Author Topic: I almost caught it on video.  (Read 640 times)
Offline Brad_bb
« on: June 04, 2020, 12:06:59 AM »
I put a new band on today, and sawed one Ash log.  As I was going to edge one of the last outside boards, I noticed that the blade was oscillating relative to the outside guide. I inspected the band wheels to see if there was something on them causing this oscillation. Finding nothing, I slowly started engaging the band again right after this video and BAM!  The band broke. Clearly the oscillation was caused by a crack in the band that I did not see. Unfortunately the band bunched up inside the housing and partially cut my drive belt. So I’m down until I get another drive belt, which should be tomorrow morning. I had just changed my drive belt recently using my spare, and had not yet ordered replacements. At least now when I see an oscillating blade I’ll know what to expect. I’ll definitely stop and inspect the blade carefully.
Offline donbj
Re: I almost caught it on video.
« Reply #1 on: June 04, 2020, 01:06:13 AM »
That's a dead giveaway of a cracked blade. I can pretty much catch them before they break, either from what you see there or the sound it makes as it saws like that
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Offline kelLOGg
« Reply #2 on: June 04, 2020, 07:29:20 AM »
What donbj said. That is my experience, too.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Tramp Bushler
  • I am blessed
« Reply #3 on: June 09, 2020, 03:02:47 AM »
One of those learning curves.
 If your not wearing your hard hat when you need it. Well.
Caught Crooks with my new video camera system
Started by Busy Beaver Lumber on General Board
Last post July 31, 2019, 06:21:19 PM
by Peter Drouin
Small "widow maker" caught on video
Started by CCC4 on Forestry and Logging
Last post December 26, 2013, 06:44:17 AM
by mesquite buckeye
Someone else caught the bug
Started by plowboyswr on General Woodworking
Last post December 03, 2017, 10:36:57 AM
by thecfarm
Look At What I Caught
Started by Gary_C on The Outdoor Board
Last post July 02, 2011, 07:44:04 PM
by SwampDonkey
