Can anyone help me decipher the marking on the bar of my MS261cm?
Started by Crusarius, June 22, 2018, 05:41:11 PM
Crusarius
Well I was just outside working on clearing a spot to setup my mill. I was cutting a tree down and wouldn't you know it there is a rock that looked just like the trunk that I tried to cut in half. Well the rock has a real nice groove in it but the blade is not cutting so nice now.
The bar look like this
Crusarius
I don't know anything about full chisel part chisel drill or anything about chains. any help would be apreciated.
armechanic
20" = bar length
81 = drive links
.325 = pitch
.063 = width of groove in bar
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Crusarius
that helps a ton. thankyou.
now i just need to find a chain or 3 to have in stock.
teakwood
Buy a 2 in 1 Stihl or Pferd Sharper, 35-40$, it would have to be in 0.325" for this saw. That's the best sharper and easy to use for People who aren't good at freehand filing.
Learn how to sharpen a chain!!
You can have the best chainsaw in the world but if the chain is not sharp it's useless
lxskllr
To add to the "learn to sharpen" comment, it'll be easier at first if you don't wait til it's dull. Reading around, a lot of people touch up the chain at every fuel fill. I've taken up that practice, and it makes everything easier. If the chain isn't trashed, it's simply a matter of making what's already there a bit better. Use the tooth as a guide, or if you trashed the teeth, the witness mark on the chain will show the angle.
I got decent at sharpening chains when my boss needed some wood cleared. That stuff had been dropped by a dozer, and pushed around several times. They were virtually hard dirt sticks. I had to sharpen about 3 times per tank of fuel. Granted, when I started, I wasn't the best sharpener, but I really got my practice in on that job. I now do a very competent job, though not perfect. I could get close to perfect, but don't want to invest time for a marginal improvement that gets quickly lost after using. Get the best I can with as few strokes as possible. I tried using file guides on a buddy's saw, but I never really got on with it. It overly complicated the setup. Spent more time looking at marks, and trying to be perfect than getting teeth sharpened.
I'd start with a bare file(correctly sized for your chain), and see how you do. If there's issues, ask questions. Perhaps try a guide. You'll get it eventually, and it'll pay off in self sufficiency, and money savings over taking them to a shop. Oh, and new files are glorious. They're consumables. Use it til it quits cutting well, then get a new one. A new file makes the job easier. I really like Stihl files.
One other thing... on the question of full vs semi chisel... This is based solely on reading around here, but going on that, full chisel cuts faster, but dulls faster. Semi chisel holds up better to dirty conditions. I'd like to try a semi chisel chain some time cause a lot of the stuff I cut is pretty dirty. Assuming what I wrote is accurate, a semi chisel would probably be best for a "generalist" cutter. eg farm type duties where you're doing a little bit of everything, under varying conditions. For pure wood cutting, a full chisel would be best.
Crusarius
Thanks everyone. The input is greatly appreciated. I think I need to find someone who is good at sharpening chains and get a few lessons. I guess step one is to get the correct file.
I expect most of my cutting to be dirty wood that has fallen or been skidded. The worst thing I do is try to cut the stumps off flush with the ground. That is what happened to this chain. Darn rock. It looked just like the trunk. Didn't cut as nice :)
You are definitely correct about a sharp chain that saw cut amazing till I hit that rock then it did not cut well at all. So I will get a few to have on standbye for the next camouflage rock that plays tree :)
Keep cutting them stumps low!!!
I had a Father that drove that into my head. When we was cutting on this land,I took his advice that I heard for 40 years. Never once did he have to say,cut the stump lower next time.  Yes,I know how to sharpen a chain too. Lots of practice. My Father is gone,but stumps are still cut low.
I had a Father that could sharpen anything he owned,be it a one man buck saw,cordwood saw,or a chainsaw or an axe too. But he was born in 1923. You had sharp tools or worked way harder than was needed.
But that sharpening skills was not passed onto to me. Even though I watched him sharpen things many,many times.Finally I took a log and told myself I will get this. Took me just about a whole chain to get it,and about a 8 foot log, ;D  but I figured it out. For me I was getting a better angle on one side than the other. I think when the motor is on the right is when things can go wrong.
Crusarius
I am sharpeningly challenged. I cannot even sharpen drill bits with a drill doctor. Either that or the drill bits are to far gone to bring back?
 I hope thats the case. I do need to learn chainsaw blades and band saw blades. really not have to rely on resharp.
