Belt or Suspenders
Started by Patrick NC, May 17, 2020, 08:52:43 AM
Patrick NC
Just curious if anyone wears suspenders when they are working.  I started wearing them about 2 years ago and find it much more comfortable than wearing a belt.  Part of that might have something to do with not being quite the same shape as I was 25 years ago. 🤔 I find that a belt just doesn't do the job anymore.
Any other opinions?
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
I wear them when I am working outside. I clip my chaps onto the suspenders too. Keeps me from pulling the chaps up.
I wear them at the hardware store too.
petefrom bearswamp
I shunned suspenders for may years in favor of a belt, but when I did the renovation to my body about 4 years ago, I put in a bay window way too big to use a belt anymore.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
SawyerTed
One or the other but not both! :D
Patrick NC
Are yours the correct color??  ???
Southside
When working I actually do use both, helps with gear hung from my waist and I find it balances things out better.
White Oak Meadows
moodnacreek
Suspenders since back trouble almost 40 years ago. Got a lot of laughs back then.
You can wear heavy pants or thin cool ones with loose waist [like bib overalls]. Much cooler in summer.
Old Greenhorn
Yes. :D ;D
 Usually just a belt, but depending on how my pants fit (snug, loose, or baggy) and what work I am doing, I choose one or the other. Suspenders mostly for the weight of the stuff on the pants, my felling belt is heavy and tends to pull everything down, so suspenders on my pants help. I may add suspenders to the belt for the same reason. Always braces on my chainsaw pants (not suspenders).
 MM, these are the right color, but perhaps the wrong church?
GAB
Quote from: Southside on May 17, 2020, 09:51:26 AM
When working I actually do use both.
A real safety conscious individual!   ;D   :D
GAB
LeeB
I use suspenders on my tool belt. 98% of the time I wear bibs so I suppose you could say in a manner of speaking I wear suspenders then too. With jeans I wear a belt but rarely wear them anymore, only when I 'dress up'.
samandothers
Old Greenhorn, Happy Birthday!  You and my daughter share the day.   Though you do have her by 30 years!  ;D
Do y'all find suspenders causing wear, scratching of leather or vinyl seats/chairs?  That has been my primary hesitation.
trapper
both  I wear the perry suspenders that hook to the belt.
Old Greenhorn
Quote from: samandothers on May 17, 2020, 01:39:35 PM
If I am wearing suspenders or braces I am working and sure don't sit down much. :D I too have those that hook onto the belt. Nice for taking on and off as the requirements change. Got those from deluth trading post
lxskllr
Belt. I never got on with suspenders, and don't really like my pants attached to my shoulders, so no overalls or anything aside from necessary cold weather protection, which hasn't been necessary in many years now.
Happy birthday OG and Sam's daughter!
Sedgehammer
If just one, there's no comparison. Suspenders all day, every day. Much, much, much more comfortable. Belt pinches too when bending and can lead to irritation. With belt works good when carrying tools, but can be left looser.
Necessity is the engine of drive
I am outside working with my suspenders, not in the house. But yes, I bet those clips could do a job on a leather chair, or even a wood one too.
olcowhand
When working with tools attached to my belt (Building or Logging), both. Also, when hunting- I typically wear insulated pants (heavy) and stuff attached to my belt... Both.
Otherwise, it's always a belt.
As an aside, in my other life (Automotive Engineering..)- "Belts and Suspenders" is a Design Validation term (slang?) that means we assume the design can accommodate all potential contingencies. Just a note to highlight that other disciplines "metaphorically" acknowledge that both are usually not a necessity, but always a preferred option when the situation calls for it....
Steve
Olcowhand's Workshop, LLC
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Southside
Quote from: GAB on May 17, 2020, 01:21:41 PM
GAB
If I was then the L4 and L5 fractures would not have happened, necessating the use of both.  :D
White Oak Meadows
51cub
Suspenders or overalls. No clip suspenders here, buttons only
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
Ron Scott
Usually wear both with work clothes and tools carried on belt.
~Ron
Peter Drouin
Quote from: Ron Scott on May 17, 2020, 08:55:44 PM
Me too.
A&P saw Mill LLC.
License NH softwood grader.
Sixacresand
Pretty much have to depend on a loose belt and suspenders.  Since my waste has more girth than my hips.
lazyflee
Good timing for this post. I'm a belt guy, but my covid 19lb gain has got me thinking, and my belt a little tight. I wear bibs (overalls) when I ski and I love them. Gonna order up some suspenders and give it a go.
Raider Bill
I wear braces, (suspenders with buttons) to keep my britches up and a loose belt to hold the multitool.
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
