Author Topic: Blade coming off lt40 wide  (Read 1077 times)
Offline Mlanier
Re: Blade coming off lt40 wide
« Reply #20 on: October 04, 2021, 06:04:27 PM »
I was having the same issues with my LT-40.
What was causing my issues was pitch building up between the drive side wheel and the tire (belt). I mean I would clean the the wheel, put on a belt, and throw a blade before I could get 5-6 cuts in.
Iíd check the wheel and sure enough thereíd be pitch built up between them again.
I switched from a B57 to a B56 on the drive wheel side only and havenít had a problem throwing blades since (knock on wood)
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #21 on: October 04, 2021, 08:20:31 PM »
I called Woodmizer early this morning and as luck would have it, I got Mike in tech support. (I sure enjoy talking with him, he is a wealth of information) Anyway, he patiently listened to everything I have checked and confirmed to be within spec. Then I asked if he had any thoughts about what was happening. He confidently answered, I do, first off, what is causing the blade to come off at startup canít be measured. It is sap getting between the belt and the the drive wheel. When the drive wheel is spinning, the sap gets warm and sticky. Then when it stops the belt gets stuck to the drive wheel where it is being held by the blade. Then when you start it again the loose section of the belt that isnít being held down with the blade basically wads up and knocks the blade off. As for the blade coming off in the cut, he credited that to a chunk of bark or something knocking it off. He went on to explain that some people that cut a lot of pine in the south have switched to B-56 belts, which seems to have solved the problem.
Thank you all for your input, I hope this will help others in the future. Now that I have cleaned the blade wheel V grooves with a light machine oil, I look forward to getting back to milling in the morning.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline Beavertooth
« Reply #22 on: October 05, 2021, 06:41:45 AM »
Putting silicone spray on the wheel in the groove also helps keep the sap from building up and dose not seem to cause any slippage and also make sure you are letting the tension off the blade when you stop cutting as leaving it on definitely will make the belt stick harder to the wheel if you have any sap in there.
2007 LT70 Remote Station 62hp cat.
Offline ladylake
« Reply #23 on: October 05, 2021, 07:18:49 AM »
 I'd just switch to B56 belts, a pain to get on sometimes but less belt damage with broken blades plus never get anything under them.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #24 on: October 05, 2021, 08:50:10 AM »
The B56 is a smaller belt? I am just following along. The damage to a belt from broken blades is what interest me. I tend to break blades, or get thrown from backing out of large cuts.
Offline Crossroads
« Reply #25 on: October 05, 2021, 08:56:01 AM »
Yes the B-56 is a shorter belt. The B designates the V-size while the 56 represents the length of the belt. Iíve heard of guys putting them in hot water before installing to make it I little easier.
Offline swampwood
« Reply #26 on: October 13, 2021, 11:05:16 PM »
Yes I had this problem with napa belts. The flat b57's from WM are a must or you will have to make tracking adjustments you really don't want to make and have no specs to fall back on.
Jm2cw
Offline Crossroads
« Reply #27 on: October 14, 2021, 11:08:50 PM »
Jm2cw
it turns out the Napa belts were not the issue. To the best of my knowledge, Woodmizer donít make B-56 belts, so those who have switched are running napa belts.
Offline Will_Johnson
  • Sponsor
  • TimberKing Factory Rep
    • www.timberking.com
« Reply #28 on: October 15, 2021, 09:31:38 AM »
I think every manufacturer that uses belted wheels will agree all B57 or B56 belts are not created equal. They vary a great deal between belt manufacturers (Gates etc...)
We carry B56 belts that do well in the band mill application. Feel free to give us a call we'd be happy to help. Or you can feel free to email me at wjohnson@timberking.com.
LT40 mill problem, chattering blade in wide cuts
Started by Kelvin on Sawmills and Milling
Last post March 07, 2009, 09:34:34 AM
by pineywoods
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
EZ Boardwalk WIDE coming ???
Started by Downstream on Sawmills and Milling
Last post August 12, 2020, 12:26:21 PM
by Hossco
LT40 WIDE
Started by John S on Sawmills and Milling
Last post June 30, 2017, 08:50:40 AM
by scully
