Author Topic: New Whole Shop Outside Cycle Dust Collector Install  (Read 4528 times)
Offline Walnut Beast
Re: New Whole Shop Outside Cycle Dust Collector Install
« Reply #100 on: May 06, 2021, 10:31:45 PM »
Is that the hp of your system Yellowhammer
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #101 on: May 06, 2021, 11:08:50 PM »
Mines a 10 Hp system, Iíve got three filters looks like this one is 4.  Oneida has a very efficient blower design, and Iíve never come close to overloading it.  It will run my 55Hp double sided planer while at the same time sucking the sawdust from the sawmill.  Iím as happy with it now as the day I installed it.  Itís not unusual for it to run for most of the day, servicing all our tools.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
« Reply #102 on: May 06, 2021, 11:30:51 PM »
The systems you guys have are probably the best out there and very impressive 💪
Offline tmbrcruiser
« Reply #103 on: May 07, 2021, 10:11:32 AM »
Worked on piping last night, connecting air lock to transfer blower. Had a little distraction when a coyote came out 100 yards away. They are just starting to be seen frequently on the Easter Shore.
I went with four filters and stand with bin, to recapture the conditioned air from the shop. The barrel will catch the fine dust from the filters, not sure how often I will need to dump the barrel. The flow of my piping must not be as efficient as it should be. From time to time the jointer and the moulder will plug up with shavings. The Laguna is rated at 6,000 cfm and the Oneida is rated at 7,800 should be problem solved. Weinig recommends 6,000 cfm for the moulder.
Almost went with Oneida when I set up originally, wish I had. A good friend once told me "You will remember a bought lesson longer than a taught lesson".
Once you get sap in your veins, you will always have sawdust in your pockets.
Offline tmbrcruiser
« Reply #104 on: May 25, 2021, 09:39:47 PM »
Offline tmbrcruiser
« Reply #105 on: May 25, 2021, 09:45:20 PM »
Got the system up and running, very happy with the performance. The trailer should hold about 600 cubic feet of dust/shaving. This will be a huge time savings in the shop, not having to empty the 40 cubic foot bin every 20 minutes.
« Reply #106 on: May 26, 2021, 12:00:04 AM »
Good deal. Looks like you did a real nice job 👍
Offline metalspinner
« Reply #107 on: May 26, 2021, 08:29:12 PM »
Where you going with the trailer when itís full?
« Reply #108 on: May 26, 2021, 08:44:08 PM »
Very nice.  Do the shavings stay contained in the trailer, or do they blow out some?
YellowHammerisms:
Offline tmbrcruiser
« Reply #109 on: May 26, 2021, 11:59:23 PM »
You can't see the soffit on the trailer, I used vented soffit along the top eve of the trailer cap. There is a gap between the plywood and the outer 2"x4". The transfer blower easily moves the dust/shavings but dose not create a wind storm. A little bit of fine dust gets out, but not much.
I have several horse farms near by that will take the dust/shavings as long as it doesn't have any walnut or cherry. When I am running either walnut or cherry I can take it to a mulch yard. They don't pay me for the dust but they don't charge me to dump.
« Reply #110 on: May 27, 2021, 07:37:19 AM »
So, performance wise, it's sucking up all the chips you need and keeping the machines clear?  It looks like a real nice, clean set up.
YellowHammerisms:
Offline Andries
  • Making buildings out of big curvy logs
« Reply #111 on: May 27, 2021, 08:14:11 AM »
Very impressive setup, and nice installation workmanship. I've also been happy with my Oneida products since a mid-winter install.
Here's a question about the transfer blower: it looks so much smaller than the capacity of the cyclone blower fan.
They must be balanced in terms of capacity, but how is that possible?
Is it because after the cyclone and air locks have done their work, that the ducting can be reduced to move mostly sawdust and much less air?
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline tmbrcruiser
« Reply #112 on: May 29, 2021, 07:02:27 AM »
The system is working better than I expected, hate to admit it but I could probably gotten away with 15 hp. I ran cherry flooring yesterday without stopping to empty the dust bin. Time savings makes the system well worth the expense.
Seems I have a habit of over building. When I put up the air drying shed 30'x50' with front and back open (used sun shade curtains) the post are 12"x12".
Whole Shop Dust Collector
Started by SlowJoeCrow on General Woodworking
Last post January 31, 2017, 02:09:41 PM
by DDW_OR
Shop Dust Collector
Started by jdtuttle on Drying and Processing
Last post July 22, 2018, 07:47:54 AM
by DR_Buck
Whole Shop Stationary Dust Collector
Last post February 06, 2019, 09:24:15 AM
by samandothers
New (to me) dust collector
Started by ohsoloco on General Woodworking
Last post June 18, 2007, 12:25:23 AM
by Handy Andy
