any furniture or other objects over the bridge, from side to side.
The other solution might be to place the arches under the deck and deck and divide the 4' into three sections and have the arch log supports under the 1/3 and 2/3 locations.
Jim Rogers
Jim_Rogers
Here is what I've drawn, if you wanted to do a straight bridge:
The support blocks are 5' apart, and they are 8"x 10"x 4' to give you the 10" clearance you needed. The stringers are 8x8x9' and have a rabbet cut down the side 3 1/2" deep and 2" wide. The deck boards in the rabbets are 1 1/2" thick and 8" wide and about 3' long. The step is set to 8" from the floor to the top of the step and then 8" to the top of the deck. The end support blocks are 4x10's.
I haven't done any engineering math on this to see if it's safe, as I mentioned the deck boards might need to be thicker.
Railing could be added as needed.
If you wanted this in a curved log you could do something similar.
Jim Rogers
Jim_Rogers
Here is another shot with a few deck boards removed and another support timber added. This timber is a 4 1/2" thick x 8" wide running down the middle of the deck.
These are just some quick ideas I had.
Jim Rogers
etat
Jim, maybe you don't realize what a stubborn old fart I am.  Narrowing to 3 feet would be a possibility.  Incorporating a couple of steel runners underneath the top boards and enclosing so they won't be seen is well within my means.  I've got a pretty good welding shop set up over here.  Steel braces, clips etc. will be no problem. I could easily take steel beams, and slice and and form and put back together in an arch.  So if I had curved wooden beams and the notches cut out for the steps.  Underneath these notches attach curved angle iron,the length of the beams..  Across these from one side to the other weld angle heavy enough to support the floor.  Put a false floor underneath the iron reinforcement to hide the steel.  Your drawing does give me ideas, about these reinforcements and where they need to go.  Just need it curved.
SasquatchMan
ck I think laminating is the best - the only other option would be to get some 6 by 6 or whatever, and then cut and glue a rough "arch" shape, then cut the actual arch shape out of that.  This wouldn't be as strong as a lam beam though.   It doesn't look like you'd even need to steam things to get the bend you're looking at... just a mold, lots of thin pieces and lots of glue
Senior Member?  That's funny.
Where's that articulated milling machine at  ??? ??? ???
I know we have a link on The Forum.......somewhere.
Well, I really don't remember what it was called and I don't remember if it'll do what you want.  ::) Been looking around and can't find it, a lotta help I am!  :-[
Ye seek and ye shall find! :D  Ye ask and ye shall receive! :D
I found it!  I found it! :)
The articulated bandsaw link
 ;D
Jim_Rogers
I've seen one of those band saw before, they're great if you got an extra $5000 or so to put into a saw. ;D
Jim Rogers
That's it! That's it!
Thanks Tom!  ;)
I've been really sick the past couple of days and my brain ain't working right. I did however remember that it was a bandsaw, after I got home last night.  ::)
ck,
If it were me I'd get ahold  of some really wide beams from someone (I'm sure you can find some somewhere  ;D ), take a chainsaw and rough out what you want then do the rest by hand for that old time hand hewed look. I would make sure to reinforce it with steel though, what you have in mind will take most of the structural integrity out of the beams. Just my 2 cents.
If you need to cut the curve in a glued-up beam, do as the laminated beam manufacturers do, and put a bandsaw on wheels, support the beam on its side, and move the bandsaw through the arc you want cut. It simulates what the articulated armed band saw does, and a bit less expensive.
Jim_Rogers
I've seen that done before on a TV show, seemed to work good for them. You'll need a nice flat floor and good casters for your bandsaw, but it should work.
Jim Rogers
Don P
At that point it sounds like you're basically just facing a steel structure with a veneer of wood. Why not use thinner wide stock, 2x, it'll behave and dry better and bandsaw or jigsaw to shape. Looking at your drawing, could the walkway be a set of landings/steps (no arch) with arched side plates to which wood is attached (flitch plate).  Pickets could be bar or tube with a flat on top, arched. Wood handrail could screw to that from the flat stock?
