Question for swing millers
Started by starmac, November 23, 2017, 02:10:19 PM
starmac
This question would also pertain to mobil deminsional mills, or any mills that you do not turn the logs.
When you get a log with stress in it, how do you deal with it.
I am lucky in this regard as I mostly saw white spruce and the percentages of logs with much stress is pretty low, low enough that they just get turned into firewood, instead of turning and trying to relive the stress.
Grandedog
     Howdy,
   By leaving one side of the log attached in a step fashion, it keeps the log from cupping, or bowing.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
terrifictimbersllc
One takes off boards from left to right, leaving a level surface after each layer. If stress bows this surface, one can skim it flat again with a shallow saw cut.
dgdrls
Amazing how some logs will move when you saw them.
The link talks about sawing eucalyptus with a dimension mill and the potential "crook" or "bow"
http://www.nzffa.org.nz/specialty-timber-market/information-resources/sawmilling/hardwoods/sawing-eucalypt/sawing-eucalypt-with-mahoe-multi-blade-circular-sawmill/
D
starmac
Does these methods work as well as turning the logs, as far as finished boards?
Probably similar. When you are having to turn a log to counter stress you still wont get perfect results either. The idea is to get the boards "good enough" so they don't go in the reject pile. Because you reference the next board off the last cut, which will be straight, and the log itself tends to get "skimmed" by the horizontal blade, even if the log does move a little it's gradual, and a fraction of an inch for each board as they come off. The boards themselves may move more, but they are still sawn "true". Weight during drying, and straight line ripping once dry are things that help later.
Of course some logs just don't want to be sawn, and that doesn't matter what mill you use.  :D