Skeans1
Myself I can get by with a file but most of the time when I'm falling for a day I carry up to 6 chains per bar length with me ground and ready. To the low stumps I normally cut low enough that my full wrap saws just barely have enough room in the back cut but what's your back worth and how hard is it to recut a stump flush. Moral of all of this buy a grinder you'll thank yourself over and over again.
teakwood
joe_indi
Quote from: Crusarius on June 22, 2018, 05:41:11 PM
3003 008 6821
The 3003 denotes the bar mount which is suitable for nearly most of the current models of Stihl
The other mount in use the 3005 for the smaller saws like the 170 to the 250
The 008 is an internal code
In the next four digits the first two (here the 68 ) denotes the version of the guidebar. 68 means it is a Rollomatic with 16mm/063" groove width
The nose sprocket has 11 teeth
Pitch is .325"
The last two digits (21 ) means the bar length is 20"
The replacement nose sprocket for this bar would be #3003 650 9926
So, the chains suitable for this bar would be the full chisel 26RSc (Rapid Super) or the semi chisel 26RM (Rapid Micro)
The RM might be a better option for your application if you cut closer to the ground.
Crusarius
Thanks Teak, and Joe. I might just happen to have a 3/16 file from my other saw. Maybe I can try my luck and breathe some life back into it.
The amount of detail I just got is quite a bit more than I was expecting. The ppl on this forum are great.
Thanks everyone for the help.
Grandedog
     Howdy,
   If you haven't bought any yet, I have some loops that are a perfect fit for your application on a "stock on hand sale". http://leftcoastsupplies.com/product/clearance-chain-22bpx-81-dl-loop-spc-22bpx81/
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
John Mc
If you want to learn to sharpen a chain, one of the Game Of Logging instructors in my area made a video of proper sharpening techniques. You do have to pay for it ($6.99 to download, $9.99 for a DVD), but it's one of the better sharpening tutorials I've seen (and I've looked at a lot of them - some OK, some just outright bad advice). You can find a link to it from his company's home page: NorthEast Woodland Training. (The Game of Logging classes they teach are also worth checking out. There is another guy teaching these classes out closer to where you live, Crusarius.)
The video does show the use of a guide (two types of guides, if I recall, and a bit on using a grinder). Over the years of my chainsaw use, I've run into a few people who are really good at sharpening freehand with just a bare file. I've also run into a whole lot of people who think they are good at freehand sharpening: their work generally results in something that cuts better than the dull chain they started with, but are too "grabby", or don't last worth a darn, or just don't cut as well as a properly sharpened chain. Since I would most likely end up in the latter group, I use a guide. Typically one of these styles:
I've also used the sharpener made by Pferd/Stihl with good results, but it's a bit more cumbersome to carry with me in the woods.
Crusarius
I was working on getting hooked up with Game of logging but somehow I lost all the info and they never contacted me. so Till I take some time to find it again I am stuck without.
I would really like to get a class though. I need all the help I can get.
John Mc
Game of Logging Training Organizations
Look as though Bill Lindloff would be the closest to you?
Most of the training organizations travel around a bit from where they are based.
teakwood
I have tried both of the sharpers in that pic from John MC
The one on the left works fine but doesn't indicate the angle very well, the one on the right i find just bad and it's so tiny that you can loose it easy.
the 2in1 is way better than both those sharpers, IMO
Crusarius
Well. I received 6 chains and 2 files yesterday. Thanks left coast!
Now I just need to find some time to use them :) Hopefully tomorrow I can spend some time Milling the spalted maple I prepped over the weekend.
I really need to get some paint on the sawmill. I am paranoid of getting rained on and having everything rust.
John Mc
Quote from: teakwood on July 03, 2018, 08:25:19 AM
I generally use the first one pictured. I have no problems maintaining angles, since they are stamped in the metal of the holder. I just line the marks up with the bar up at the beginning of the stroke, and maintain that angle through the stroke. The wedge holster on my tool belt has a slot for a file - it's a snug fit, but I can fit the guide with file into that file slot.
I get very good results with the second one (the "roller guide"), though I don't use it much. It is easier to lose, but the fact that it is small is one of the reasons I tried it. It can ride in the bottom of the wedge pocket on my chaps or in the wedge holster of my tool belt, so it's handy whenever I need it. While I don't carry it much, I do lend it out to friends from time to time. It's handy for those who have problems with rocking their file up and down while filing (for some reason, lots of people new to sharpening tend to push down on the handle as they make the stroke): I just tell them to make sure it stays in contact with both rollers. Once they've used it a bit, they get the muscle memory to use other guides without dropping the handle during the stroke.