etat
Don, I don't exactly understand what you said, but for some reason it was sounding real good.  An actual viable, doable plan that may be within my means and meet my requirements.  I hate to ask you to explain it again, but would you please.  I've got appx. 6 weeks work to do on this house before I have to start actual construction on this, to get it finished before I move in.  (IF I can stay on schedule)
Don P
I sketched it out on graph paper real quick, 4 squares per foot. I tried to make the depth of the "stringers" 14". I got 10" rise about 6" in from each wall. You can fiddle around with all that. The blue is steel plate, I came up with 3 pieces about 10" width. Was thinking 1/2" welded up would do it (you're past my engineering abilities :D). The brown is the 2X stock on the outside, route the recess to bury the plate...you can just plate the inside with 2x then cut the arcs. I used radii of 51" and 65". The treads could be on angle iron thats recessed in a groove in the ends of the tread planking. Or are you planning on planking the underside of the bridge? Then you could just drop the angles under the treads and screw to them from the underside.
raycon
http://www.newmansknees.com/
Shows a fixture for milling braces on a woodmizer. Looks homemade out of wood. More for FYI then helping with this problem.
I'd start with a naturally curved log --using an alsakan mill cut curved timbers...might be less work than laminating. Woodenboat magazines archive has lots of info on bending 6x6's into half U's for boat hull ribs --problem is finding the archived articles.
Lot of stuff..
Fla._Deadheader
Heyyy. THAT is one neat link!!!!!!
  We have a potential customer that rebuilds AND builds from scratch, the old style Chris Craft Runabout, made in the late 30's and 40's.
  He uses CYPRESS, what else. And we are in the cypress business. Why wouldn't he be interested in the same thing as these guys are doing???  Cypress crown roots grow just like that AND we ain't gotta DIG ours ::) ;D ;D
  Gotta go see him when we go back to the camp.
  BTW, we sawed an "S" shaped Pecky log (Showed a pic on another thread), by doing the same as these guys.  Once ya get a flat side, the rest is pretty simple. That's the way I suggested to saw the "curved " logs. Flatten one side so it Doesn't roll and swap ends and turn it over. Take all yer cuts and throw away the last board.
etat
Thank you Don.  I've got a digital camera on my 'wish' list'. I've got a super el cheapo one but the pictures leave a very lot to be desired.  I'll try to take pictures when I actually start trying to build the thing.  I liked your idea and approach to my problem.  Again, thanks.
L. Wakefield
   Gee, Ray- up in Aroostook- that's just a short trip!   :D :D
   What an excellent idea.. my tamaracks are a mite smaller than that, tho.. I will have to look at the structure of larger ones. From the photo it looks like each trunk has 3-4 large roots?  lw
CK, I was plundering around in Lowe's this evening, and spied one of those hand-held, metal cutting bandsaws. Looks like it would be great for cutting curves on large timbers, if you fitted it with a wood cutting blade. Looked like it would hog off about 4" at a whack. Might try it myself if I ever get my hands on one of them. There's a shop here that will make up any size band blades, so that wouldn't be a problem. :)
etat
Thanks Dan, that's a very interesting idea.  I've had pretty good luck welding blades for my jet bandsaw, I've tried brazing, but usually cut em on an angle and a bevel and join em in a jig, with a mig.  Then grind, heat, and anneal. I'm still thinking hard about this bridge ramp thing, and still haven't decided exactly how I'm a gonna handle it.  The upstairs is finished all but painting and the bridge.  Built a surround for a bathtub and just come in a little while ago from laying tile.  That's too a first for me but it's looking pretty good so far.  Getting a heck of a coat of flash rust on my tablesaw, cause instead of springing for a tile cutter I put a 7 1/2 inch blade in it and am spraying the tile with water as I cut it. Didn't clean it up before  I come in so I'll have to do it tomorrow before I start.  Sure could use a few squirts of that rust stuff for sale around here.  Wish they had it in the stores.  Thinking about ordering me some.
L. Wakefield
   So DanG- is that hand held but a powered unit? Gotta be :D :D :D  lw
Fla._Deadheader
I've used a Milwaukee "Port-a-band" several times. Being as how they are a metal cutting saw (230FPM), I doubt of it would work on wood that was very thick. They are not made for power, and a wood blade requires speed???
Back in my young youth, there was a TV show called "The Life of Riley," starring William Bendix. One of his trademark lines was, "What a revoltin' development that is!"  Somehow, I've always been able to identify with him. :-/
Jim_Rogers
DanG: Thanks for the link to Harbor tools. And that's a good price. I saw one of these recently at Home Depot and it was a Millers Falls brand, they wanted $269 for it and had a whole stock of blades. I asked the tool guy if it could cut wood and he showed me the blades, and they were 14 tpi (teeth per inch). The one with Harbor freight has 16 tpi and I couldn't find any replacement blades on their site.
