Blade guide felt washers
Started by Dan_Shade, April 19, 2021, 09:21:54 PM
Dan_Shade
Anyone know the purpose of the felt washers in woodmizer blade guides?
I'm curious....
lots of dull bands and chains
My thought is that they keep the water/lube from the bearings.  I normally give each side of the blade guides a squirt of ATF which saturates the felts before each sawing day.
Southside
I would think more along the lines of keeping fine sawdust out, sort of like the foam filter liner on small engines?
White Oak Meadows
donbj
Just a barrier to keep crap out of the bearing. Magic Man's idea of atf on them is a good one.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
D6c
My older LT40 had greasable bearings with felt.  I changed it to sealed bearings and elimeated the felt.
No, the oiled felts come installed in new blade guide rollers and also in replacement bearing kits.
Bruno of NH
Bruno of NH
??  They are behind the washer/nut, etc. and don't wear out.
jpassardi
I believe they are available separately. I think MM is right - to reduce lubewater entry.
Dave Shepard
I went 1057.8 hours on the original rollers. Bearings are sealed. I think the felt just keeps debris out. Bearings and felt were fine, just had some wear on the rollers. Never did anything to them.
terrifictimbersllc
Quote from: Bruno of NH on April 20, 2021, 08:00:46 AM
Can you just by the felts ?
P04252 white felt washer 37 cents, goes in back against the circlips
P06455 gray felt washer 35 cents goes in front against the bearing
last probably as long as the bearings, but they can get nasty and are cheap.