I do like the "Stihl 2 in 1" / "Pferd Chain Sharp CS-X". I get good results when I use it, and it's certainly faster than filing the teeth and the depth gauges separately. My main problem with it is that I don't have a good way to carry it with me. My other beef is with how it handles the depth gauges: It does not "customize" the depth gauge height to the associated tooth the way some other depth gauge tools do (including the one with the roller guide). This means you have to keep all the tooth lengths equal - by eyeballing or by counting strokes. With a depth gauge tool that works like the one on the roller guide (or on the old Carlton "File-o-plate" guides), each depth gauge is matched with the tooth that follows it, so there is no need (within reason) to keep all the teeth the same. If I damage a couple of teeth, or all the teeth on one side, I can take just those teeth down further to get them sharp (and hope the next time I hit something it will be with the teeth on the other side). That style of depth gauge tool also does a better job of adjusting the gauge as the tooth gets filed way back, IMO. The differences may not matter to some, and as I said, the Stihl/Pferd sharpener does do a good job
samandothers
Sharpening takes practice or time.  Do it after each tank or at least When you break midday and end of. I think next sharpener I'll try is the 2 in 1 Teakwood talked about.  This will get the links and drag teeth in one go.  Ok, I'm lazy!
Skeans1
Take this for what it's worth typically I'll bring enough chains to run all day say 6 or 8 but this is for production falling work. If you're doing any production or even considering production work filing would be out of the question, you can swap the chain, clean the rails, and open up the Oiler before you file both sides of a 20" full comp round chain.
teakwood
Quote from: John Mc on July 03, 2018, 11:01:57 AM
Well said John!
Crusarius
Well. I decided to go cut up some aspen yesterday so I could mill some stickers. instead of changing to a new chain I thought I would try my luck at sharpening the original one.
I had round 3/16 file without a guide or handle and just kinda used the teeth as a guide. I managed to get it sharpened and it cut just like before I hit the rock. Maybe I have a chance at hand sharpening after all?
John Mc
It's not hard to learn, it just takes some practice. The key is to practice it right. Practicing poor technique can form habits that are hard to break. It does not take much to sharpen a chain so it works better than after it hit a rock. The goal is to get it cutting better than it did when it was new.
One thing that helps some people getting started with hand sharpening is to do 2 or 3 sharpenings on the chain themselves, then take it to someone who really knows their stuff to either hand sharpen or sharpen on a grinder to bring all the angles back into spec. (NOTE: It's easy to wreck a chain on a grinder if you don't know what you are doing. The kid at the local hardware store is unlikely to be any good at operating their chain grinder. He's probably had 15 minutes of training.)
In my opinion, a fair amount of new chain may be sharp, but it's not right, and thus is not hard to beat when you resharpen. One major chain manufacturer who prides themselves on "sharp out of the box", packages chain that does not meet their own specifications for sharpening: Their teeth have too much hook to them, resulting in a chain that can be rather "grabby". They try to counter this by leaving the depth gauges too high, reducing the bite that each tooth takes. It cuts fairly well when brand new, but the sharp hook does not hold up well. After just a bit of normal use in hardwoods, you are left with a slightly dull chain making chips that are too small.
teakwood
Quote from: John Mc on July 05, 2018, 08:24:12 AMIt's not hard to learn, it just takes some practice. The key is to practice it right. Practicing poor technique can form habits that are hard to break. It does not take much to sharpen a chain so it works better than after it hit a rock. The goal is to get it cutting better than it did when it was new.
Absolutely right!! don't learn it the wrong way!
btulloh
Quote from: Crusarius on July 05, 2018, 07:44:02 AMI had round 3/16 file without a guide or handle and just kinda used the teeth as a guide. I managed to get it sharpened and it cut just like before I hit the rock. Maybe I have a chance at hand sharpening after all?
With your background it's not surprising that you can pick up sharpening pretty quick.  Main thing is to keep the pressure on the file to toward the head and not down otherwise you'll end up with too much hook.  You're right - the profile shows you where to hold the file.  Keep the depth gauges at the right height or you'll have a sharp chain that won't cut.  Nothing like fixing a chain to get you to watch out for rocks.  And dirt, and everything else.
That 261 is a good little saw with a big heart.
HM126
kalevan
Ouch... cutting stones is the pits.
It seems to me a .063 gauge chain in 325 pitch is an odd combination.
The world seems standardized on .050 gauge 3/8" pitch for medium powered saws.
If cutting stumps and really dirty wood, consider a buying a Carbide chain (like the emergency rescue people use and stump removers) for just the dirty jobs.
You can get them on Ebay for $30 to $300 each.
If you don't abuse it it'll last a lifetime.  It may not hold up that well to sawing a bolder...
If you need to sharpen a carbide chain, it'll take a specialist with the right kind of grinder,
or you may be able to touch it up with a diamond round-file.
Consider identifying one of the less expensive carbide chains... then purchase the (0.050 gauge) bar, and drive component (3/8" spur clutch, or rim-sprocket) to match it.  The package may be less costly than a carbide chain in your 81x0.325x0.063 size.