For $79 plus shipping I might get one for an experiment and get blades from Home Depot.
I'll have to do more research on this first and see if it will cut wood. I'll go to Home Depot and talk to the tool rental guy and see what he thinks.
Jim Rogers
On one of the older shows of This Old House (I think it was TOH anyways  ::) ) they used a portable bandsaw to cut beams with. Looked like it worked real good from what I remember.
L. Wakefield
   I just went to HD today and spent a great hour or so (as DanG said, 'plundering around'- it would be blundering except that you keep picking up plunder.. A-las, you must pay for it at the end- but it is fun..)-
   I looked for a portable bandsaw but they just had the little free-standing ones- portabke but not hand-held. I ended up getting the wood I was after and a reglur skilsaw along wit a few extry blades.
   Now am I the only twisted sister who gets 4 carbide tip blades in her hand and starts to wonder if they'd make good weapons?? Anyone care to admit if they've tried chucking a nice sharp blade at the wall and if so, did it stick in? Course I don't want to treat a *new* blade that way (which is why I'm asking if *you* tried it  :D :D :D ..) and I bet an old one wouldn't be as apt to stick. I can already tell you a) I'd want gloves on and b) you'd have to have it right way around in your hand to get the teeth headed in to getting a good grip, sotospeak. Otherwise it should be kinda like a frisbee with teeth, knowhutimean, Vern? Could be right up there behind nunchaku.  ;D  lw
Fla._Deadheader
  Here's some good logs for the "Bridge beams"  We gots LOTS of 'em. Can't believe Y'all don't grow 'em where ya need 'em. ;D ;D :D :D
etat
I'll take the two on the left, and the one on the far right!!! :) :) :) :) :)
Fla._Deadheader
Ya want 'em barky or sawed up nice & neat ??? ;D ;D ;)
etat
Probably couldn't afford your prices ;D ;D :-/  Finally got the tile laid in the first bathroom.  Wouldn't been so bad but the wife wanted everything laid with patterns in it.  Soo, I wound up cutting up a bunch of big pieces of tile into strips and little pieces to mix with the big pieces.  Then took a diamond grinding wheel and buffed the sharp edges before installing.  Slowed things down, a lot. . Been plumbing it last night and today with pex. That too is new to me but it gives you a little more flexibility than sweating copper. Of course no matter how many pieces you buy you still have to send to town after the odd piece or two you didn't count on. Example. Cut the hole for the toilet, guess what, centered  a floor joist.  So, had to trim it down a few inches, then brace and reinforce it back to original strength, and then go get an offset toilet flange to get by where I trimmed it.   Getting ready to run some sewage line, that I dread.  But don't have to go too far, I'm going to tie it in to the existing septic tank.  The day will come that I will  have my beams,  even if I have to hew them out with an ax. ::) ::) ::) ;D ;D :)
etat
Hey Florida, the wife want to know more about why the crooked trees and what makes so many of em grow that way in one place.  Is it high winds, or ??.......
Fla._Deadheader
  Beats me??? That's the way I found 'em. ::) ::) ;D
  The area where they grow is the heart of the Floral Fern growing area. The ones that Florists use. The ferns grow in the shade.
  Could be because the trees are a distance apart and they are shooting for the sunlight ???
L. Wakefield
   So as I was driving home yesterday the trees were having fun with me. For some strange reason ALL the curved ones stood out- especially after I saw the first 1 or 2 and remembered this thread. Some were nicely outlined by a skift of snow on the curve to make them that much plainer. Made me wish I had cuttin rights and a mill right there to try what you were writing about. Coulda had a few bridge timbers.
   It was right after I passed a (fairly bogus) arched bridge over an arificial pond to an artificial island. Seemed like the trees were saying they could do it better..
   I realized if I were going to build a bridge the first thing I'd do would be to load the potential timbers with a weight equal to or exceeding what I expected them to bear once installed. It's a heck of a lot easier to bust down onto the ground than to fall 6-8' .. lw
beav
I bet if i tried i could cut that curve with my woodmizer.I can cut curves without trying.Slow feed,turn the handwheel (on my oldy}slowly as i go......follow the line. Both beams at once....yeah ;D
