Author Topic: Locking dogs  (Read 1822 times)
Offline EZ
  • Betya can't cut just one!
Locking dogs
« on: November 15, 2011, 05:36:35 PM »
What is used on most mills for the locking dogs, hyd. motors or cylinders.
Mine is 12 volt and its just not strong enough.
Rod
Offline paul case
  • Original wearer of the PCM.
Re: Locking dogs
« Reply #1 on: November 15, 2011, 10:16:42 PM »
I don't know of any mfgers using electric motors for the clamp. most use cylinders  or hyd motors for the clamp.
my mill uses cam lock MANUAL clamps for now anyway. PC
pc
Offline EZ
Re: Locking dogs
« Reply #2 on: November 16, 2011, 04:46:30 AM »
Thanks for the reply, Paul.
I put a 12 volt 2000 lb winch on my mill with a swing arm type arm. works pretty good except on the bigger logs.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Locking dogs
« Reply #3 on: November 16, 2011, 11:44:22 PM »
I put a 2000 lb 12 volt electric winch on my manual mill and it will drive a home made shuttle clamp well into the log or cant, if I let it.  Check out the thread below if you want to see what it looks like.  Pretty easy to build and doesn't lose any mechanical advantage, so a 2000 lb winch will clamp with one ton of force.  Stronger winch, more force, but I never needed it.  If you don't want to install the hydraulic cylinder and turn it into a two plane clamp, and only build the shuttle clamp, it will  cost almost nothing since you already have the winch.
http://www.forestryforum.com/board/index.php/topic,53476.0.html
I never used manual clamps again, I took them off the mill.
I clamped logs almost 30 inches in diameter, no problem
Also have more pictures in my gallery.
YellowHammer
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
Re: Locking dogs
« Reply #4 on: November 17, 2011, 01:30:10 AM »
Well done Yellowhammer those are some nice modifications. You have done with your mill.
Offline EZ
Re: Locking dogs
« Reply #5 on: November 17, 2011, 05:17:53 AM »
Nice job on your mill.
I put hyd. on my mill a few yrs back and the winch for the locking dog was before the hyds.
I just never took the time to put a hyd locking dog on.
Now with winter around the corner I'm going to do it, some how. It looks like a hyd motor will be the best and easyest way to do so.
Thanks for the pic of your mill.
Again, good job.
Rod
Offline eastberkshirecustoms
Re: Locking dogs
« Reply #6 on: November 17, 2011, 02:31:00 PM »
Here is a photo of a home built two plane dog that uses hydraulic motors and chain for the up/down and in/out:
Offline EZ
Re: Locking dogs
« Reply #7 on: November 17, 2011, 06:52:27 PM »
Thank you eastberkshirecustoms for posting that photo, that is just what I want to do with my mill.
Will the locking dog turn logs and if so what is the largest log you can turn.
Thanks again
Rod
Re: Locking dogs
« Reply #8 on: November 17, 2011, 09:04:43 PM »
EZ, sent you a PM
Offline EZ
Re: Locking dogs
« Reply #9 on: November 18, 2011, 05:19:35 AM »
eastberkshirecustoms,
I've built my own bandmill that will mill a 40inch log, but I'll be DanG if I can figure out how to use the PM thing.
Everytime I try to reply in it I delete the PM message.
Sorry, and Thanks for the PM.
Rod
Vapor locking or gas too hot?
Started by logger on Chainsaws
Last post April 20, 2005, 12:20:07 PM
by jjmk98k
461 locking up while cranking
Started by slider on Chainsaws
Last post October 30, 2018, 12:27:27 PM
by LeeB
PM mssg locking system
Started by dgdrls on Technical Support Topics
Last post November 19, 2012, 11:04:45 PM
by Warbird
Problem with chain locking
Started by Oregon40Acres on Chainsaws
Last post February 04, 2019, 04:31:00 PM
by mredden
