Blade lubricant
Started by just_sawing, January 17, 2011, 07:18:27 PM
just_sawing
Found out something today and it's nice to learn something new.
As many here I use windshield washer lub on my blade in the winter. I am setting up a new Blade sharpener and the engineer had RV antifreeze for the blade lub for the sharpener. I questioned it and found that the RV style is PolyEthalgychol  . It is OK with all rubber and has a corrosion resistant with it.
Windshield washer doesn't'. If you don't sharpen your blades and they set you might want to which to it. Also if you have a sharpener use the RV it is better.
You can follow me at
www.http://haneyfamilysawmill.com
Chuck White
I've used RV antifreeze, works great.
Sometimes even cheaper, but around here, usually not.
Didn't know about the anticorrosion issue, but it makes sense because it's primary use is in plumbing for drinking water.
just_sawing
It is listed as a anti corrision label on some even stattes that it is fine for tool cutting.
Bibbyman
What kind of grinding wheel was the guy using - stone or CBN?
Sawing since '94
