Echo 7310
Started by Hossco, October 15, 2020, 08:33:07 AM
Bruno of NH
Remove the muffler and take the spark arrester off cut it open then drill a 9/16 in the baffle in the muffler.
Put the screen and spark arrester back on.
Then re - tune
It will run much better
OldTimbercutter
I might try that . Thanks .  Did you remove the limiter caps when you retuned yours?
I have heard they are aggravating to get off.
deere 440b
clark f66
loyal dog
stihls 440,460, 066
pretty wife who likes to cook
prentice loaders
A few huskys and a dolmar
Life is good
Tacotodd
Easy to do on Echo. A wood screw or something else like it. Screw it in just enough to bite, and pull. Pops right out. Don't lose it if you EVER might need to take it back in for any warranty work.
Trying harder everyday.
Bruno of NH
Yes I removed the limiter caps
Take a sheetrock screw
File the point down a bit.
Screw it in and the whole assembly pops out.
My dealer won't care that they aren't in.
ladylake
  I grind the tabs off the limiter caps and reinstall them, it's easier to use the screwdriver for tuning with them on.  If worries about the warranty you can buy new one for under a $.  Steve
curved-wood
Quote from: OldTimbercutter on December 28, 2021, 09:28:07 AM
I'm surprised at the vibration it has.
I have a Echo 501-p and I felt the same about vibration. A lot more than my Husquavarnas. Difficult to sleep because of pain in the wrist. So I put a thin layer of foam tapes with electric tape on the handle. I did improve  a lot
