Gang Rip Question
Started by Kevin_H., September 28, 2003, 02:25:45 PM
Kevin_H.
Is anyone using or seen in action a gang rip?
I'm looking for something that will rip and size 5/4 x 8" boards into two 3 5/8" pieces. we are sawing pallet stringers and are looking to get better consistancy on the size.
Thanks in advance
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
shopteacher
I'm not to familair with the gang rip, but have looked at quite a few straight line rip saws.  The're awsome.  I'm loooking to find one at the right price at the right time. Either don't have the money when available or just spent what I had when one comes available.  I imagine the gang rip is just as fast and accurate as the straight line.  Seem the chain wears so if looking at a used one you might want to pay special attention to that area.
ladylake
I have one set up in my RBI machine right now to cut stickers out of 3/4" pine. Cuts 4 one inch at a time, works great. Way faster than on the table saw.
Kevin_H.
We have thought about buying a woodmaster and using the gang rip on it but it will only do up to an 1 1/2",
we dont cut pallet material everyday, but I dont know if it would hold up.
The only plus is you can get into it for a couple of thousand.
dewwood
Try looking into an edger.  Most have one fixed blade and one moveable blade, you could rip different sizes by just moving the blade.  Some will only do two inches thick others will do thicker stuff.   Horsepowers requirements increase with capacity.
Other benefit, you can edge your lumber with it.
Selling hardwood lumber, doing some sawing and drying, growing the next generation of trees and enjoying the kids and grandkids.
Kevin_H.
Thanks Dewwood,
It looks like that might be the way we go, kinda killin to logs with one stone, so to speak. ;D
Fla._Deadheader
Kevin, on my Corley Edger I had, there was an angle iron that was movable on the LEFT side of the stationary saw, that was on the left side of the edger. It was movable, so that I could swing it over to cut 2" and 4" and 6" boards with the stationary blade, and also cut whatever with the movable blade. That made a 2 board rip possible with one pass considerin wane on both edges, 3 boards without wane. Don'T know if Noble's edger has that feature??? Maybe we otter ask him???.  Hey Noble :D :D :D :D :D
Kevin_H.
Noble...Noble...where are you...
Bigdogpc
uh...anybody tried to build their own edger?  Maybe a couple of circular saws and a roller table?
Fla._Deadheader
  There was some discussion a while back. Might check the search feature for edgers.
D._Frederick
Bigdog,
I built a 2 saw edger from scratch 3+ years ago, but have not used it much because of health problems. I used all new material and have a friend that was setting up a shop. He did the machining for me @ $25 per hr. about 1/3 of going rate. He made the arbor and sliding collars, the feed rolls (used #40 roller chain sprockets), pressure rolls, and bored holes in 5/16 plates to mount bearings. I made the frame out of 6 inch channel bolted and welded together. Had a sawshop make the 12 inch split carbite blades @$95 each. I have $900 in machine work and a total of $3200. I have an edger that would cost over 7K if bought from a dealer.
If I had to do it again, I would buy a used edger like Mitch did and rebuild it. A lot less headaches!