John Mc
Quote from: kalevan on July 08, 2018, 12:37:42 AMIt seems to me a .063 gauge chain in 325 pitch is an odd combination. The world seems standardized on .050 gauge 3/8" pitch for medium powered saws.
.063" is a common Stihl guage.
Other common gauges are .050" and .058" (Stihl also uses .050 on some saws. To my knowledge, they do not use .058.) Smaller saws or some narrow kerf offerings sometimes show up with .043".
"Standardization" on either .050" or .058" for non-Stihl saws seems to be a regional thing. Here in New England most of the saws I see (other than Stihl) are wearing an .058" chain. The only time I see .050 is on some big-box store saws, or on a saw owned by someone from out of the area.
Out west, .050" seems to be more popular. I'm not sure about other areas of the country.
I've never understood how it is that different areas came to favor different gauges.
Crusarius
Thanks for all the comments everyone. This has been a huge help for me understanding what I got myself into.
New baby just arrived so I am not sure how much time I am going to have to play with it but I will try to make time. Still have some good trees that came down that need to get drug out before they start to rot.
I been playing a bunch with the sawmill really look forward to cutting some nice logs and not the junk I been practicing on.
kalevan
As for sharpening with a file... ALWAYS use the right diameter file.
When hand-sharpening, match the "hook" profile of the cutter to that of a new chain.
The flat (Stihl or Oregon) filing guides help a lot. They have angle markings, and help get the depth right.
Notice the "witness-marks" on the back-end of most chain cutters.
Match your filing angle to the angle of the witness-mark (the leading edge of the cutter should
be parallel to the witness mark).
If you don't use enough downward pressure on the file, the cutters get flatter across the front (square) and won't have enough "bite."  When cutters are too flat,  you compensate by applying too much downward pressure, and the excess pressure prematurely wears out and overheats the bar.
Discard the chain when you file down to the witness mark for any of the cutters,
or discard the chain when you run out of adjustment range in the bar (i.e. too much stretch or wear in the pins).
 Don't run the chain too loose!
Don't over-tighten the chain; it's hard on the drive sprocket, the bar, and the drive side motor bearing.
Follow the chain tension guidelines of the owner's manual!!!
HolmenTree
Quote from: Crusarius on July 03, 2018, 08:44:02 AM
Crusarius, you should have bought a box of a dozen files with those 6 loops of chains.
Biggest mistake amatuer hand filers make is cheapening out trying to use a worn out file. Nothing kills the motivation and technique of hand filing more then trying to file with a dull file.
Best way to learn is lay a file without a guide of any sort in the cutter gullet of a new chain and give it a light touch up.
With the saw sitting level in a bench vise or stump vise on a waist high stump, hold the file level and push straight forward with out too much pressure. Better to have the file handle lower then higher into the stroke of the cutter. Too high and you'll get a uneven not straight cutting edge. No pressure on the file in the return stroke is very important, dulls the file quickly and puts a wobble into your stroke.
Just do a light touchup on this new chain and through normal use of the chain without  cutting into a stone periodically touch it up.
When you do hit a stone and see there is lots of damaged cutter material to file off it is much easier to file the cutter at a square 0 degree angle eliminating the rounded off corner and then proceed to file in the correct 25 to 35 degree angle.
After filing if you see no light reflecting off the top plate cutting edge your chain is sharp. Also all cutters don't need to be perfectly the same length. Put a caliper on a new chains cutters and you will see different lengths right from the factory and it will cut just fine. Just make sure the different cutter lengths average out on both left hand and right side of the chain
HolmenTree
Another thing to add as you progressivily file the cutters over time you may be not putting enough downwards pressure on the file. In this case you're putting more backward pressure then down. I call this lazy filing or trying to file with a dull file.
You need to put a even pressure in both downwards and backwards direction in your stroke. (In a diagonal angle into the gullet.) If you don't the side plate angle will turn into a back slope which makes a very poor cutting chain.
Now you can concentrate on lowering the depth gauges after you have filed some of the cutter length off.
Crusarius
Holmentree thanx for the info. Next time I get a chance to do some playing I will try those techniques.
Thankyou everyone for your help you are all amazing.
Since I have a new ummmm toy? at home it may take a while to get back to doing things. He was born July 6 and has already turned my world upside down. This is #2.
I know you will spend time with that new one more than the one that requires gas to play with. The one that don't need gas will remember it too.  :)
realzed
Quote from: Crusarius on July 11, 2018, 12:08:58 PMSince I have a new ummmm toy? at home it may take a while to get back to doing things. He was born July 6 and has already turned my world upside down. This is #2.
Congratulations - Hope everyone is Happy and Healthy!
Skeans1
Congratulations I'm in the same boat mine showed up May 29th the first couple weeks are the worst.
HolmenTree
My twins were born 11 years ago, challenging but I did ok for a 50 year old dad :D
