Author Topic: Trailer build for HM126  (Read 3967 times)
Offline Dana Stanley
  • For fun and profit!
    • Stanley Carpentry Construction
Re: Trailer build for HM126
« Reply #40 on: August 25, 2019, 07:01:25 PM »
I finished the tail lights and removable bracket a few weeks ago. The cover is just for when its parked, not when moving. I like that the lights are removable as I can use them for tow lights too, and they wont get broken on the mill.
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
« Reply #41 on: August 25, 2019, 07:13:19 PM »
Finished the winch brackets, winch post, and modified the ramps so they sit on and fit into the bunks. The winch is attached to a trailer plug-in, or whatever it's called. Anyway, I will be able to use it on the log/tractor trailer that I hope to get soon. 14' tandem axle Big Tex trailer (I hope)! Really happy with how it worked, just using a lawnmower battery for now. Not sure if I will need a deep cycle battery.
My wife took a pic of me using the mill for the first time since I put it on the trailer. Not sure if I want to lower the throttle control or not. It felt ok at chest height, it is predrilled to lower it, just 2 bolts, so I may try it just to see.
Matthew 3:10
Offline olcowhand
  • I'm new- ish!
« Reply #42 on: October 08, 2021, 06:11:05 AM »
@Dana Stanley I just re-visited this thread because I plan to fab a trailer for my new mill. Any follow up suggestions or "Do-overs" you would recommend? Thanks again for your detailed journey....
Steve
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline olcowhand
  • I'm new- ish!
« Reply #43 on: October 11, 2021, 06:16:58 AM »
@goose63 , Dana has not replied, how about you? Any retroactive design changes you would recommend?
Also, where did you procure the axle you used on your trailer, and how wide did make your frame? please advise. Thanks.
Steve
Ezekiel 36:26-27
Offline goose63
« Reply #44 on: October 11, 2021, 06:37:52 AM »
@olcowhand the trailer frame is 2x4x1/4 tube is the same with as the mill frame the axle I got pioneer rim and wheel
goose
thank you to all the vets
Offline olcowhand
  • I'm new- ish!
« Reply #45 on: October 11, 2021, 11:44:23 AM »
Thanks, Goose!
Ezekiel 36:26-27
A New LT 10 and Trailer Build
Started by Slingshot on Sawmills and Milling
Last post March 28, 2016, 07:22:11 PM
by Kbeitz
My log loader trailer build
Started by bigblue12v on Forestry and Logging
Last post August 30, 2016, 07:58:41 AM
by bigblue12v
Off-road log trailer build
Started by mjeselskis on Forestry and Logging
Last post October 01, 2021, 12:46:47 AM
by mike_belben
WM LT10 Trailer build.
Started by OlJarhead on Sawmills and Milling
Last post August 07, 2013, 12:34:53 PM
by OlJarhead
