Nice vid. I have the same mill and sawed a 8' X 42" diameter WO that fell in SuperStorm sandy. Nearly tore up my ATV and log arch hauling it and by the time I got done I don;t think I got 100 bf out of it because of shake. I trust you will fare much better than I did. Good luck. Let us know how it turns out.
It may be because I am new, but I did not understand your comment about shake – did you mean the mill shaking and causing cutting problems?
Nice. I've often wondered how the Porta Power system would work splittingogs. Just curious, with the 880 why didn't you rip it with the chainsaw?
Nice video, 123! I've had to do the same several times (same mill, LT35), and will again tomorrow ... maybe get some pix too. That one is only about 38", but (as you say) is too big for the mill. Did one a couple of weeks ago, we ended up with a TON of nice quartersawn lumber -- got pix of logs (below) but I almost always forget to take some of finished product! (The halves closest to the street came down that way ...) (Image hidden from quote, click to view.) How are you going to process it from here? Quarter first? (The issue being that there's less than 12" of "throat", so you can't quarter it on the mill)
Hi, WV, come on over to Fluvanna some time & I will demo the swinger. I was all set to buy band and then learned about the swing mills. Each has its merits of course but finding this cherry used one helped me decide.Nativewolf'll give you a ride if you meet him somewhere.
I bet a bunch of people never heard of a medullary ray .
Started by teed on Sawmills and Milling
Started by D._Frederick on Sawmills and Milling
Started by inspectorwoody on Sawmills and Milling
Started by Tam-i-am on LogRite Tools and Rite Leg Co
