Other topics for members => General Woodworking => Topic started by: hackberry jake on February 13, 2013, 01:21:05 PM
I have lost a few $ worth of products over the years simply because I forgot to bring my finishes inside. I use something in the summertime and put it in a shelf in the shop when I'm done. Winter time comes around and I forget it's there and it freezes and is no good anymore. Do they make the opposite of a refrigerator? Something that will keep the inside temp above 50 or so? I was going to glue up some white oak this morning and it said glue must be above 45 degrees. It was right at 45 so I postponed the glue up til a later date. I could probably make something myself I suppose. Just an insulated cabinet with a thermostat controlled electric heater inside, but would feel better about fire safety if it was a premade unit. Do such things exist?
Use an old refrigerator with a light bulb left on inside.
Lefty1981 beat me to it, :D
Find an old fridge gut it outof its compressor, redo the insulation and make some shelving that will hold what you plan on storing in it and put a 40 watt light bulb in there that will stay lit and heat the inside. If the insulation is real good ya might get away with a 25 watt bulb.
You guys are geniuses! I've heard of that for pump houses. I don't know why I didn't think of that!
works good for welding rods too.
Great idea, i ran into sorta the same kind of issue...but mine involved curing meat. I have a fridge in my garage but the outside temps were in the -25c range a few weeks ago....things were getting too cold so put a 60w bulb in the fridge and left the door opened just a bit...temps were around 3-4c...perfect!
I must assume that Mr. Bishop is talking in degrees celcius.
Quote from: sbishop on February 15, 2013, 09:54:41 AM
-25c range 3-4c...perfect!
Lee, I am sure the little "c" after the numbers is giving that away ;D :D
Put them in an igloo cooler
