Sharpening with diamond or CBN wheels
Started by BalticAbrasives, June 19, 2019, 05:29:34 AM
BalticAbrasives
Hello,
Would like to ask to share the opinion who sharpens chains with diamond or CBN wheels. What improvements could be used?
Are you satisfied with the performance?
ladylake
 Mine will blue the cutters too easy, otherwise good.   Steve
Jemclimber
Don't use diamond without coolant.  Diamond is carbon and with heat dissolves in the chain, use CBN.  If chains are blue, the cbn wheel is probably clogged and needs to be dressed/unclogged.  I assume you are referring to chainsaw chain.
lt15
ladylake
Not many chainsaw sharpeners are set up for coolant, I've tried cleaning the wheel.  Steve
LeeB
wonder if a compressed air stream would work? Probably be messy though.
jimbarry
I use cbn for sawmill blades using woodmizer bms250. I also had a company make up different size cbn wheels to use on a cheap Oregon bench top grinder. Working good so far.
If your teeth are bluing, you are either taking too much off at one time or leaving the cbn wheel on the tooth too long I think. Having the right grit matters too. I have my wheels made up using the grits circled in this chart.
BalticAbrasives
Diamond and CBN wheels (resin bonded) can work dry no problem if they are produced correctly. Special bonding for dry operation should be used.
There should not be burning (teeth getting blue) problem.
As jimbarry wrote maybe wheel is pushed too hard or too long on the tooth, but person who grinds should notice it soon and should eliminate this mistake.
Jemclimber diamond wheels can perfectly work dry if they are produced correctly. The heat dispersion usually goes to wheel's body if body is made of aluminum.
Also please note that diamond wheel should be used only on carbide tipped teeth only (TCT).
CBN wheel should be used on steel chain teeth only.
Normally wheels should not get clogged. But if it happens it is easy to "open" them with abrasive stick.
