1010D Crane module
Started by sebasbeaudoin, May 05, 2024, 10:04:11 PM
sebasbeaudoin
Im new on this forum. Don't trow me rocks plz. I just purchase a John Deere / Timberjack Forwarder 1010D 2005. I do have persistent issue. I would like your help to diagnostic.
At the beginning I had crane speed / control issue. Changed one of the joystick / calibrate / adjusted  by the dealer. Now run as new corect speed and all movement works.
But after this story fixed, still have a trouble with losing the Crane module communication.
In fact it's happening when you clam wood and all the sudent I loose all hydraulique control on both joystick.
Sometime it come back after a couple seconds, but most often I do have to shut down the engine. When I restart all good to go, for another couple minutes until it stop again and again.
Any Ideas ?
Appreciate the community support
Hakki Pilkie 37 / John Deere 1010D
barbender
I haven't ran JD/Timberjack machines, but it sounds like you have either a direct short, bad connection, or a broken wire in your electronics. You'll have to dig into it more to figure out which.
 Which error codes show? Just the crane module communication?
 I have had modules go bad before that made some goofy things happen, too.
