Did something dumb today.
GRANITEstateMP and 2 Guests are viewing this topic.
I made a cut and then went to raise the head so I could return it for the next cut.  Apparently I lowered the saw on accident instead of raised.  When I pulled the saw, the back of the blade hit the log and the blade came off the wheels.  At first I thought the blade broke, then I realized what had actually happened.  The blade appeared undamaged, but I was leery about putting it back on.  I figure at the least, some teeth got damaged.  Who's done this?
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Woodpecker52
Happens more times than I care to admit, forget which way to move dial.  Blade should be ok.  I like to finish a cut, turn the log raise the blade up about a 1/4 of a turn and pull back and do not see the bump sticking up till it catches the blade and everything comes to a stop. Or the all time bonehead, turn about a 4x 10 cant up on high side forget to raise up stops and have it fall over in the middle and jam the whole works up and end with a zig zag blade.
Southside
Nope, not me, never hit the right trigger instead of the right thumb button.  ;) That's my story and I am sticking to it!!
Percy
After 11,500 hours, my blade door on the mast side has a jagged hole in it where countless  blades have hit Because of various unintelligent moves. A common one for me is leaving the feed lever in the business position but having the speed control knob completely off. The lube mizer keeps squirting and, using pdiesel for lube,  enough of it accumulates on the blade. Hit the auto clutch on and the blade spins out on the diesel causing it to fly off, just as it's winding up. I could go on for many chapters of Dumbness. Should write a book called Percy's Pinheaded Sawmilling Techniques.
Rhodemont
When sawing or logging I have a prescription for one-dumb-aday and use it.
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P and now a CSA 300 C-O
Chuck White
I've done it maybe twice since I've had my mill, then I started following what's written in the book!
When the blade exits the cut, disengage it for the gig back to the front!  ;)
Old Greenhorn
A better question might be "who hasn't done this........... Yet." :D :D
Thanks for the replies everybody.  I enjoyed them all.  The thing is, I always disengage.  I must have disengaged and then tried to go back while it was slowing down.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
This is why I am putting a "laser" on mine.  I at least one time hit my setworks down button before I had cleared the back (near) end of the log and tried to stretch my blade.
"laser" indicator for sawmill. in Sawmills and Milling
   Yeah, I have bumped the down toggle on my setworks after raising the head then lowered and knocked the blade off. Usually no damage is done, just a little embarrassment if others happen to be watching.
Crossroads
I'll take the 5th 😎😎😎😎😎
petefrom bearswamp
Been there done that multiple times.
No cure for it in my case as inattention is a constant trait of mine
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Alyeska Pete
Now we know why Cook always used plywood for blade covers. In recent years they caved in to the "me too" market pressure and went to steel covers. I'm lucky to have bought my mill before the change. I have yet to trash a blade by knocking it off on the return, despite having done it at least several times a year. I strive not to do this unless I have an audience.
au·di·ence  Dictionary result for audience
/ˈôdēəns/
noun
  • 1.
    the assembled spectators or listeners at a public event, such as a play, movie, concert, or sawmill demonstration.
Pete, I feel like you might have added that last part.  Lol.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Sixacresand
There are so many things you have to be aware of while milling,  Being tired and hot can cause lose of focus.
gshd1
E-Tex
Quote from: firefighter ontheside on February 26, 2019, 10:48:19 PM
that's just nonsense.  it's NEVER happened in bullard, texas!
LT-50 Wide, Nyle 200Pro Kiln, Mahindra 6065, Kubota 97-2 / Forestry Mulcher
L2 Sawmill LLC
I looked closer at that blade today.  One tooth was almost completely sheered off.  I think I will not send that back to resharp.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
GAB
Quote from: Crossroads on February 27, 2019, 08:54:58 AM
You are definitely not alone on that one.
Don't ask me how I know.
Gerald
starmac
Well, there is a saying on the haul road, that there is two kinds of truck drivers, those that have crashed and those that are going to.
Some things are just a whole lot alike, and yea I have done it, but I ain't admitting it.
randy d
Yep been there done that happens when I am in a hurry.
Idiocrates
This has never ever happened to me......although I'm pretty sure that when it did happen that either the mill misunderstood my intentions and prematurely backed up or sensed the Head-Up switch contact as a Head-Back contact through some kind of inherent glitch or electrical impulse fault either of which results in a lot of cussing.  Of course, there's always the possibility that somebody UP there thought I was working too hard and needed a rest.......and those are my top three stories and I'm sticking to them all!
James
tylerltr450
Quote from: Alyeska Pete on February 27, 2019, 11:31:58 AM
/ˈôdēəns/
noun
  • 1.
I have a timber harvester looks like cooks but came well before them and it has the plywood panels. One time on site with a customer I threw a blade and it stuck in the plywood. I turned to the customer and said you now see why its plywood and not steel. He laughed and said it must have happened a time or two based on the holes in your plywood. I smiled and said it happens more than I like to admit.
Best part about plywood is I saved many blades and I can make new covers in no time at all.
Timber Harvester 36HTD25 fully loaded
2006 Dodge 2500 first Auto to NV5600 swap, EFI Live Tune by me
John Deere Tractor
Massey Ferguson 711B SkidSteer
Brad_bb
I've done what the OP describes more times than I'd like to admit.  Whether I try to put the band on and try it depends on what I'm cutting and if I can afford to risk a dive.  If you put it on and get it turning and don't see any visible blurp in one spot, then try it slowly on wood.  If it's good, run it.  Just make sure to feed slow and cautious at first.
Percy
Quote from: Brad_bb on February 28, 2019, 08:32:12 AM
Ive pondered putting mabey 3/8 plywood on the inside of my blade doors. Seen it done on many mills...Or I could just be more careful ;D ;D
